Question about Dell 962 Photo All-In-One InkJet Printer
My printer is putting a line about 2" from the Left side of the copy only when I use the ADF.
  • inkypete May 11, 2010
    Is it a vertical line? If so there will be something on the strip of glass where the sheet is scanned into machine
My dell printer 962 is not printfrom line
Posted on Apr 25, 2009
"Inka" is right.
Lift the auto feeder, and on the left side of the main scan glass, there is a narrow "filter glass" that is only used with the auto feeder. It only takes a spec of dirt to cause a solid line. Clean it, and all will be good!
Officejet 9600: vertical lines (4) in center of page when copying using ADF. No lines when copying from glass. I tried the cleaning procedures on your trouble shooting pages. They did not help. How ca
John:
When using the ADF, the scanner doesn't move. The long rectangular platen glass on the left side of the machine is used, not the large glass. I believe that if you clean the long, thin piece of glass on the left side of the platen, your lines will disappear.
May 21, 2014 | HP Officejet Pro 8600 e-All-in-One -...
Streaks in the first copy through adf
clean the narrow glass on left of where you place the copy on glass, remove if needed to clean both sides
Mar 16, 2014 | Ricoh Aficio 2035E Digital Copier. 35cpm...
How do i get rid of 2 vertical lines on my copies
lift the scanner lid and then open up the ADF (document feeder) mechanism off to the left.
There's a small glass under the ADF mechanism, and it needs to be cleaned.
Use a glass cleaner like Windex sprayed onto a lint free cloth to clean it.
That's it! put the ADF back down and close the scanner lid!
Problem solved!
Jul 24, 2011 | HP OfficeJet 6310 All-in-One Printer...
Line down side of document when copying - changed cartridge but this did not help used cleaning mode this did not help
Might I assume that you are using the Automatic Document Feeder(ADF) to make your copies?
Put a document on the Flat Bed Glass and copy it. I bet there is no line. Lift up the copy section so you can see the glass. To the left is a thin glass. Clean it. Glass cleaner and a lint free cloth.
Try your copies again. They should be good
Feb 07, 2010 | HP LaserJet 3050 All-In-One Printer
When using the ADF for scanning to pdf, it creates black lines vertically down the left side of the document. If I use the flatbed scanner, no lines.
Your machine ADF is dirty or dust in adf glass please clean it by soft cloth and scane again its clear and sharp.
thanks.
Nov 24, 2009 | Brother MFC-7820N Printer
When the Automatic Document Feeder (ADF) to copy I
There are two scan modes when copies are made.When you make copies through ADF you originals go past small **** glass located to the left of the main exposure glass.Any small mark on this **** glass( correction fluid mark,ink mark,small scratch,dust particle and so on)will show as a line on your copy.So to get rid of these vertical lines on your copies you need to clean this small exposure glass.
Oct 04, 2009 | Epson Stylus CX9400Fax InkJet Photo...
When I use the adf to copy something there are always two lines on one side of the paper (to mark the copy). How can I change the setting for this problem. It does not occur when not using the adf. Thank...
Hi;
If you are only getting the lines when using the ADF , but not when placing the document on the glass then there is some type of debris on the scan glass.
This is a small strip of glass that is independent of the copy glass. This glass should be to the left or right of the copy glass. Just glean this well with alcohol or windex and try copying again from the ADF and see if the problem is gone.
Good Luck
Andrew
Jun 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
The ADF Konica Minolta causes paper jamp or may bend 1 corner of
check there are two locking claw for uper cover of adf one is broken check and replace if necessary
Apr 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Dell 962 Photo All-In-One InkJet Printer Logo
60 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
