Question about Monroe 7130 Calculator
MONROE 7130 LOCK UP WHEN I PRESS THE PAPER ADVANCE. ALSO LOCKS UP WHEN I ADD WITH THE PRINTER ON. A E COMES ON ON THE LEFT SIDE OF THE SCREEN ALSO.
MY MONROE 7130 LOCKS UP WHEN I PUSH THE PAPER ADVANCE BOTTON.
    Problem Solver:
  • 5 Answers
We repaired many Monroe 7130...this could be logic problem..maybe something on the logic bd. ...coke , coffee, etc. etc. staple, paper clip.. but in all probably you may have a printer gone bad.. You can always shake your cal to see if you have dropped anything on the logic bd... but always turn your machine off before you do this...this problem has happened only once or twice..we would try a another printer unit and isolate if it was a logic or printer and go from there...good luck 608-222-2484
Posted on Nov 02, 2009
Paper keep jamming
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Dec 29, 2010 | HP Officejet 5510 All-In-One Thermal...
Put new ink in printer. got the message "carriage jam" checked ink to see if correctly installed...it was. tried to use it again and same message appeared. Did as was instructed on Kodak...
Dec 15, 2010 | Office Equipment & Supplies
Paper jam
Dec 07, 2010 | Office Equipment & Supplies
Printer carriage jam and then locks
Dec 07, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Paper Jam {Printer does not detect paper
Nov 18, 2010 | Office Equipment & Supplies
Piece of paper stuck inside my HP printer
Oct 21, 2010 | Office Equipment & Supplies
Settings
I bet your display is showing the correct ans, however your printer is printing incorrectly. Settings have nothing to do with your ans. You need your printer to be cleaned or have the printer replaced with a rebuilt unit. I can do this... 608-222-2484...
Oct 22, 2009 | Monroe 7130 Calculator
Monroe 7130 displays an "E" and I won't respond.
Even you turn off then turn on the calculator, the 'E' still there? As I know, when 'E' display, if any key is stuck (press the key and it never pop up), all other entries will be ignore, until u release the key stuck. And, please confirm the printer is not stuck.
Jul 13, 2009 | Monroe 7130 Calculator
Monroe Calculator 7130 - won't print red for negative
turn it off & back on & that should fix it. the ribbon lift needs to reset.
dennis
Nov 18, 2008 | Monroe 7130 Calculator
Monroe 7130 Calculator Logo
161 people viewed this question
Top Monroe Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Monroe Office Equipment and Supply Expert? Answer questions, earn points and help others
