Question about Office Star Wood Bookcases: Bookcase/Etagere - HM127ES - Hampton Collection
I bought an Etagere Unit for our bathroom but the manual got damaged by water. The style # is TE012-P and the dpci # is 064-19-0008. Can I find the manual online somewhere?
  • Al Schlinksi
    Al Schlinksi Oct 13, 2013
    Forgot to mention this was bought at Target
Need assembly instructions for target threshold etagere
Contact manufacturer or return unit for another one with instructions.
Nov 22, 2015 | Dishwashers
Can I install laminated floor in my bathroom?
Laminated floors can be used in any room you would like although there are some laminated floors that are more sensitive to moisture. If you want to use laminated floor in your bathroom you will need to prevent water from core material of the floor.
Feb 06, 2013 | Building Materials
What is the most common type of bathroom vanity?
Cabinet style vanities are the most popular style. They are mounted on the floor, along a wall and have a mirror installed above. Here is what a typical cabinet style bathroom vanity looks like -
Sep 03, 2012 | Belle Foret Furniture
What are some of the styles to choose from in terms of bathroom vanities?
There are three main styles of bathroom vanities - shelf vanities, wall-mounted vanities and cabinet style vanities.
The humidifier is starting and running,but there is no water in the bucket
ayke, this can be caused by several things: The air intake filer is dirty and needs to be removed and cleaned. The humidity level on the unit is set too high and should be lowered to 35%. The air circulation around the unit is obstructed. There should be a minimum of 12" free air space all around the unit. The air temperature in the room is to low for the unit to operate properly. Most dehumidifiers will not work well between 40 and 60 degrees F.
To do an in home test, move the unit to the bathroom, and start it with the humidity level set at 35%. Turn the shower ON hot enough to generate steam. Do Not turn the bathrooms exhaust fan On and close in windows in the bathroom. As you exit the bathroom, close the door. Wait 15 to 20 minutes, before returning to the bathroom. Then open the door and turn the shower OFF. Allow the dehumidifier to continue run for 5 minutes, the check the water collection bucket for any signs of water. If you see any water, the bucket is working as it should.
If you don't find any water in the bucket, the humidity sensor may have failed and/or the compressor needs to be recharged with refrigerant gas.
Hope this helps you to troubleshoot and solve the problem.
May 26, 2011 | LG LHD45EL Dehumidifier
Bought a new samsung wave 3 weeks ago went to charge it would not switch on again left battery out for 1full day it then powered up used it for another day or 2 went to charge it same problem.went back to...
Check the water damage indicators on the phone and battery. They are white stickers, and they will turn red if they have gotten damp or wet. Be aware that some phones can get water damaged from condensation, or being in a moist environment like a bathroom.
If the damage indicators are clear, they cannot prove that it has damage and you should take it back and talk to someone else.
Mar 02, 2011 | Samsung Cell Phones
No hot water in sink and shower
it sounds like 1(or more) of the motorised valves arent working.find the valve and make sure you are getting power to it via a tester,if so then it probably needs the head on the motorised valve changed
May 04, 2010 | Rinnai Digital Remote Water Heater Control...
Bought a new toilet kit and had it installed but the water wont stop running into the tank and overflows out of the handle. Need help, Jerry
The float isn't closing the valve, which is adjustable, but there are many different styles of these. Who installed it? Can you call them back? Did they leave the packaging? I might be able to help if you can tell me the brand and model of the kit.
Feb 24, 2010 | Home
Where can I get assembly manual?
Return the item to Target as defective.
Dec 12, 2009 | Elite Home Fashions - - Bathroom...
Office Star Wood Bookcases: Bookcase/Etagere - HM127ES - Hampton Collection Logo
80 people viewed this question
Top Office Star Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you an Office Star Furniture Expert? Answer questions, earn points and help others
