Hp 764c will not power up - Computers & Internet
    Scholar:
  • 181 Answers
First check if your adapter is good. Most adapter has an LED indicator, then check your AC outlet. Be sure to firmly insert mthe plug of the adapter onto your laptop's power socket, most laptop do have an LED indicator. IF you haven't seen any lights, that means the adapter or the plug or the socket is bad.
Good luck
Tedmac
Posted on Oct 17, 2013
Stuck mother board hp pavilion 764c
Check to see if the ports themselves are screwed to the back panel of the case. I don't know about your specific model but usually if you get all the screws it should lift out no problem. Also, you should not need to remove any motherboard components to get at these screws, they should all be visible.
Feb 03, 2014 | HP Computers & Internet
Hp C7280 will not power up
Sir/Madam
It's Seem That Your HP Printer Power cord Is not Connected Properly,so I strongly suggest You Check Your Check Your Power Cord Is Connected Or Not If yes then May be Your switch is Not working Correct Or If No Then
Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
Reinsert the cartridges, and then close any open doors on the product.
If you receive a prompt to print a calibration page, do so.
Reconnect the USB cable to the rear of the product, and then try printing again.
Hope Your Power For HP Printer Solved By Now,If No Then Go To Below Link URL:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c02036357
I Hope Your Power For HP Printer Solved By Now After Click On Official HP Printer URL Link,
In Case You Still Have Problem Then Follow US On For
HP Printer Support
Jan 08, 2014 | HP Photosmart C7280 Printer
Hp pavilion 764c
not enough information........... what will it do? first thing i would check is the power supply... then remove the battery and try without the battery.
Oct 13, 2013 | Computers & Internet
How do i reattach an hp 764c pavillion heatsink using the two clamps. it became loose and trying to figure out how to reattach using the two clamps
The HP Pavilion 764c uses a Socket 478 processor socket.
One style is that there are two flat tabs, that protrude from the base of this processor socket.
View this type of Socket 478 more closely, without an Intel processor mounted in it,
http://en.wikipedia.org/wiki/Socket_478
You can click on the photo to the upper right to enlarge it.
I would like you to do so at this time.
Looking at the bottom of the photo, you will see a grayish tab that sticks out from the middle, of the white processor socket.
There is a tab on the opposite side also.
The clamping device goes across, and around, the middle of the Heatsink.
It should slide back, and forth a little bit.
At each end of this flat clamping device, is a rectangular slot.
The rectangular slots go over the tabs.
Styles vary as to how each clamping device is set up.
It could be that there is a lever on one side of the clamping device, and is tilted down to create slack in the clamping device, allowing the rectangular slots to go over the tabs.
There is usually a place for your thumb on the lever. The lever is pressed down, and to the outside.
Then the lever is brought back up to create tension on the clamping device. (The clamping device will hold onto the tabs, and push down on the heatsink)
It could be the opposite direction for the lever. The thumb place on the lever is brought up, to release the clamp.
Here's another style shown in a video,
http://www.youtube.com/watch?v=dSFOfAGjql0
If this information does not help you, come back in a Comment, and give me a description of your clamps.
Feb 14, 2010 | Computers & Internet
HP PSC 1410 All in one printer
Reset the HP All-in-OneFollow the steps below to reset the All-in-One.
  1. Turn off the HP All-in-One by pressing the Power or On/Resume button.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Plug the power cord back into the HP All-in-One.
  4. Turn on the HP All-in-One by pressing the Power or On/Resume button.
Nov 30, 2009 | HP PSC 1410v All-in-One Printer
My hp officejet 7410 all in one display only hp invent and not respond
Perform a power reset
  1. Press the On button to turn off the HP All-in-One.
  3. Unplug the power adapter from the wall outlet and wait for 30 seconds.
  4. Plug the power adapter back into the wall outlet.
  5. Plug the power cord to the back of the HP All-in-One.
  6. Press the On button to turn on the HP All-in-One.
Sep 25, 2009 | HP OfficeJet 7410 All-In-One InkJet...
6210 Stuck in self test mode
Perform the steps provided below.
  1. Unplug the power cord from the HP All-in-One.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while plugging in the power cord to the HP All-in-One.
  4. Release the buttons after the HP All-in-One starts up.
  5. The HP All-in-One will now be reset to factory defaults.
AFTER PERFORMING THE STEPS IF THE ISSUE PERSIST FOLLOW THE STEPS PROVIDED BELOW.
  1. Press the Power button, and turn off the HP All-in-One.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the HP All-in-One.
  4. Wait for 20 seconds.
  5. Plug the power cord into the wall outlet.
  6. Press and hold # and 6 while plugging the power cord back into the HP All-in-One.
  7. Turn on the All-in-One by pressing the Power button (c01150476.jpg ).
Aug 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
I have an HP pavilion 764c. Can the
Yes. Simply got to the manufacturer's site and look up the socket type for your motherboard. Expamples: AM2, 939, 734...
Once you've found your socket type, go to Newegg.com or another parts store and buy a processor of that type. You can also try real stores like Best Buy or CompUSA
Jun 27, 2009 | Computers & Internet
Hp pavilion 764c wire diagrams
Take a picture of the inside of your computer and put it up on the website with the wire connectors that need to be connected. The connecting wires should be in four groups. 1. The power supply connectors. These connectors will supply power to to all the power using components not supplied power by the motherboard itself. 2 The connections to the other components in your system like the dvd/cd player and the harddrive and floppy drive.3. The motherboard connections for the case. The power switch connector andreset switchconnector. The power led and theharddrive activity light.The USB connector and the audio connector.The fan connections like the cpu fan and other fan only connectors found on the motherboard.The external fans ( Fans that need to be connected to the power supply).Most of these connections are labeled on the motherboard. The case connectors also should be labeled for the correct connection. The best way to find the answers to this hook-up, may be to call HP pavilion with your computer make and model number,motherboard model number including revisions number. Computer made by big manufacturers tend to have may revisions and the only way to make sure your are getting a correct hook-up to the motherboard is call them for assistance.Especially if the motherboard and case labels are not present or so small that they cannot be read.Hope this helps you with your problem.
May 16, 2009 | HP Computers & Internet
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
