Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Ct151 keeps reving and idle - Kohler CH25 PA-CH730-0040 Command Gasoline Engine
    Master:
  • 452 Answers
Check plug and clean and re gap also a clean filter will help some times mixture to rich dirty filter ,
The other thing u could o if filter and plug is ok adjust idle speed up till it runs smooth ,1 last thing adjust air screw turn both ways till it runs smooth
Posted on Oct 15, 2013
Why my oil pressure raises while idle, then falls when engine is reved
Likely electrical issue or bad fuel pump which draws excessive amps when reving up thus blowing fuse and creating drain on electrics making oil gauge reading drop.
Feb 10, 2015 | 1991 GMC Sierra
Kohler ride on mower ct151 not running smooth when idling it keeps revving every 2 seconds and dyes back again have cleaned plug and filter ???
Sounds like tick over speed is running to slow adjust till it runs smoothly,also u might like to adjust the air screw just a possibility also make a note how many turns u do just in case u go to far then u can put back as was
Oct 13, 2013 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Start up
You provided no info on the vehicle motor,so
I would assume you may have an Air Idle Solenoid
next to the throttle or on the intake manifold,that you
can remove & try cleaning or replace.
Jul 03, 2013 | GMC Sierra Cars & Trucks
My 426 doesnt idle smoothly. have to keep it reving to stop it stalling. have tried adjusting the idle screw, runs fine apart from the idle...
Replace Gold idle screw on the carb and then keep turning it clockwise till its revving high, Then slowly do it anti clockwise till its idling at a low RPM which you feel right or/and defined in the owners manual.
Aug 28, 2010 | 2001 Yamaha WR 426 F
My 400 ss is reving high when it is warmed up
First check entire length of throttle cable for kinks, crimping or binding. (especially near steering head) Check function of twist grip, it must rotate smoothly and spring back when released. Ensure choke is turned off after initial warm-up. If no change, turn out idle screw fully,(owner's manual refers) start bike and keep throttle at idle speed and screw in idle screw till it engages.
Apr 17, 2010 | 1992 Ducati 400 SS
Vespa T5 Mark 1 (1989) not idling
cleaned carb and the jet was blocked
Aug 03, 2009 | Peg Perego Vespa Scooter
Engine looseing reves when driving. reves above 8000rpm when idle
My engine light is on in my 199 ford explorer and I was told it is the o2 sensor 1 and 2 what does this mean?
Feb 18, 2009 | 2000 Volkswagen Passat 4Motion
1991 CR 500 (reving to high on idle high serges)
take some wd 40 & spray around the carb boot while running to see if the idle drops for a few seconds. sounds like you have an intake side air leak causing a lean condition making the motor rev high.
Feb 16, 2009 | 2001 Honda CR 500 R
Power/reving up issues
The engine has a rev limiter to keep from blowing engine up with too much rpms at idle.
Sep 10, 2008 | 1998 Mazda Protege
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
64 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
Craig Butler
Craig Butler
John Trevino
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
