Question about Ovens
MIDDLEBY MARSHALL PS636G OVEN SHOWING IGNITION LOCKOUT
WHEN I TURN THE OVEN ON IT WILL FIRE FOR 5 SEC AND THEN GOES TO IGN LOCKOUT I CAN UNPLUG IT AND EVENTUALLY IT WILL STAY LIT WHERE SHOULD I LOOK AT FIRST THE IGN BOX OR THE GWS PRESSURE
  • 139 Answers
SOURCE: Oven will not stay alight
You have aproblem with you ffd ( flamme faliure device which is located in the oven.. Or if your oven has a thermocouple that has gone. Yo need to replace either one of them depending which one you have in your oven
Posted on Nov 18, 2007
abhishek33
  • 1239 Answers
SOURCE: spark module clicks and gas will not stay lit, flame comes on but goes out
hi Clogged burners are a very common problem with gas ranges because foods spilled on the burners block the gas ports and prevent ignition. On some gas ranges you can remove the top ring of the burner to expose the ports. Here's how to clean a burner:
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
thank u.................
Posted on Sep 12, 2008
SOURCE: Middleby Marshall PS360 pizza oven won't maintain HEAT
I have a middleby marshall ps570 oven. The conveyor belt is moving too fast, I already try adjusting the timer control but it does not do any-good. I open the access panel I turn on the oven and started to work fine as soon as i close the panel it does it again the conveyor speeds up, Any body know what could be wrong.
Posted on Nov 30, 2009
heatman101
  • 43501 Answers
SOURCE: ignition not turning off once oven lit
It is normal for the ignitor to stay lit while the burner is going...There is nothing wrong there...
heatman101
Posted on Apr 09, 2010
  • 2468 Answers
SOURCE: DEBIG24SS Gas Single Oven: oven want stay on after you let loose of the ign...
replace the gas safety valve thermocouple,it has a thin coil of copper colored tubing going from the safety gas valve into the pilot light flame and as the flame heats the copper tube end it keeps the gas valve open to supply gas to the unit,they get old from being in a flame and cant signal the gas valve to stay open any longer,they just unscrew out of the gas valve and the opposite end is positioned in the tip of the pilot flame to heat it
Posted on May 20, 2010
Oven kicks on gas lights runs for 10 sec then beeps showing preheat is done then kicks off
I had to replace my igniter to get mine to work. I did it myself for $65.00 Mine the gas just would not stay on to heat up.
Mar 13, 2015 | Maytag Ovens
Middleby marshall conveyor motor speed
my conveyor motor is going fast and will not slow down, what is the fix for this?
Feb 02, 2012 | Ovens
Middleby Marshall 360 pizza conveyor oven is making clanking noise by circular fan grate in back bottom left of oven. Please help
Is it the rear of the oven or the left side?
  • Rear of the oven, it is a obstructed or malfunctioning axial fan. Replacement cost $10-$20 - 30 minutes labor
  • Left side of oven, possible main blower fan malfunctioning. Depending on type of motor "S" or "Q". It might be the mount or a bearing wearing out. Replacement motor $200-$400, motor shop rebuild instead $150. Squirrel cage will need to be removed if damaged $100-$300. Labor 2 hours, if you know what you are doing, 4 to 6 if this is your first time. Check your heat slinger also. This might have come loose.
Call me for parts or further info. I have been here before.......
Marcus Bramhall
Shimmmer LLC
318.202.2022
206.769.4466
Feb 17, 2011 | Ovens
Who makes the turbo chef oven?
According to the TurboChef commercial website (on the very bottom) it says they are a division of the Middleby Corporation.
