Question about Garden
Mixture screw problem
I have a ryobi rlh1100a lawn hornet and i wanted to know what both mixture screws had to be adjusted to.
thanks
This is confusing sorry. There are two screw, outside one and an inside one. Do I:
a) Screw them all the way in and then both out 1 & 1/2 turns
b) Screw them all the way in, outside 1 turn and inside 1/2 turn
c) Screw them all the way in, inside 1 turn and outside 1/2 turn
d) e) f) all of the above but screw them all the way out and then turn back in
Thanks for your help
Posted on Dec 18, 2009
  • 155 Answers
You can start them at 1 & 1/2 and go from there
Posted on Jul 26, 2009
Ryobi 725r carb adjustments
Zama Carb? Turn both low and high meter screws 2 full turns counterclockwise, and idle speed control to maximum. Prime unit and start motor. Run for about ten seconds and then turn idle jet (clockwise) for maximum rpm and then lower idle rpms - readjust idle meter as necessary along with idle screw. Then gun unit at high speed and turn high screw for maximum rpm. Go from idle to max and make sure there is a smooth transition. If not play a tad with the idle mixture screw till that is achieved.
Oct 22, 2015 | Ryobi Garden
Ryobi s430 will idle but will stall out when throttle opens. This carburetor has one idle adjustment screw and one fuel mixture screw.
Those carbs are a pain. Try arousing the idle screw, turun it to the right, then try to see if it will idle. You will have to tinker with the adjustment screw and the idle screw. Eventually you're gonna need a new carburetor. You can rebuild it, BUT , chances are those cheap carburetors never are the same.
Sep 13, 2015 | Ryobi Garden
How do you adjust the high speed mixture screw? I have a Ryobi RLH1100a MK III 31cc line trimmer, and after changing the fuel lines, it will start but not idle more than about 3 - 5 seconds before it...
Hi montex124, I will try to help. In the past few years carb makers have been making changes. Some carbs have no adjustment at all, the ports are all fixed inside the carb. Other carbs have only the idle speed mixture screw that can be adjusted, like yours seems to have. Is this screw you mention at the top and completely outside of the carb to adjust the throttle? If it is it's probably the idle speed screw which can be adjusted to any idle speed you want and has nothing to do with the air fuel mixture but If it is right next to the idle mixture screw, it might be the high speed mixture screw but is capped so it can't be adjusted. The low and high speed mixture screws should be marked next to each screw H and L.
The 1 1/2 turns suggested is sometimes just right but other times has to be adjusted, so you can try adjusting it to get your idle but maybe adjust the idle speed screw first to get a higher RPM so it doesn't stall on you. Like I said earlier it just adjusts the throttle, and is like when you are using it, and giving it gas as they say. I hope this helps just a bit. Regards and good luck. Get back to me if you need more help or just let me know how you did. Denis.
Feb 28, 2011 | Ryobi Garden
Ryobi Lawn Hornet rlh1100a mk111. Having purchased two new fuel lines how do I pull them through fuel tank without exerting too much pressure and possibly breaking new tubes. There is obviously a trick but...
Take a small stiff wire, put it through the fuel line hole and filler neck of tank. Cut the end of the fuel line on approx. a 45 degree angle to make it easier to start it through. Wrap the wire tightly around the end of the fuel line about 3 or 4 times do not wrap around the wire itself, that makes it harder to start in and pull it through slowly helping it along by pushing on it, do this from outside the tank, and when it is started in it is easy to pull through. I hope this helps you out, best regards.
Dec 20, 2010 | Ryobi Garden
I have a ryobi lawn Hornet (weed trimmer) MKIII, i...
Sounds like it has a fuel blockage. Three things to check are;Inspect the fuel-filter (inside the tank) for contaminants. Inspect fuel lines for cracks. Inspect carby for oil residue (blocking the jet). Hope this helps
May 17, 2010 | Garden
Lawn hornet whipper snipper needs tuning
clean the air filter first of all and then take the spark plug out to make sure its clean (should be a light brown color)
if you need to tune it take the carby cover of and you will find two needles or screws marked H and L wind them both all the way in then wind the H out 1turn/wind the L out 1/2 a turn . this is a good starting point. Start the snipper then adjust the L screw minutely till it revs up quickly and doesnt bog down
Mar 18, 2010 | Ryobi Garden
Can't remember what fuel our Ryobi Lawn Hornet uses
All 2 cycle tools must have oil mixed with the gas. Use the proper oil and mixture recommend by the manufacture.
Dec 08, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi lawn hornet mk2
Change your spark plug
If the fuel oil mixture is too oily it will foul the spark plug and no cleaning will get it right.
If there is a lot of oil in the crankcase it may foul the new spark plug so another new one is needed
Aug 10, 2008 | Electrical Supplies
Garden Logo
204 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
