Question about Panasonic NN-T783SF 1350 Watts Microwave Oven
Left Microwave on while empty
I have a Panasonic Microwave Model NN-T783SF. I set the clock to 30 minutes and instead of pressing the timer function button I pressed start. The Microwave was empty. At approx 20 min there was an electrical burning smell and I realised what I had done. By this time the display was no longer showing. I pressed stop and opened the door. the whole microwave was very warm. When I reached behind to turn the power off at the wall the back was hot. I have not tried to use it since as I wan to find out the likely damage and if it is worth repairing. I am an electrician but have very limited electronics knowledge. Thanks for any advise you can give. Cheers, Jason
  • Jason Apr 24, 2009
    I just turned it back on and put a bowl of water in it. Display seems ok. Set time to 1.00min started normally but only ran for about 22 seconds before turning beeping once and stopping. reset for 30 seconds and it did the same, ran for about 22 seconds then beeped once and turned off.
    Hope this helps with possible diagnosis.
    Thanks, Jason
Hi James, Well it sounds to me as the Magnatron burnt out. There are tests you can so, so to familiarize you with what it looks like by copying the link. http://www.ebay.co.uk/itm/PANASONIC-INVERTER-MICROWAVE-OVEN-MAGNATRON-2M236-M42-NN-SF550W-1000W-/262200547027?hash=item3d0c5ed6d3:g:ucsAAOSwSHZWdkWb#ht_1687wt_726
If you are prepared to open up the unit there are a couple of checks you can do on the mag. If you see the item described above in your microwave, chances are its that. With all the video's readily available to view there is little or no point in my describing to you for what to do next so I will advise you look at 'YT' and search for 'TESTING A MAGNATRON' This should hopefully lead you to the conclusion that your Magnatron is faulty.
If it is not, then there is a possibility that the door switches could be at fault, but it's best do do this in a step by step approach to eliminate the issue.
WORD OF WARNING: I have studied electrics but even with my knowledge I received a 250v JOLT across my body due to being careless. I touched the case at the same time as the LIVE in the microwave. DO NOT MAKE MY MISTAKE. IF YOU do not feel confident to remove the cover on the microwave, then DON'T and if you do then then MAKE DOUBLE SURE IT'S NOT PLUGGED IN. I won't forget so easily If fix another.
::((((( . BE SAFE.!!!
Posted on Apr 03, 2017
4 Suggested Answers
SOURCE: Panasonic NN-C994S stop 2 sec. after I press Start.
Sounds like the power inverter
Posted on Apr 18, 2008
SOURCE: Panasonic NN-H264 1200...stops after 3 seconds
I found sufficient information elsewhere.
Posted on Feb 13, 2009
SOURCE: Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Posted on Jan 20, 2010
How to set the clock Model NN-SA651S
To set the clock, press Timer/Clock twice when the microwave is not in use. The colon between the hour and minutes should start to blink. Type the current time (12-hour clock) with the appropriate number key pads. To save the time and exit the clock set mode, press Timer/Clock once more. Note: if you take too long to begin typing the time, the microwave may exit the time set mode. In that case, the colon will stop blinking. None of the other features of the microwave will work when the colon is blinking.
This is shown on page 11 of the manual which is available on the Panasonic NN-SA651S support page: http://shop.panasonic.com/support-only/NN-SA651S.html . The direct link to the manual is currently ftp://ftp.panasonic.com/microwaveoven/om/nn-sa631_nn-sa651_nn-sa661_en_om.pdf .
I hope this helps.
Mar 16, 2018 | Microwave Ovens
How to reset the clock on a Panasonic NN-SA651S microwave.
hi carol.
try this,if this does not work go to the link.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set. You are now ready to use your new Panasonic Microwave Oven. When you first turn on yourmicrowave oven and under normal operation the "CHILD LOCK" feature is off. If "LOCK" or "CHILD" appears on your display . . .
set-up guide - Panasonic
ftp://ftp.panasonic.com/microwaveoven/om/set-up_guide_en_om.pdf
How to reset the clock on Panasonic NN SA651S microwave Google Search
Nov 07, 2017 | Panasonic Microwave Ovens
How do I set the clock on a Panasonic microwave nn-e271wm
To set the clock, you need to press Timer/Clock twice. Then press the 10 Min keypad several times until you get to the correct hour. Then press the 1 Min keypad as needed to get to the closest 10 minute period below the current time. Finally press the 10 Sec keypad several times to reach the current time. Then press Timer/Clock once to exit the time set feature.
Panasonic has the manual for the NN-E271WM on their downloads page: http://www.panasonic.eu/Downloads/en_GB/popup.html . Enter the model number and then click View. You will need to accept the Panasonic Terms Of Use and click View again. The direct link to the manual is currently http://tda.panasonic-europe-service.com/docs/2z5845f124z3z39cabz656ez706466z25z9709ff8b3ba329b0c218b9bf248a6442e93022b3/tsn3/data/ALL/NNE281BMBPQ/OI/912715/NN-E271WME281BME281MM.pdf . See page 21 in the manual (23 in the PDF) to see the procedure.
I hope this helps.
Dec 05, 2016 | Panasonic Microwave Ovens
How to reset time
"Clock"
once
or
"Timer/Clock"
twice
(depending
on your keypad)
The colon symbol (:) will flash.
Enter time of day.
The time appears
in the window; the colon continues
to flash.
Press
"Clock"
or
"Timer/Clock"
day is set !
Nov 16, 2015 | Panasonic Microwave Ovens
How do I get my Panasonic Inverter microwave out of demo mode? I think my toddler might have hit something to put it in demo!
Hello Two options to try: a) Press the Clock / Timer button 3 times b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
This should work with all Panasonic Microwave models.
Good luck
Aug 10, 2010 | Panasonic NN-H275 Microwave Oven
Model NN 9804 U microwave in Demo Mode
No owner's manual?
If you're in the US, find it here.
If you're not in the US, see Panasonic.net and look for support / download links.
Otherwise, I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Jan 14, 2010 | Panasonic NN-T888S Convection/Microwave...
Microwave turned on when empty
The magnetron will be damaged and now emit low output as there is nothing to absorb the energy.
I would dispose of it and get a new one.
Sep 01, 2017 | Panasonic NN-T783SF 1350 Watts Microwave...
Operating instructions how to set the clock etc con my mircoware
hit clock button press in the time with the numbers on the pad and press the clock button time solved
Apr 03, 2009 | Panasonic NN-P794SF Microwave Oven
I have a panasonic range microwave oven model NN-H264/S254 clock cannot be set. (It use to work but no longer can be set)
Sounds like you disabled the clock function. If you do not have the user manual, you can get a copy at this website and use the function keys to reactivate and set the clock...
http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/NN-H264-_E
I belive the information you seek is on page 12 of the manual.
Hope that helps...
Aug 13, 2008 | Panasonic Microwave Ovens
Panasonic NN-T783SF 1350 Watts Microwave Oven Logo
314 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
