Question about Whirlpool MH7140XF Microwave Oven
Whirlpool MH7140XFQ-1 microwave no longer heating
My Whirlpool microwave, Model # MH7140xfq-1, just quit heating. All the lights, push buttons, and turn table work but food no longer gets hot. MWO was purchased back in Jan 2001 and has been worked on as part of a recall several years back.
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
kggk
Posted on Sep 30, 2010
Whirlpool MH7140XFQ Fuse to Breaker Problem
There is absolutely no way to guess at the problem. You need to troubleshoot the circuitry with a meter to find the failing component
Oct 06, 2009 | Whirlpool MH7155XM Microwave Oven
MH7140XFQ Fuse Amp
you need to look at the ends on your fuse and this will tell you the amperage you need to get for your particular unit,get them from a hardware store
Sep 22, 2009 | Whirlpool MH7155XM Microwave Oven
I have a whirlpool model MH7140XFQ and we got a guy to come and look at it and he said the Mag. tube and the circuit bars were broken. Which would be more expensive to change the broken things or just...
He is referring to the magnatron tube which is the heart of the microwave. Probably more expense than you would want to put in to it.I would recommend replacement unless it is a high end model. Hope this helps
Jul 24, 2009 | Whirlpool MH7155XM Microwave Oven
Whirlpool MH7140XFQ-1 light does not switch from regular to night
If there are 2 bulbs try swapping them around. If the night light works then you just need a bulb. Take the bad one with you and match it up at a parts store. Some actually have a dimmer circuit programmed in the board and that will not be a easy fix. Do you hear a click when you try to activate the night mode? If you cannot find a bulb or do not want to replace or repair the unit just disclose the non working light. I was in real estate for a couple years and a burned out bulb will not be a deal breaker as long as they are told up front.
Eric
Jun 08, 2009 | Whirlpool MH7140XF Microwave Oven
Microwave not working
est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Dec 19, 2008 | Whirlpool MH7155XM Microwave Oven
Whirlpool MH7140XFQ
It's most likely caulk. It can usually be sliced with a razor blade.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 21, 2008 | Whirlpool MH7155XM Microwave Oven
Owner
Check the internal fuse. Unplug it, unscrew and take off the cover, the fuse should be easily found in the back by the power cord. It looks like a regular fuse but is white instead of clear glass because microwave fuses are special. You'll have to measure it with a meter as a result and be sure to replace it with the same kind. (try finding them at radio shack) Hopefully there isn't something more serious also.
Hope ya fix it!
Jan 09, 2008 | Microwave Ovens
Whirlpool MH7140XF Microwave Oven Logo
1,039 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
