Need drivers for usb 2.0 - Computers & Internet
  • 2,019 Answers
Do online search at the site for motherboard maker. Since you did not list the maker, we can't tell you the link.
Posted on Oct 13, 2013
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Usb driver software needed for nokia 3500c model
http://www.nokia.co.in/link?cid=PLAIN_TEXT_406563 =)
May 23, 2009 | Cell Phones
Bios no option to Boot from usb Cd rom broken
Floppy works right? So you need to boot from floppy disk, install USB drivers in DOS and then access an external USB device... whew. OK, so getting a dos 6.22 boot disk is easy, then you have to load a DOS-level USB device driver that 'recognizes the chipset in your USB controller/port and can turn it 'ON'
Go here and READ ;-) They have everything you need (except for my expert help)
http://www.bootdisk.com/usb.htm
P.S. There are many DOS-level drivers out there, if you don't find one for your PC, make a noise and I'll see if I can help
Feb 23, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Need driver for SD Card USB Drive for Windows 98
Check these driver :
1) http://www.lowrance.com/Downloads/Drivers-and-Firmware/MMCI-USB-11-Drivers-LEI/
2) http://www.sandisk.com/retail/driverdownloads.aspx
Jun 01, 2008 | Microsoft Windows 98 for PC
My kingston 2 GB USB Data Traveller does not wotk with windows 98
Your USB Data Traveler needs a USB version 2.0 driver. Try tofollow this link and install USB 2.0 driver: http://www.softwarepatch.com/tips/usb2-driver.html
Apr 21, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Driver for Pen drive Kingston 2 GB
Hi
u do ot require driver for xp. its plug and play
if its not working than something wrong with ur xp- usb configuration. pls checkp their
Mar 31, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
WANT USB DRIVER
Go to www.nokia.com
There, search for ur phone.
Download PCSuite.
Install it and connect the phone.
Now you can connect ur phone and access data in it.
Feb 01, 2008 | Adapters.com BT-0333 Bluetooth USB Adapter...
Drive not being recognized
Have you tried this in another PC with, say, WinXP? If it worked then it may be 1 of 2 problems:
1) Driver Issue- you may use a compatible driver and not necessarily a "Fantom" driver. WinME needs drivers for these devices unlike WinXP
2) The USB port is not giving enough power to the drive for it to run (a problem common in older PCs). I have an external USB harddisk that needs to use 2 USB ports in my old Dell laptop since 1 USB port can't supply the power it needs. The cable should have a dual-USB jack on one end, this is so you could use the power from the other USB port.
Hope this helps
Jan 20, 2008 | Fantom Titanium II (TFD500C16) 500 GB USB...
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
