Godrej semi automatic washing machine
E1 error
SOURCE: Can't get rid of E1 error on a Samsung front loader washing mach.
E1 : washing machine has exceeded a check time for fill, heat or empty.
Common causes for this are fill and empty problems, heater fault (or the wiring
to it broken), water pump open circuit (although that would stop the water draining too) Pressure chamber blocked or pressure tubing pipe looped below the pressure bottle, or a sticking eco ball in the sump hose (sludge and grease build up)
This error code is generic and vey common.Since you have tried the remedies.Try getting checked the internal wiring damage by professionals.I hope certainly hope the problem lies there.
Posted on Dec 10, 2008
  • 1738 Answers
SOURCE: error e1. washing machine will not drain
Two problems. Step one check the drain pump motor, to see if it draining the water out. Next step if the drain pump working you have a clock in the hose between the drain from the tub to the pump. Messy job witht he machine being full of water. I suggest take a small bucket and empty try to empty it out as much as you can.
Posted on Aug 10, 2009
SOURCE: hi am getting e1 error in my washing machine
what is an E1 error message
Posted on Jan 04, 2010
  • 343 Answers
SOURCE: my lg washing machine is a semi automatic model
Sounds like a pump or drain hose blockage.. Check filter. Could also be the pump motor. The more resent synchronous pump motors get detritus inside them and gradually 'gunk up'. You may be able to drain the machine by lowering the drain hose and allowing gravity to help. this won't work if the drain hose is mounted high at rear of machine......Nomess
Posted on Apr 18, 2010
caroldon
  • 17129 Answers
SOURCE: water gets drain cannot remain
The drain is pull the knob which will pull up the drain valve. So if this is not working then the connecting bowden is broken and is not connecting the link to the bottom drain valve.
Look at the bottom and connect. Clean the drain valve, if choked.
Posted on Sep 14, 2010
WHAT IS MEAN BY ERROR E1 IN AUTOMATIC WASHING MACHINE
try adding a make and model to a google search Google
Aug 10, 2017 | Heating & Cooling
When stachi do, not move clothes.
Godrej front load washing machine model no GWI5511 RES. Error e 5
Apr 20, 2017 | Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    My samsung automatic washing machine wa7584c1 is giving me a 1E error why
    You can sometimes solve issue by unplugging unit from wall for ten seconds to reset sensors.
    CERACOAT-NANOTECH.com
    May 14, 2015 | Samsung Washing Machines
    Godrej eon washing machine e2 problem.
    eco wash fault this can be down to hard water areas, the switch for the water intake is stuck can be opening but not all the way so it shuts it back off and you get this code.
    May 09, 2014 | Washing Machines
    My Onida Semi Automatic Washing machine Hydrofall 70S model Spinner is not working
    onida semi automatic washing machin motar is rotating in only one direction (clock wice direction) ho to solve the problem?
    Apr 28, 2013 | Washing Machines
    Error during start for samsung automatic washing machine
    E1 = Not filling in allocated time
    This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed.
    Nov 28, 2012 | Washing Machines
    Ac voltage become hihg or low when start ifb washing machine
    We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
    Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
    Sep 30, 2012 | IFB Washing Machines
    I need a user manual of whirlpool semi-automatic washing machine
    whirlpool semi automatic washing machin motar is rotating in only one direction (clock wice direction) ho to solve the problem?
    Sep 22, 2010 | Whirlpool Washing Machines
    Washing Machines Logo
    20 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
