Question about Refrigerators
The light will not come on when opening the refrigerator but does come on when it is closed and goes out when it gets ready to, any suggestions?
  • 2,019 Answers
Look at the switch. Something is hitting the button. It is around the door flange somewhere.
Posted on Oct 13, 2013
Freezer bleeps as if door open. Temp goes down on its own
Kenmore freezer door alarm beeps but door is closed ...
www.shopyourway.com > Manage My Life > Questions
Every once in a while, the door ajar light goes on and the alarm beeps and will not ... Ifthe door is closed good and the door alarm is sounding, it will indicate the ...
How to fix constant refrigerator door alarm beeping? - Shop ...
The doors aren't open and we have checked the air flow vents and made sure ... We have to turn the alarm off to get it to stop beeping but I more concerned about ... If the fresh food section lights are working, meaning you can get the lights to go ... Thefreezer fan motor would need to be checked to make sure there motor is ...
Jan 12, 2016 | Refrigerators
Lights in my kenmore refrigerator, freezer on bottom, burned out. I purchased two 60w bulbs and replaced them. I plugged in the refrigerator and the lights were on. Then a couple of minutes later,
Hello Sharon;
My name is Peter. I am a retired field service refrigeration technician.
You can not put normal house hold appliance bulbs in appliances. There are special bulbs for refrigerators, clothes dryers and close washers.
The bulbs are usually available in the local market and marked; "Refrigerator" and Freezer".
You may have a bad door switch. But, I am more prone to go with the wrong service bulb.
Your Friend,
Peter, Baltimore, Maryland, USA
Nov 16, 2014 | Kenmore Refrigerators
Frigidaire FFHS2612LS4 wont stop beeping
Hey Brandon, this is JK. Thank you for your post. I understand that your refrigerator is beeping none stop. When the door(s) have been opened for longer than 10 minutes, an audio alarm sounds and the interior lights shut off. This protects the liner from melting due to the heat produced by the light bulbs. The alarm will sound every two minutes until the doors are closed. Once the doors are closed, the alarm will reset. The refrigerator will also beep on some models to inform the user that the door has been left open and the cool air is escaping. Check to make certain that the gaskets on both doors have no gaps and that the appliance is maintaining the desired temperature. If all of these suggestions pan out and the problem still persist, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue? If you are still having these issues and can think of anything in particular, please feel free to reconnect.
Hope this helps!
Mar 10, 2014 | Frigidaire FRS3R5EMB Side by Side...
Lights Out and Door Open Indicator Flashes
The problem is above the doors at the switch, the unit can't see the switch opening (closing the door opens the switch). The linkage is where the problem is, the light go out to protect the fridge from getting too warm and the lights are remaining on after you close the door.
I hope this helped. Good Luck
Dec 22, 2013 | KitchenAid Refrigerators
Blinking light in refrigerator
I think that's the light letting you know the door is open so it won't drop ice. When I held in the catch on the left side (as if the door was closed) the red light went off for me.
-Drew
Jun 21, 2009 | KitchenAid KSCS25FKSS Side by Side...
Interior light does not turn off
Hi, try this  There s this knob that gets pushed when you close the door (the door puhses on it when it closes) and the light goes off
you can do it yourself, open the door and find the knob somewhere around the light or on top where the door closes and push it, the light should go off..
Pls rate my solution.. thank you
Apr 10, 2009 | LG LFX25960ST Stainless Steel French Door...
The ice maker is not making ice
I assume "light flashing inside@the switch" means the inside light turns on when you open the door, and goes off when you close the door, or depress the switch manually.
Sounds like the fill valve has failed at the bottom back of the refrigerator.
Reply back your findings if that is not it and I will give you more suggestions.
Jan 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
No inside light in older Kenmore refrigerator
Most refrigerators take the same size. make sure you get a 40 watt appliance bulb. ken
Jan 03, 2009 | Refrigerators
Refrigerator is beeping intermittantly with door closed
Len, I have had many service calls regarding this problem. The problem is the inside door switch. LG missed the tolerences a little. What I have had to do is get a piece of plastic with some double phase tape, about the same size of the switch and mount it so when closing the door it will put more pressure on the switch. The piece should be at least 1/8 inch thick. I believe LG has come out with a kit but the aforementioned works better...Catriver...post back.
Oct 24, 2006 | LG LRTN19314 Titanium Top Freezer...
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
