Question about Liebherr CS2062 Bottom Freezer French Door Refrigerator
How to drop the front wheels on the refrigerator
I want to roll the refrigerator and can't seem to make the front wheels touch the floor. Do I need to lift the refrigerator and screw in the leveling legs? That seems impossible! Help
    Scholar:
  • 50 Answers
You should be able to remove the plastic grill at the front bottom of the frig exposing the leveling screws which you can adjust without moving the frig.
Posted on Oct 13, 2013
When I'm vacuuming it's very hard to push
There are many reasons, perhaps yours is one of these.
1) The carpet/bare floor selector.
This adjuster raises and lowers the front of the vacuum according to the depth of the carpet
. A thick carpet has the wheels dropped way down away from the front of the machine, a smooth floor or a very short pile carpet has the wheels up high , close to the front of the machine.
Having the selector set wrong can cause this problem.
2) Check to see if the front wheels are rolling freely.
If one or both are clogged with hair, carpet strands, string, etc., the vacuum can be hard to push.
God bless your efforts.
Jun 20, 2016 | Vacuums
How do i use the wheels on my maytag refrigerator model MBF2256HEW. They don't seem to lock in a down postion to roll
You probably need to turn the front leveling feet in so that they are higher than the wheels.
Jul 25, 2015 | Maytag Refrigerators
How do you lock the wheels on a maytag refrigerator
Hello Joyce;
My name is Peter. I am a retired field service technician.
You did not give me a model number so I am not sure what you have.
Remove the front bottom grill. Some grills have clips 1 on each end that you just pull to remove. Others have a screw on each end to remove.
1.) Some units have a locking bar on the outside of the front wheels. Turn this bar to lock.
2.) Some units have bars on each side with square heads. There are 2 bars on each side. One for the front wheel and one for the back wheel. You need a box wrench or ratchet. Clockwise raises the wheels and counter clockwise lowers the wheels.
3.) All units have leveling screws in the front. Turn the jack screws clockwise to bring them down. If you did not receive a special wrench with the unit, you will need either a pair of channel locks or another tool when the jack screws touch the floor. Turn the jack bolts 1/2 to 1 full turn. This will secure the refrigerator in your desired position.
I do not recommend 3.) unless your floor is pitched and your refrigerator tends to move. The leveling jack may leave impressions in you kitchen floor. Generally, just the heavy physical weight of your unit keeps the refrigerator in place.
Oct 29, 2014 | Refrigerators
CAN NOT LOCK THE WHEELS TO KEEP REFRIGERATOR FROM ROLLING
A refridgerator will roll forward and back you cant lock the wheels. If the floor slants that much you can take little peices of wood or carboard to place in front of the wheels so they dont roll.If you have anymore questions please comment me back so I can further assist.
Jul 28, 2011 | Kenmore Side by Side Refrigerator
Hi I just bought a whirlpool refrigerator and it rolls forward on opening the doors. Is there anyway to prevent this? It is on a wooden floor, Thank You Model NumberED5FVGXWS
At the bottom front of the refrigerator there are two feet. One on the left and one on the right. These need to be screwed down untill they touch the floor. Once they are touching the floor they should act as anchors stopping the fridge from moving
Mar 31, 2011 | Whirlpool Refrigerators
How do i remove the covering of the wheels to lock them. it is an lg refrigerator with bottom freezer
LG refergiators have floor stops that screw down to contact the floor to keep it from rolling when the doors are opened.
There is one stop on each side, In front of the front wheels.
You may need to remove the toe kick grille to see them.
Check your installation book or online @ www.lgusa.com
Jan 15, 2010 | LG LFX25960 Bottom Freezer French Door...
I need to level the refrigerator. The back needs
Hello Monty, If you can roll the fridge out, you'll likely see the adjustment screws for the rear wheels, (if equipped). If the rear wheels are fixed, as most are, you can put a couple of wooden shims down on the floor where the wheels will be and roll the fridge back into place and then make the leveling adjustments from the front wheels.
If the amount of height adjustment is greater than a half an inch, you can use a solid piece of plywood the width of the fridge and about 4-6" wide and place that at the back. Roll the fridge in until it hits the plywood and tilt the fridge forward about 2 inches and push it back until the rear wheels are on the plywood. You can then, again, level the fridge using the front wheel/leg levelers.
I've found that it's easier to get a good idea of just how much out of level the space is where the fridge is being placed. Then you can make the changes using the best materials for the situation. Shims are fine for small adjustments, while the full width plywood is more consistent and easier to adjust, as the fridge will likley get moved out every 6 months or so, for cleaning of the coils and behind the fridge.
Remember that ideally, you want the front of the fridge just slightly higher than the back, so the doors will close by themselves, when opened almost 90 degrees and released by hand. Gravity should then take over and automatically close the doors, ensuring a good seal to keep the fridge closed and running properly.
I hope you find this Very Helpful and best regards!
Dec 24, 2009 | Maytag MFI2568AE Side by Side French Door...
When I move the refrigerator is scratches my floor
All refrigerators have wheels, including yours.
There are also two "leveling" screws with rubber pads next to the front rollers.
Turn them clockwise (normal screw) to raise the pads so that the refrigerator is free top move around. The levelers are probably not required, so raise them up high.
I suppose that 99% of all refrigerators have the levelers raised....
Sep 28, 2009 | KitchenAid KFCS22EVMS Stainless Steel ...
I need to move my Kenmore fridge for floor installation
you have to raise the front by runnung the wheels down in the front with either a large screw driver ir a socket wrench the bolts are uvderneith the cover by the floor.
Apr 03, 2009 | Kenmore 65232
Door opens beyond position parellel to floor
Hi dougisommer
I'm Harvey the Master Plumber.
Your question is: The door springs seem fine but when we open the door and wheel out the lower dish rack, the door drops further and the rack rolls down to the floor. Reading other postings, it seems like a good name for this is a broken "door catcher." How can I fix this?
You may need a sevice tech for this. The 'door catchers' on the sides of the unit can only be accessed after removing. Not a job for the inexperienced.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Maytag 24 in. MDB4100 Built-in Dishwasher
Liebherr CS2062 Bottom Freezer French Door Refrigerator Logo
291 people viewed this question
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
