Question about KDS Valiant 6380iPTD-01 Notebook
I have a Vaillant Thermocompact VU182 E boiler. Functioning ok except that when room stat. or cylinder stat.shuts of gas the demand light continues to glow and pump keeps on running. Main switchboard has been replaced. Is the fault in the control board and will replacing it solve the problem?
  • 2,019 Answers
Pump should keep running long after gas shuts off, because of residual heat. It is most efficient to shut gas off as quickly as possible, and run off retained heat.
Posted on Oct 13, 2013
Testimonial: "Hello Kirk. Many thanks for your reply. Unfortunately, the pump will run for many hours eventually pushing cold water round the rads. before the boiler re ignites. Peter"
SOURCE: vaillant Boiler time switch no user manual
http://www.vaillant.co.uk/stepone2/data/downloads/9a/42/00/timeSWITCH_120.pdf
Posted on Dec 26, 2007
SOURCE: re-pressure Vaillant Turbomax Plus boiler
two pipes coming into boiler on right hand side have brass block valves with a small round recess. These two valves are linked with a stainless fill hose.
Inside the recess on each valve is a small slot, there is a "key" with the boiler but prob lost with the manual. The advantage of the key is its sized so you wont be poking it in the wrong place!
Using a screwdriver turn both slots throug 90 degrees, you will hear water running through. Sometimes one valve is left open so try a combination until the watert runs.
Keep an eye on the pressure gauge and dont let it get too high, if you have no idea of setting pressure head for about 1bar.
Posted on Nov 23, 2008
SOURCE: f22 on my vaillant boiler turbo max
Hi Guy's,
The answer is that your system is out of water pressure.
Usually there is a nob on the right under the base of the unit near to the small dial to the right of the front cover.
To enable the system to work correctly the needle on this dial should be in the Grey, about midway position.
Currently with fault F22 this will be lower to below the Grey and on the needle.
To bring the pressure back to the correct position, you need to turn this nob until you hear the water entering the system, KEEP AN EYE ON THE DIAL AND TURN THE WATER OFF AGAIN WITH THIS NOB ONCE THE DIAL IS IN THE CORRECT GREY POSITION AS MENTIONED ABOVE. DO NOT OVER FILL THE SYSTEM. I suggest you check this every six months or so.
Once this is corrected your unit will light up again.
Best of luck. Mike. N.
Posted on May 22, 2009
SOURCE: hi my vaillant eco tec pro shut down last night
Got exactly the same problem with mine. Manual says f28 = fault in gas supply, gas pressure too low. Boiler will ignite but goes out within minutes? HELP!
Posted on Jan 08, 2010
  • 104 Answers
SOURCE: vaillant eco tec pro 28
IF the weather is extremely cold, and you're getting F28, the external pipework may be blocked with ice. Warm up the external pipes (lag them if you can) - and now see if your boiler will re-ignite.
A friend fixed our condenser boiler with this tip - hope it helps you.
Posted on Jan 09, 2010
Baxi back boiler. Heating only works when hot water is on, and cylinder stat is calling for heat (Y plan). Is this a problem with room stat?
Turn cylinder stat down turn room stat up y plan valve should move to heating check you have power from stat to valve . It may be the valve not moving over to heating side .
Nov 08, 2016 | Heating & Cooling
I have a Y plan heating/domestic instalation.The boiler will go off and on even if the programmer is off,If the programmer is off and I turn the cylinder stat up the c/heating pump will run,i recently...
Hi the cylinderstat controls the hot water only not the heating the boiler stat controls the water temp the room theromstat controls the rads , if you have one ,
so boiler stat set on 180f or number 5 cylindersat set on 140f to 120f roomstat to your comfort , the boiler stat works as a over heat so if the cylinder stat or roomsat fail it will turn off on the boiler you should beable to check wiring from that .
Mar 10, 2010 | Heating & Cooling
Vaillant Combi boiler
LOOK ON ONE OF THE COVERS 75% OF ALL CODES ARE ON THE INSIDE OF A COVER FOR SERVICE TECHS, NOT MUCH HELP BUT HOPE IT LEADS YOU DOWN THE RIGHT PATH
Jan 23, 2010 | Heating & Cooling
Lost my user manual for the vaillant boiler ecotec plus 824 R1
try to enter here all informations and you can find the manual: http://instructions-manuals.com/search.php?cmarque=VALLIANT%20&modele=ECOTEC%20PLUS%20824
Oct 27, 2009 | KDS Valiant 6380iPTD-01 Notebook
No central heating back boiler
back boiler run from a gas fire? check the instructions to operate the gas heat to the back boiler not just the fire
I presume that this a fully pumped system - air lock doubtful There maybe on/off valves on the pipes to and from the back boiler [situate close to cylinder] make sure they are on - anticlockwise turn
or there could be a blockage in the outlet from header tank usually in the loft. or If there is no water in it maybe the mains cold feed it is off.
Note if no water in it DO NOT USE the back boiler
May 03, 2009 | Bosch & Power Vent Water Heater
I can't turn the bar pressure up on my Vaillant VCW 221 Boiler
on the pipework below there may be a silver braided hose with one or two valves on the end. turn the valve(s) so the handle is inline with the pipe this will allow water from the mains supply into the heating circuit , remember to keep an eye on the pressure gauge. fill the system to 1bar cold then shut down the valve(s). turn on the boiler and it should be ok, if you lose pressure again then you may have a leak somewhere which needs to be found.
Mar 25, 2009 | Water Heaters
Thermo Compact Vaillant Boiler
the thermocompact is a non-condensing model, and should be o.k to fix, you do not need a cylinder as is a combi model and would provide hot water on demand!
Dec 02, 2008 | Heating & Cooling
Boiler light wont ignite
more likely the thermal coupling is u/s get new one fitted
Dec 02, 2008 | Water Heaters
Vaillant thermocompact 628E gas boiler - not working. Seems as though no power getting through. I had a to replace a switch where some drops of water had leaked into that supplies the power to the boiler,...
Dear Prockie..
First, find the wiring diagram and a voltmeter. Attach one lead of the meter to a good ground. Then trace the voltage as laid out on the diagram. For example, if you have voltage to a switch or device, but no voltage out, then that device may be defective. Check all connections. Your boiler has "self diagnostics" but with no display a simple power problem is indicated. If you have no wiring diagram check with the manufacturer online.
Ray
Nov 15, 2008 | Heating & Cooling
KDS Valiant 6380iPTD-01 Notebook Logo
74 people viewed this question
Top KDS Computers & Internet Experts
RobertFonner
RobertFonner
daibras
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
