Question about Goodman CKL36AR36 Air Conditioner
Fan and compressor will not run
I have two units one for upstairs and one for down. On the upstairs unit the fan and compressor will not run. Tried to turn off breaker to see if maybe woud reset any electronics. Pushed reset button on thermostat. Tried swapping out thermostat with one from the other unit.(they just plug in). Did not see anything abnormal at evaporator. Found black rocker switch I assume maybe a rest button, pressure cut out or something similar, tried that and heard a click. Still nothing. All functions on the digital thermostat seem to be working just nothing tuns on. Was working fine and then not working. Only about four years old and serviced two years before.
  • 1 more comment
  • blip77521 Apr 24, 2009
    The indoor fan does not run in auto or on position. Gas heat. No disconnect outside. I had the unit upstairs checked for fuses. Havent checked the t-stat wires outside. Good point. I am trying to have a friend check this for me for my my via email as I am offshore working in Africa for two more weeks. thanks
    Will have him check voltage.
  • Ken Bledsoe May 11, 2010
    We need to run a couple of checks if you can. Make sure the small two wire thermostat wire is connected to condenser. And you have 240 volts to condenser. Let me know and we can go from there. ok ken
  • Farley Redfield
    Farley Redfield May 11, 2010
    Helps if I know if the indoor fan runs or not. Is it all electric heat? Is it natural gas heat. Does the outdoor unit have an electrical disconnect? Does this disconnect have breakers or fuses in it?are the thermostat wires still intacted to the out door unit? (found 1 today that got cut up by weed eater).
    Guru:
  • 462 Answers
Ok here is what Im wondering. Most of the gas furnaces sold here in USA have what we call a "door switch" If the panel thatcoveres the blower door is left off nothing will run. If the door switch is bad , nothing will run. Then on some gas furnaces there is a fuse on the control board, if its blown it may cut off the 24vac power and this could be the trouble. If the fuse is blown dont use anything bigger than 5 amp. If it blowes again check for tstat wires together or grounded. If none showing get back to me and I'll help you decide lnext step. 1 of these items Ive mentioned may allrteady be the trouble. Please rate me as high aS you can and thank you for using fix ya.
Posted on Apr 25, 2009
  • 24 Answers
Try replacing the fuses for the condensor.
Posted on Apr 24, 2009
I turned my AC off during a 3 day cool rain spell. When I turned it back on to dehumidify the upstairs only the fan ran. I can hear that the unit is energized but the compressor
possible bad capacitor for compressor. or burnt wire connection at several locations inside the unit. a look see at the capacitor can tell if the cap is swelled up-it's bad. it is possible for a voltage spike ,during a storm, to cause these problems.if you remove the electrical panel door,of the unit, be sure to turn off high voltage to the unit at the breaker. remember that a capacitor stores a charge that will electrocute you even if high voltage is turned off at the breaker!!!!!!!!
Oct 12, 2015 | Heating & Cooling
Breaker trips on unit. Fuse in house is ok. As soon as AC unit turns on it trips the breaker outside next to unit.
you have a 'direct short' - most likely the compressor or fan motor.
you could isolate it to one or the other by (be sure all power is off) disconnecting one of them and turning the unit back on.
For example if the fan motor is shorted and you disconnect it - the breaker will hold and not trip and the compressor will come on - which will tell you that you need to replace the fan motor.
If you do this and it still trips the breaker then reconnect the fan motor and disconnect the compressor and try that.
If the breaker holds and the fan motor runs then you know the compressor is shorted.
Note: the fan motor can be replaced with not a lot of trouble depending on how mechanically inclined you are - but the compressor will take a qualified serviceperson.
Jun 06, 2011 | Heating & Cooling
Kenmore central air conditioning unit tripping breaker each time we turn it on.
The breaker tripping when you turn the unit on indicates a 'direct short' and 99 out of a 100 times the short will be either the outside fan motor or the compressor itself. Either way - you will need a qualified serviceperson to diagnose this problem correctly and make the needed repairs.
Best solution is to call AC person.