TurboChef webpage: http://www.turbochef.com/commercial/
Middleby Corp webpage: http://www.middleby.com/ body { margin: 0 0 0 0; padding:0 0 0 0 }td,div { font-family:Tahoma;font-size:8pt;vertical-align:top }body { margin: 0 0 0 0; padding:0 0 0 0; overflow:hidden; }.transcript { background-color:#d2d2d2; }.messageBlock { margin-left:4px; margin-bottom:3px }.message { margin-left:100px; word-wrap:break-word; white-space:-moz-pre-wrap; _white-space:pre; }.messageCont { margin-left:100px; word-wrap:break-word; white-space:-moz-pre-wrap; _white-space:pre;}.other { overflow:hidden;color:#39577a;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; }.myself { overflow:hidden;color:#da8103;font-style:normal;font-weight:bold;font-style:normal;float:left; width:95px; }.otherCont { font-size:8px;text-align:right; color:#39577a;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; }.myselfCont { font-size:8px;text-align:right; color:#da8103;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; }.system { margin-left:4px; word-wrap:break-word;color:#da8103;font-style:normal;font-weight:normal; white-space:-moz-pre-wrap; _white-space:pre; }.showTimestamp { padding-left:8px; margin-right:3px; float:right; color:#999999;font-style:normal;font-weight:normal; }.other1 { color:#ac2000;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; }.otherCont1 { font-size:8px;text-align:right; color:#ac2000;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; }.other2 { color:#3c9fa8;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; }.otherCont2 { font-size:8px;text-align:right; color:#3c9fa8;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; }.other3 { color:#e25614;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; }.otherCont3 { font-size:8px;text-align:right; color:#e25614;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; }.other4 { color:#0b6ac8;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; }.otherCont4 { font-size:8px;text-align:right; color:#0b6ac8;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; }.other5 { color:#b23290;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; }.otherCont5 { font-size:8px;text-align:right; color:#b23290;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; }.other6 { color:#02e7c7;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; }.otherCont6 { font-size:8px;text-align:right; color:#02e7c7;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; }.other7 { color:#5b3284;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; }.otherCont7 { font-size:8px;text-align:right; color:#5b3284;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; }.highlight { background-color:#bed6f8; }.datestamp { cursor:default; margin-bottom:1px; background-color:#c0c0c0; width:100%; float:left; text-align:right; color:#ffffff; font-weight:bold; font-style:italic; }#chatAlert { float:left; border-bottom:1px solid #E8D091; padding:6px; width:100%; color:#A5754C; }#chatAlertImage { float:left; }#chatAlertText { float:left; margin-left:6px; }#chatAlertClose { float:right; margin-right:10px; padding-right:6px; margin-top:0px; }#chatAlertText a { color:#A5754C; }#chatAlertText a:hover { color:#A5754C; text-decoration:none; }.tsDisplay { display:block }.dsDisplay { display:none }
Dec 12, 2010 | TurboChef TORNADO Electric Oven
Ican't turn the oven on. When I press "Bake" it goes to LOC and then turns itself off. I should be able to adust the temperature (+ or -), then press start.
Hi
If it is a GE oven then you can try and reset the LOC error by pressing 9 and the 0 simultaneously for 5 seconds or until the LOC disappears. Alternatively you can try pressing the "Oven Lockout" or "Range Lockout" button on the control panel and then the "Start" button. Hope this helps... Please post back with make and model# of your Oven if you need more information.
Daniel
Nov 10, 2010 | Ovens
I have a Middleby Marshall Pizza Oven.igniter works but seems like no gas coming through ,tried poking a pin in the gas nozzles as we had that problem before where some **** blocked one of the holes but...
Need a qualified person to check gas control valve to determine proper voltage to the valve is supplied. If voltage is present, either the gas line is blocked to the pilot, or the valve has failed and needs to be replaced. Typically, the latter is probably the problem. If NO voltage is present when the unit "calls" for ignition, check for loose conections at the ignition control, and the gas control.
Jul 21, 2010 | Ovens
Cant turn it off, it seems to be locked?
hELLO THERE
On some of these ovens they have a internal reset device that needs to be reset and this is done by unplugging the oven and waiting for one hour then plugging it back in and waiting for 5 min befor you attempt to unlock it.
Now on some of the newer model ovens all you have to do is unplug wait 15 sec and plug it back in for 5 sec then repeat this step 3 times ok so please try these and let me know how this goes
Best regards Michael
Apr 26, 2010 | KitchenAid Architect Series KEBC107KSS...
sounds like the control cabinet overheated and the controller starts to break down at 140' F I would replace the controller and keep the cooling fans clean
Aug 06, 2009 | Ovens
My conveyor is not moving on my pizza oven any suggestions?? its a middleby marshall q360
These little motors are controlled by a rheostat for speed control, or electronic speed control. Follow wire from motor to control and check. Also; is chain on?
Jul 06, 2009 | Ovens
Oven will not light but broiler works. Ignition Module turns red when you turn on oven but no fire
there is a small bathtub shaped can that the gas line goes into under the broiler this releases the gas to the ignitor module replace it
Apr 21, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Ovens Logo
361 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
