Question about Lexicon Alpha Personal Recording Studio
When I record & play it back my recording take is off beat
  • 3 Answers
You have too much latency in your setup. Try using ASIO as your audio engine in your recording program. Also, shut down all unnecessary programs running on your computer to get better performance.
Posted on Nov 10, 2013
Im Using Acid Music Studio 8.0 With & Xenyx502 Mixer. Every Time I Record It Sounds Fine But When I Play It Back When Im Finished Its Off Beat How Do I Fix This??
check the "buffer" setting - set to the lowest number possible. You can't eliminate the "latency" but you can reduce it a lot. Also 0 try to monitor what you are recording with "live" sound (input instead of output) - also, you may need to download a different driver for your audio card, try ASIO4ALL
Oct 13, 2013 | Lexicon Alpha Personal Recording Studio
When i record i can hear me very well but the beat has like a funny bass sound to it what can i do to stop it
If your mic can "hear" the beat, it will record it as well with a reverberation that will NOT be pleasing. Maybe you can use headphones to avoid that.
Jul 13, 2011 | Yamaha Mg82cx Stereo Mixer
When I arm a track to record in tracktion 3 I get a delay when monitoring playback.
If you monitor the recording there are two delays... one as audio is converted and stored... the next is when it is retrieved and converted back to audio. Usually the recording interfaces have a monitor function that loops the audio back out before the conversion. playing back previously recorded audio of course will have the delay to retrieve and convert back to audio.
Jul 03, 2011 | Mackie Onyx Blackjack 2x2 Recording...
I recorded drums to the internal click track/metronome and drums are in time with metronome when i play it back with the click from the start of the song. BUT, if i stop in the middle of the song and...
I'd say the click track starts from exactly when you hit play even if you've hit play not right on the beat. There might be a setting or preference that can fix this.
Try rewinding back to be right on the beat and see if it syncs with the click
Jul 01, 2011 | Tascam 2488mkii 24 Track Recording...
I have the Simmons SD9K electronic drum kit. I really love it, but I have two seperate issues. First, I sometimes get a snare pop out of the blue while playing a beat and sometimes just after I stop...
With the sensitivity set very high, you might be getting false triggers from static discharges. It sounds like your snare trigger is either bad or possibly the cable from it may have a problem as you should NOT have to set the sensitivity so high.
It will take an oscilloscope to test the pad unless you can find a system to do a sensitivity comparision. The second problem regarding the recording/overdubs I cannot help you solve.
Mar 27, 2011 | Simmons SD9K Electronic Drum Set
I am trying to record sounds from my keyboard into my MPC 1000. I have what I think is the proper set-up. MIDI sync...softthru as track...etc. Problem is when I set it up I can play one sound and record...
It is not clear whether you are recording audio or MIDI. If you recorded Audio samples, you will get the same sounds back even if you change the voice on the keyboard.
If you record a MIDI sequence, and then play it back you will STILL get the same sounds UNLESS you also record the MIDI voice or patch changes so the voice is changed as it occured when you recorded it. Usually there are options taht you can enable or disable voice changes.
Feb 11, 2011 | Akai Music
I bought mv 8800. I bought converter which converts from 250V-50Hz to 110v 50w So I get into my mv, with vga mode, and i see software with lags, not freezing but for example i play beat, it records not...
This is NOT likely to be a problem with the power source at all but more likely with some setup parameter. Search your manual for subjects like "quantize" and also sampling rates.
Dec 01, 2010 | Roland Mv8800 Production Studio
Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
Midi doesn't actually "make sound". If your trying to record the patterns you made on the DR-5 to the recorder you need to use an audio output(I don't remember if they are RCA or 1/4" on the DR-5.) The midi output would be used to"trigger sounds" in another device that has sounds built in, or you could also trigger sounds in a program that supports midi input.
Mar 03, 2009 | Boss Micro BR Digital Recorder
Open Questions:
Lexicon Alpha Personal Recording Studio Logo
Top Lexicon Music Experts
Michial Gueffroy
Matthew Spark
Matthew Spark
Electro Med Services...
Are you a Lexicon Music Expert? Answer questions, earn points and help others
