Canon IR-3570 i have problem in pannel touch
Canon IR-3570 i have problem in pannel touch screen , In the screen is coming just vertical lines,,but copier is working, i can't see anything in pannel
  • 26 Answers
Screens do become faulty over time, it could be a faulty connector/ribbon cable or the circuit board in the pannel
Posted on Oct 30, 2013
4 Suggested Answers
  • 7 Answers
SOURCE: Canon PC 745 Copier
not 8 it is an error code
please write other words
Posted on May 13, 2008
Cogz
  • 1326 Answers
SOURCE: Alignment of Tocuh Screen Panle of Canon Copier IR-6000/6001
I believe under the aditional funcation screen, you can calibrate the touch screen. Is the screen working at all? Does it look like there is Water on it and you can not wipe it OFF. If so, the display screen is cracked and needs to be replaced.
Posted on Apr 02, 2009
canontech
  • 1219 Answers
SOURCE: canon ir 3530
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Posted on May 04, 2010
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
MI COPIADORA CANON IR 3570 ME MARCA ERROR E002 ME PODRIAS DECIR POR FAVOR QUE ES ESE ERROR Y COMO LO SOLUCIONO GRACIAS
tengo una fotocopiadora canon ir 3570 y le cambie el cilindro y la cuchilla y ahora no me copia la imagen sale la hoja en blanco
Aug 22, 2011 | Canon ImageRUNNER 3570 Copier/Printer
I can't get my Canon ImageRunner 3570 to print in color, how do I get to that setting?
The Canon IR-3570 is a black and white copier, printer only, it's is not a color printer. sorry
Dec 25, 2009 | Canon ImageRUNNER 3570 Copier/Printer
Canon ImageRunner 3570 Touch Screen
you have to do it in service mode.
hit additional functions.....let go
hit the 2 and the 8 key together.... let go
hit additional function ......let go
then on the screen hit copier...
function
panel
touch check
this will put + on the screen touch the + in the 9 possitions it pots up in and then hit reset twice. if this doesnt align it you have to replace the screen.
Aug 11, 2009 | Canon imageRUNNER 3570 Copier
IR3570 error code E000602-0003, screen won't come on, won't copy or fax
this error is related to machine hardisk problem/failure,,It needs hardisk replacement with IR 3570 sytem software You need to contact your service provider to fix this problem
Jul 19, 2009 | Canon Office Equipment & Supplies
Faxing with the Canon 3570 Image Runner
On the copier display screen is their a tab that says "send"? If not then you do not have the fax option installed. If you have the machine on your network, find out the IP address assigned to the machine and enter the IP address in the address bar of your Internet Explorer browser to access the machine settings from your PC. If you have a fax option you should be able to set it up from there.
Printdoctor
Dec 17, 2008 | Canon imageRUNNER 3570 Copier
IR 5000 No Back illumination for touch panel
Most likely you will have to just replace the LCD display pannel or Touch Screen PCB. It does have a lamp, but I did not see a part number for it. You may be able to find a used or rebiult one on line and have a tech install it for you, to save your self some money..
Aug 27, 2008 | Canon imageRUNNER 5000 Copier
174 people viewed this question
jasbo
jasbo
