Question about Epson Stylus CX6600 All-In-One InkJet Printer
Every time I try to print, the left side of the paper tears.
  • 3 Answers
It could be the moveable paper edge guide is in the wrong place, it should be touching the edge of the paper, not too tight. Another problem possible is the paper is not being put into the printer properly, either by operator error or there might be something in the paper path. Inspect where the paper feed in, remove any foreign objects or paper bits. There are some feed guides that could be in the wrong position(broken) but that is unlikely.
Posted on May 05, 2009
When I print a multiple page document on tear paper roll, the first page prints correctly but the pages after that start printing too near to paper tear size or up to paper tear size. What should I do
Sounds like your top margin is not either not set properly or your documents do not have page feed command at the end. Are you sure you have the correct driver installed?
Nov 23, 2014 | Epson Dot Matrix LQ-2090 Printer
How do I unjam a fax machine 1010
to clear document jam:
1 Open the front panel.
2 Carefully remove the jammed document.
3 Close the front panel firmly until it clicks
into place.
If the fax paper jams while you are receiving or printing, Remove jammed paper and press
Cancel appears in the message.
if the paper is jammed in the printing area
1 Remove the jammed paper by pulling it out
smoothly in the direction of the arrow as
shown.
If the paper tears when it is being removed
check to ensure that no small pieces have
been left inside the machine.
2 Press Cancel.
3 If this was a fax, reprint the fax. For more
information, see reprinting faxes on
page 29.
if the paper is jammed in the paper feed
area
1 Remove the jammed paper as shown.
removed check to ensure that no small
pieces have been left inside the machine.
2 Reload new paper with the print side
facing toward you.
3 Press Cancel when finished.
May 04, 2012 | HP 1010 Plain Paper Inkjet Fax
Using Lex. 4'x6" paper, my 901 is not
To properly lay the 4 X 6 in paper in the tray, please follow the steps below:
  • Pull tray completely out of the printer.
  • Move the paper guides to the sides of tray.
  • Use the photo paper outline on the bottom of the tray to help you position your paper.
  • Load your paper.
  • Adjust the paper guides to rest gently against the left, right, and bottom edges of the photo paper.
  • Insert the tray.
Make sure the correct print setting is configured before printing your file. With your file open, click File > Print > Properties > From the Paper Size list of the Print Setup tab, select 4 X 6 in. Click OK to save the setting. Click OK again to print your file.
Jul 24, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Paper keeps ripping on the side on normal one sided printing. Duoble sided printing paper just rips up and jams.
sounds like some tron parper was stuck inside and has contributed to more paper tearing. First check for any paper jams, and check inside for and broken or damages items, causing paper to tear.
Nov 27, 2009 | HP Officejet Pro K8600dn - - colour -...
How to set half half size paper
Look for a latch on the right side tractor drive. This will unlock it so you can slide it sideways on its rail. Set it approximately where it should be, load the paper, then adjust it so you have a slight amount of tension across the paper. I think the rest is software.
Jun 25, 2009 | Epson LX-300+ II Matrix Printer
My Dell 1100 keeps wrinkling and tearing the paper
Depending on wear the tear is at determines the issue. The wrinkling paper and the look of your printer sounds like some sort of fuser issue. Recycled paper is more likely to wrinkle and the grain can cause paper to wrinkle as well. The Long grain paper is up and down the sheet and short gain is side to side on a sheet of paper. If your printer is on a long grain setting and you have the pages coming out sides ways or vice versa then your print outs can wrinkle.
Jun 22, 2009 | Dell 1100 Laser Printer
Paper tears when printing
Helllo sir; I would say 99 % you have paper chip stuck in the paper path , ckeck the fusing unit,
Apr 14, 2009 | HP Color LaserJet 2600n Printer
Paper feed jams
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | HP Photosmart C7280 Laser Printer
Cut off printer during print, paper jam tray 2 won't release
Open the cartridge door and remove cartridge...can you see the paper here...if so slowly apply even pressure to both sides of paper and pull...
keep me posted
Cheers!
Nov 13, 2008 | HP LaserJet 2840 All-In-One Printer
Could you please tell me how to release paper jammed in a hp photosmart c3175 ALL IN ONE printer scanner copier,if I pull the paper it just tears away. Thank You . RAY WINCH. EMAIL...
Clearing a paper jam from the rear door Follow the steps below to clear a paper jam through the rear door.
  1. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the unit. Figure 1: Removing the rear door c00652942.gif
  2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all of the pieces of paper from the unit, more paper jams are likely to occur.
  3. Replace the rear door. Gently push the door forward until it snaps into place.
  4. Press Cancel to continue the current job.
Clearing a paper jam from the front door
  1. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door c00652943.gif
  2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all the pieces of paper from the unit, more paper jams are likely to occur.
  3. Close the print cartridge door. Figure 3: Closing the print cartridge door c00652944.gif
  4. Press Start Copy Black or Start Copy Color to continue the current job.
Aug 06, 2008 | HP Office Equipment & Supplies
Epson Stylus CX6600 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