However, here's a good way you can get it down to either the fan motor or the compressor.
(1) With all power OFF - disconnect the wires to the fan motor
(2) turn on AC unit (a) if breaker trips it means the compressor is probably the shorted component. (b) if breaker DOES NOT trip and the compressor runs - it means the fan motor is shorted.
(3) If breaker tripped with the fan motor disconnected meaning the compressor is probably shorted you can then (with ALL POWER OFF) 'disconnect the wires going to the compressor' and re-connect the fan motor wires. Turn on power - and if fan motor runs (with compressor wires off) you know it's the compressor that is shorted.
After all this you will now know which of the two (compressor or fan motor) is shorted.
If it's the fan motor you can with 'limited mechanical experience' change the motor yourself, but if it's the compressor you will need to call a serviceperson because of the expertise needed to replace the compressor.
Jun 05, 2011 | Kenmore Heating & Cooling
Rudd Achiever series model RQNJ-AO42JK 000 mfg
Turn the thermostat as low as it will go and have someone stand out side, they should here the condensor fan and compressor come on at the same time. They are two distinctive sounds so you should
be able to tell if the compressor is running.
If nothing happens and you are skilled with electrical
you can turn power off and remove the electrical
cover to the outside unit. Restore power and carefully
push in the contactor, if the fan and compressor
starts you have a thermostat or low voltage problem.
If just the outdoor fan runs on any attempt, more than likely you need a new capacitor.
Jun 18, 2010 | Ruud Central System Air Conditioner
I have an goodman model gsc130241ae unit will not
Hello Does the thermostat have a display?Check emergency wall switch and curcit breaker all on.Fan on should at least run if power.
Mar 31, 2010 | Goodman CLQ36AR49 Air Conditioner
COMPRESSER IS VERY HOT, FAN OUTSIDE BLOWING COLD AIR OUT NOT HOT
Most likely the unit is low on refrigerant. You could also have a restriction in the system. You need to put gauges on the unit.
Jun 14, 2009 | Ruud UBHC Air Conditioner
AC wont kick on....
The first thing to check is your breaker box. There should be one double breaker for the air handler unit, that's the inside unit, and one double breaker for the compressor, that's the outside unit. Check both breakers. If you're not sure if they've be thrown, click them toward the outside of the breaker box (off position) and then click them toward the inside of the breaker box (on position). If the breakers are on and you still are not getting any A/C take a look at your compressor, (outside unit). If the fan is running at least you're getting power. However, your compressor down inside the unit may not be getting power or it may need to be replaced. The compressor has a start-up cap. If this cap goes bad or the wires from this cap fry or corrode away, this will also keep the compressor from starting but the fan will still run. If the fan is not running it could be caused by a faulty relay inside the compressor cabinet. This relay is supposed to open and close based on a low voltage signal from the thermostat. I believe it's roughly 24 volts. This relay switches on and off the 240 volts for the compressor and the compressor fan. Often this relay goes bad or the wires leading up to it fry. If you?re going to work on the unit yourself make sure all power is shut off. There should be a shutoff switch on the outside wall near the compressor. I?d also shut the breakers off.
Jun 12, 2009 | Honeywell Programmable Thermostat Heater
Fan runs but blowing hot air. Thunderstorm reset some breakers. I did reset the two breakers inside the house and one unit working fine, upstairs unit fan running but blowing warm air only. Box out
Sounds like your Capacitor is bad, or you had a wire burn off compressor terminal or capacitor. Way you can check capacitor is take cover off and see if looks swollen. Make sure to turn off power before taking panel off.
Apr 25, 2009 | Heating & Cooling
Turn the unit on, the fan runs, and when the compressor tries to start the fan slows down and the compressor will not run. After a few seconds the fan speeds back up. I put an amp meter on the compressor...
sounds like you have a bad capacitor, if it's not tripping the breaker it doesn't sound like the compressor is drawing LRA unless the breaker is oversized for the condenser.
Apr 24, 2009 | Heating & Cooling
Goodman CKL36AR36 Air Conditioner Logo
291 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
