Question about Zodiac BARRACUDA G3 IN-GRND CLEANER
Suction with my pump
I have an inground pool and have a hayward super pump. Just purchased last season. When we went to stat the pump this year, the basket is filling with water but it is not moving fast enough to give us the suction to even hold the skimmer basket down,. When I turn the valve to "backwash" , "drain", and rinse, we have perfect suction. We just are not getting any suction when the valve is in "filter" mode
    New Friend:
  • 77 Answers
First thing to check is the removal of any winterizing plugs in the return lines. Sometimes plugs are fitted inside the lines in the pool making them not obvious. Secondly, check that any valves in return line are open. Many never lube type valve handles are oppositely positioned as compared to ball valves. If the multiport valve hasn't been tampered with, then there really is no other place to look. The flows everywhere but back to pool.
Posted on Apr 24, 2009
Upon startup ...new season. Pumpstarted but when full circulation started pump shut down and seemed overloaded
well..you can start by blowing out the back of the motor with compressed air" where the wires go into tthe back of the motor cover" there is whats called a start switch there ! if this fails to fix it search for your local pool pump motor repair guy in your area and bring it to him for free testing.. CLICK HERE HOW TO REMOVE MY PUMP .. LAST prime the pump and make sure the filter needs to be clean
May 26, 2011 | Hayward 3/4hp Super Pump Inground Pool...
Just purchased a new super pump 1hp, but it is
Can you be more descriptive? My guesses are that the motor is wired wrong, the motor is defective, There is a leak in the supply line or the pump and air is getting into the pump, causing the pump to cavitate.
Jun 02, 2010 | Hayward 1HP Super Pump II Inground Pool...
The vacuum seems slower and doesn't get around the whole pool. Is there a way to speed it up
If it's a suction cleaner, give it more suction. Clean the filter and adjust valves to give correct suction
Feb 25, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Pumping water intermitting
If the pump motor runs continously it probibly is a suction side air leak, check all "O" rings, gaskets and fittings, it could also be a restricted suction screen or filter basket as well, Need more info to get more specific.
Aug 16, 2009 | Hayward 1HP Super Pump II Inground Pool...
My Haywaord filter psi gauge is 19 psi's and the
clean the filter.also check that the main drain is closed and80%suction is from cleaner.
Jul 04, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Loses suction after 2 hours
Filters are getting blocked.
Clean more offten - use filter socks (if have skimmer box).
OR get better pump/filter system.
May 31, 2009 | Hayward 1HP Super Pump II Inground Pool...
Inground pool question. How far away can I position my skimmer.
you don't say the volume of the pool, but if the 1.5 was working before and you are not adding too many turns, it will work.
David
Apr 28, 2009 | Hayward Pool Products HAYWARD 1.5 HP 2...
Lossing Prime
It's pulling in air very slowly from somewhere:
priming pot lid,
valve body tops,
valve handles,
pipe unions, --
check gaskets/o-rings-- replace defective ones, lubricate
tighten everything possible
Apr 10, 2009 | Hayward 1HP Super Pump II Inground Pool...
Zodiac BARRACUDA G3 IN-GRND CLEANER Logo
345 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
