Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Kohler ride on mower ct151 not running smooth when idling it keeps revving every 2 seconds and dyes back again have cleaned plug and filter ???
    Master:
  • 452 Answers
Sounds like tick over speed is running to slow adjust till it runs smoothly,also u might like to adjust the air screw just a possibility also make a note how many turns u do just in case u go to far then u can put back as was
Posted on Oct 15, 2013
4 Suggested Answers
  • 7 Answers
SOURCE: John Deere Mower Engine Issue
HAVE YOU CHECKED THE CARB AT ALL? LOOK AT THE LINKAGE & MAKE SURE IT MOVES FREELY! IF CARB CHECKS OUT MAKE SURE GOVENER IS ADJUSTED RIGHT!!
Posted on Sep 10, 2009
SOURCE: kohler k582 runs poorly at operating speed.
ALWAYS CHECK THE POINTS!!! 20 years operating this engine and you'd think I would know better. The points were severely pitted. Spec said .020 but actual is .013. The cold weather had me suspecting a carb problem. DOH!
Posted on Jan 14, 2010
  • 259 Answers
SOURCE: My 23 hp kohler courage
it sounds like the jet is dirty in the carburetor. Remove the float bowl and in the center there should be a jet that you can remove and clean. There are small holes on the side of it which you can clean with a thin piece of wire. Clean the center hole also.
Posted on Mar 25, 2011
I have a J Deere G 100 Kohler 25 hp mower. On first use this spring, the engine bogs down when the deck is engaged, almost to the point of stalling. New fuel filter, new spark plugs. No change. Help!!
Sounds like you have a dead cylinder. V-twins can run perfectly smooth even one cylinder without a load as they are just running the idle circuits in the carburetor.. Remove spark plug try starting. If it starts shut off engine reconnect plug wire and do the same for the other plug. Should it not start now then that cylinder is dead ignition-wise. Test both cylinders before replacing the coil pack to be sure as it can be a dirty carburetor high speed circuit.
May 26, 2015 | Garden
Ct151 keeps reving and idle
Check plug and clean and re gap also a clean filter will help some times mixture to rich dirty filter ,
The other thing u could o if filter and plug is ok adjust idle speed up till it runs smooth ,1 last thing adjust air screw turn both ways till it runs smooth
Oct 13, 2013 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Toro lx423 inconsistant idle
drain fuel tank. replace fuel filter. strip down carby and give it a good clean and blow down with air put back together. fresh clean fuel and should be as good as new
Sep 14, 2013 | Toro LX423 42" 20-HP Kohler Lawn Tractor
Spark plug keeps getting soot on it
an indication of running rich . check that the air filter is clean and not blocked-- check that the choke control is off after starting--check float level and operation of needle and seat.
Jun 20, 2013 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Sabre 17.542hs loss of power
you could have a weak coil and misfiring under a load each cylinder has it own coil on that engine you can get a inline spark tester to see
Sep 03, 2012 | John Deere Garden
LT1550: runs for about 30 mins on 1/2 to 3/4 throttle. sputters and DIES!!!!! I have to wait a day or two before it would start again.
Try this:
When it begins to stall, loosen the gas cap. If the engine smooths out, clean the vent holes on the cap.
Gary
May 08, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Kohler courge sv720-0010 on cub cadet
SOUNDS LIKE IT HAS SOME BAD GAS YOU MAY NEED TO CLEAN THE CARB AND IT MAY NEED A KIT
Oct 10, 2009 | Garden
15 HP Kohler Engine RIding mower wont stay on
What's the gap setting between the coil and flywheel 15 hp kohler motor?
Apr 20, 2008 | Black & Decker 19" Electric Lawnhog...
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
100 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
Craig Butler
Craig Butler
John Trevino
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
