Question about Kitchen Ranges
Sears model 790.99122401 elite stove. Glass between over doors is filthy. Took door apart and now have a part left over that we can't figure out where it goes. Help?
SOURCE: how to take apart oven door
you need to remove the door. On your model just grab the door and lift and it should lift right off. Then remove the screws that run along the bottom of the door. Remove the bottom trim and the glass should slide down and off. Reverse to assemble
Posted on Jul 21, 2007
  • 833 Answers
SOURCE: KESC307 Oven Door
Hi Mcrae...
Generally, the procedure is a straightforward mechanical one.
First, check below the door for screws and remove them. Next, open the door and find the screws on the side and inside of the door. Remove them. Careful...when the door panel comes off, the door will be much lighter and will slam closed if not restrained. The panel should 'fall away' from the door. Have someone assist you here! At each stage, take a digital picture of the disassembly so you can assist yourself in putting it back. Clean the glass with a blue cleaner and buff out. Use a scrubby or very fine steel wool to gently remove any stains from the old glass you're reusing. Do this on a bedding of newspaper. Always handle glass by the edges.
When installing the glass, it should generally be apparent which way it goes in. Some glasses have patterns on them which correspond to the door opening...if it is the outer which is being replaced. Note them. There may be an up or down as as a result. Any foils or patterns are positioned to the direction you won't have access to later.
You'll likely need a second pair of hands to put it all back together. Take your time. Don't force anything. Tighten screws evenly.
Posted on Dec 03, 2007
SOURCE: How to Dismantle Oven Door to Clean Glass
yep but it isn't worth it in my opinion if you want to know i can tell you its a pain and usually you cant get it all off because its baked on but if you want to do it just reply to your own message and ill write procedure in the morning there is about three or four pieces of glass in there insulation all kind of stuff lol -tech17
Posted on Dec 29, 2007
SOURCE: Kenmore Elite Range door locked error message
Hold down the number three button until the LOC message disappears and then the door will open.
Posted on May 13, 2009
SOURCE: Staining between glass in oven doors of Kenmore electric stove
I had the same problem with my Kenmore elite. Also told they would not cover it under the warrenty. Seems like alot have this issue with these inner glass panels.
It is a nightmare to remove the glass yourself.
But before you go and pay $150 for a service tech, try this:
Under the oven door there are large vents. If you remove the bottom drawer, you can get better access to them. Or you can remove the oven door entirely and lay it on a blanket...this is not that hard to do.
Buy a bottle cleaner brush with an extra long handle.
Tightly tie a sock around this and spray all over it with Windex. Push thru the vents and wipe, wipe, wipe.
It might take awhile to get it all clean, but it works.
You will need a long handle though..and something flexible. So that bottle cleaner brush works well.
I did it about 6 months ago and worked great.
Unfortunately, just recently I cleaned my oven after allt he holiday cooking spills.
And voila...tons of dark streaks running down the inner glass.
So I will do the windex trick again.
They do need to come up with something better considering the costs of these ovens!!
Posted on Feb 08, 2010
Replacing oven door glass
You didn't say what brand or model but here is a link to a youtube video for a Frigidaire oven, Other brands and models on youtube too. You will probably be able to get a replacement kit from sears parts direct if you have the brand and model number. Or an appliance parts store or ebay.
Range Stove Oven Repair Replacing the Inner Oven Door Glass Frigidaire...
Aug 16, 2014 | Ovens
Magic Chef microwave oven
On alot of models the door comes as a complete assembly and can't be taken apart. Magic Chef is made by Maytag and I am pretty sure theirs do not come apart. If it does come apart then it is likely held togther by plastic tabs that have to be pried apart. The problem is they break easy and then you will be replacing parts. Guess you will have to decide if it is worth taking that chance because doors are expensive. I don't see your model # in the description but you can try looking a diagram by typing in your complete model # located on the sticker inside the microwave. Try sears.com and click on parts and various other repair sites. Hope this helps. Let me know if you have any other questions.
Oct 07, 2007 | Microwave Ovens
Oven door
Nectar time take a photo first, they generally only go back one way.
removing the door may make it easier open the door see the hinges on the bottom lift up the little cam on each hinge then just lift the door up & it should come out.
Apr 17, 2014 | Kenmore Sears Electric Range Stove Oven...
I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
Oct 10, 2009 | Kenmore Ovens
Apr 19, 2009 | Kitchen Ranges
Icemaker auger
To see how the auger goes back together, go the the Sears parts web site and put in your model number. It will show the parts list and a diagram. You may be able to print it out, Don't remember if there is a print option or not but if you have a screen capture program you could also.
Apr 13, 2008 | Whirlpool EL7ATRR Refrigerator
Oven Door Inner Glass Replacement
can you gals get me the complete model # off the stove and i will look up the parts diagram & exploded view.
Nov 20, 2007 | KitchenAid KGST307 Gas Kitchen Range
How to take apart oven door
Jun 18, 2007 | Maytag MER5775Q Electric Kitchen Range
Kitchen Ranges Logo
16 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
