Acer lapt top will not start in any mode.It says start in Launch startup repair or start windows normally. But will only go back to the same screen that says Launch startup repair or start windows normally. AND THAT IS ALL IT DOES. ANY SOLUTIONS.
You always want to start your windows normally.
In my 10 years as a computer technician I have learned that you never use the startup repair option cause it will never help.
Any more questions or concerns feel free to contact me Country Tech Repairs
It is most certainly a driver, but if you cant access the safe mode also that could be a hardware issue.. Try to troubleshoot with a windows installation cd. Put it in and boot the pc. It will start the windows instalation, you choose repair computer and not install windows. The command prompt will open, try to troubleshoot from there.. Thanks!
you just start your pc when it shows startup sreen press f8 and enter to safe mode in safe use the acer erecovery management software to recover your pc.
It smees your windows having some problem. It might crash.
try to boot the PC from CD, repair the windows. if it cannot repair, then better do fresh loading.
If it askes for a password try the password\
admin
and then press enter If this does not help try f8 safe mode
if that fails get the operating system CD or the recovery CD that belong with the macking.
After theis by a backup and hid it from everyone that wants to use it/...
When you boot up start pressing F8 and you should get a Windows startup page with more options. If you do select Safe Mode
When windows has loaded, goto MSConfig and select Diagnostic Startup. Ok and reboot
See if windows boots normally.
You should go into the safe mode and try to uninstall or undo the previous work. Else use the system restore. But if it continues again with a blue screen error, then u should format ur pc, further if u experience blue screen error then u should note that one of ur hardware is damaged.
Try to boot in safe mode.
From a cold boot, hit f8 till it gives you several options including "safe mode". Do that and if you can boot to windows let it do it's stuff before restarting normally.
Good luck
Same problem....
where can l get a o/s disk from
