Question about Electrolux Washing Machines
Electrolux washing machine spins too fast - Electrolux Washing Machines
the dr
  • 447 Answers
SOURCE: Kenmore Washing machine spins slow
If it has a speed selection switch than this switch is likely to be bad, other than that are you sure that It once has high spin in the cycle you are using??
Posted on Jan 15, 2008
Timon90
  • 126 Answers
SOURCE: Washer won't go into fast spin cycle
Check the motorbrushes. When the brushes get worn, the motor doesent get electricity to the communtator
Posted on Jan 27, 2008
kjmac
  • 97 Answers
SOURCE: Zanussi FC1200W
have you checked the filter behind the flap on the front of the machine, this could be blocked. if the machine is full of water though you will have to manually drain it by putting the grey outlet hose into a bucket or a washing up bowl. you will also need one or two towels to place on the floor because there wil still be a bit of water left in the ipes even though the drum is empty.
hope this helps
Posted on Jul 28, 2008
  • 113 Answers
SOURCE: Washing Machine doesn't spin fast enough
Most likely needs a new clutch. www.washermd.com dave
Posted on Jan 14, 2009
miket756
  • 2702 Answers
SOURCE: My Hotpoint WF860 will spin on rinse/spin load but not on a wash
no its the programer at fult
Posted on Oct 25, 2009
Electrolux EWF 1495 won't spin.
The belt could be stretched or the tension idler could be malfunctioning.
Feb 12, 2015 | Electrolux Washing Machines
Why wont my ewf 1080 electrolux spin
Most likely the washing machine is stuck in Hold mode. Check if you have the spin speed knob at the correct setting.
Manual is available from here
http://www.manualslib.com/manual/616814/Electrolux-Ewf-1080.html#manual
Check the parts and schematics at this site
http://spares.bigwarehouse.com.au/index.php?cPath=64689_77309_77544&sort=2a&page=1
Aug 29, 2014 | Electrolux Washing Machines
Electrolux front load washing machine ew10001 spin cycle slow on "SPIN" setting runs fine through regular wash setting? any ideas?
Hello jamespeattie - Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Jan 02, 2013 | Electrolux EW1000i Front Load Washer
My electrolux front load washer model number, EWFLW65HIWO, gets to the spin cycle and spins slowly. At minute 4, it stops, never entering the super fast spinning. However, if I put the washer on the Spin...
Sounds like the timer and control board are not communicating correctly and efficiently when in a normal cycle. You would need a professional to diagnose the control board and see if that is the only part needing replacement.
Dec 26, 2012 | Washing Machines
My electrolux washing machine is not spining anymore
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 06, 2011 | Electrolux Washing Machines
I have an electrolux washing machine model atfb6700 front loading bought in 2008 that does not spin. It will turn on the wash cycle but the motor buzzes in both cycles. Is it the motor or motor boards?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The motor is toasted...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 09, 2010 | Electrolux Washing Machines
How to reset my washing machine (electrolux)
my electrolux EWT606 will not spin. it drains and then just wont go into spin cycle....no error messages it just beeps. can anyone help me please as i have kids with disabilities and NEED to wash!
Mar 14, 2009 | Electrolux Washing Machines
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Washing Machines Logo
62 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
