Question about Garden
Programing instructions for a Batrow mini i-24
Programing instructions for a Batrow mini i-24 irrigation controller.
2 Suggested Answers
SOURCE: Instructions for garden watering system Hardie Irrigation
WIRES CONNECTION
Posted on Mar 08, 2010
I need instructions of Melnor 304F timer for watering
From the Melnor 304f actual instructions:
Use 9V alkaline batter only! Flashing lighs indicate that the battery is low and needs to be replaced.
1) To start: Turn Dial to Off position and press ENTER
2) Set Time: set the current time and press ENTER
3) Start Time: set the time to start the first irrigation cycle and press ENTER.
4) Frequency: Set the frequency of the irrigation cycle e.g. twice a day = 12h and press entere.
5) Duration: Set the duration of the first irrigation cycle and press ENTER.
-- to change the duration
Turn the dial to the new duration and press ENTER
--to turn the water on manually
Turn dial to ON position.. The water will turn off automatically after 30 minutes.
-- to turn the water OFF
Turn the dial to the OFF position
Do NOT press ENTER when dial is in OFF position, otherwise the unit will clear the program, and you have to Reprogram the unit following the steps 2 through 5.
Jun 29, 2014 | Flotec Garden
Controller will not respond to clock nor the manual setting
Remove batteries wait 10 min Clean battery terminals with metho
then try again sounds like corrission on battery terminals
Apr 03, 2014 | Garden
How to wire hunter rain clik rain sensor to r8816p101c
1) There are different rain clik model numbers shown in manual
Open 24 volt Rain clik manual:
http://www.hunterindustries.com/resources/pdfs/instructions/domestic/lit358w.pdf
http://waterheatertimer.org/pdf/Hunter-rain-clik-instruction-manual.pdf
2) The rain sensor has two wires.
And two additional wires are needed to run from rain sensor to sprinkler timer. For example, buy thermostat wire from local hardware store if wire is not supplied.
3) The rain sensor has a terminal block where wires are connected. .
Open manual above to identify markings on your terminal block.
For example Figure 1 shows SRC model, and with this model number, the rain sensor wires connect to terminals RS and C, and then two wires going to timer connect to terminals RS and and 1.
4) R8816P101C is 208-240Volt 24-hour irrigation timer.
Timer has two separate terminals for attaching rain sensor.
5) Timer power connections have 4 terminals. Do not connect rain sensor to power terminals.
Connect wires from sensor to the two sensor terminals.
6) Timer slide-switch must be set to ON position for rain sensor operation.
Sensor sends continuous 24Volts to irrigation timer.
When it rains, the rain sensor stops sending 24Volts to timer. Timer responds by not turning on power to irrigation pump.
To by-pass rain sensor, move timer slide-switch to off position.
7) Open following link for Intermatic replacement parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
8) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 05, 2011 | Intermatic R8816P101C -...
I cannot get the automatic watering program1 to work on my Philmac 6 station Dundee irrigation controller Stewart
Remove the backup battery.
Unplug the timer for 10 seconds, this will do a full electronic reset.
Try to reprogram "program 1".
If this doesn't work, "program 1" may be damaged internally in the controller.
If it is adequate, use "program 2".
Reinstall backup battery.
Gary
Jan 01, 2011 | Garden
The instruction manual got wet and I cannot read how to program the Orbit Watermaster 62015/91600. please advise
Assuming you have the four dock kind, here's the link to the pdf manual online. Otherwise, you can search their website for the correct manual.
http://www.orbit-irrigation.com/lib/media/62032-24ErE_001098.pdf
May 12, 2009 | Orbit 2-Dial Hose Faucet Control Timer...
Instructions on programming a Randall 102E controler on our central heating system please.
here's some links to some pdf files that can assist you
http://www.bhl.co.uk/uploads/article331/Danfoss_CP715.pdf
http://www.plumbnation.co.uk/site/danfoss-randall-102e5--24-hour-gp-mini-programmer/102E5%20Guide.pdf
Hope to be of assistance to you all,
Sincerly, alexander
Apr 29, 2008 | Heating & Cooling
Garden Logo
703 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
