Question about Amana Washing Machines
Amana SofSound / Commercial Quality Washer 5 Speed Combination - 3 Speed Motor - 13 Cycles - Stainless Steel Tub. The washing machine will fill up with water but will not spin or drain.
3 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: Water Won't Drain from Washing Machine
Hello phylislw61,
If you had an incident where a pillow broke and feathers where dispersed throughout the washer..then there is a good chance that teh drain fiilter screen, pump or hose feeding the pump is clogged. I would verify that the filter is free from anything that would limit water flow from getting to the pump.. then if the problem is still there.. examine the pump itself to make sure it isn't clogged...
If you or someone in your family is reasonably handy, here is a link to your washing machines exploded view and parts and this should provide sufficient information for how to access the pump and associated hoses etc that feed into and out of it for cleaning..
If you are having problems after you verify the lines are free of restriction, feel free to contact me and I will try to assist you in solving your problem.. Here is the link..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Posted on Dec 06, 2008
ginko
  • 19396 Answers
SOURCE: Hello there! I appreciate
Hi.
There are two possible reasons for your problem.
1) The water is flowing back from drain or is not completely drained out because of a drain system problem.
The first action will consist in checking the drain hose at the back. Make sure that the hose height is as specified by manual, or you get the so-called siphoning problem, with water flowing back from drain hose into the tub. Try running a cycle with the drain hose down in a bucket on the floor. If clothes are dry the problem was the drain hose
If possibly try also checking the drain filter accessible from lower front bottom of your washing machine. Please be aware that to check the pump the machine must be lifted and checking drain pump may raise safety issue. Power must be disconnected before performing any maintenance. You can leave this for last. The pump represented below and the hose to pump represented as part 18 in diagram must be tested.
Pump:
Diagram 1. Click on picture to enlarge:
2) The sensor that detects water level is defective and drain part of the cycle stops before drain is complete.
The part that detects water level is called pressure switch. The pressure switch looks like a plastic disk with 4 contacts connected to a long thin rubber hose that goes inside the tub. Before replacing the switch an attempt to correct the problem can be done cleaning the pressure hose connected to the switch. If that does not fix the problem and if the problem is not drain blockage or pump malfunction, replace the pressure switch. The pressure switch is part 4 in diagram below . The switch is reached taking apart the top control panel held by screws at the back. Here the part: (Pressure Switch)
Here Diag.2, click on the picture to enlarge.
Here a page explaining more about drain problems.
If you need parts or schematics see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Here all parts for your washer: ALW880QAW Parts List.
Regards.
Ginko
Posted on Sep 21, 2011
What is the cubic feet capacity for Amana washer Model lwa60aw?
According to the service manual, the LWA60AW top-load washer has a 3.3 cu. ft. capacity stainless steel wash tub.
I hope this helps.
Oct 24, 2016 | Amana Washing Machines
How to change belt on Amana SofSound 1 commercial quality washer
You call a technician. This is something that probably shouldn't be instructed in just text.
Nov 14, 2012 | Washing Machines
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
My Amana sofsound dishwasher is not draining
When you open the washing machine lid and discover it full of water, it means it didn't drain before the spin cycle.
You may be confronted with a tub full of sopping wet clothes at an inconvenient time, but don't panic and call a repairman.
Chances are the trouble is with the drain hose or the pump and you can fix it yourself with just a few simple tools.
Difficulty: Moderately Challenging INSTRUCTION BELOW.
  1. 1 Look at the drain hose to make sure it isn't kinked or clogged. If there is a piece of clothing lodged in there, clear away the hose from the pump and yank the clothing out.
  2. 2 Take a look at the switch under the lid of the washing machine. If it doesn't click when you press it, it may be broken and the washer may stop during the drain cycle. Call a repairman to repair or replace the switch.
  3. 3 Examine the clothes tub and the outer tub of the washer for anything that may be stuck in there.
  4. 4 Open the main access panel of the washer and take out the large rubber hose connecting the pump to the lower part of the outer tub.
  5. 5 Check to see if there is a piece of clothing stuck in there. If so, use a pair of needle-nose pliers to grab the clothing and pull it through the port. If it is difficult to reach, you will need to take out the agitator, the top part of the outer cylinder, and the interior tub to grab it. Unless you have special skills and tools, you may want to call a repairman.
  6. 6 Inspect the pump for a clog or frozen pulley. To check if the pulley is broken or frozen, take the pump out and attempt to turn it manually with your hands. If it's stiff or appears frozen, install a new pump.
Thanks for visiting .
Oct 23, 2010 | Amana 24 in. ADB1500AWS Stainless Steel...
My Amana sofsound dishwasher is not draining.
When you open the washing machine lid and discover it full of water, it means it didn't drain before the spin cycle. You may be confronted with a tub full of sopping wet clothes at an inconvenient time, but don't panic and call a repairman. Chances are the trouble is with the drain hose or the pump and you can fix it yourself with just a few simple tools.
THANKS.
Whirlpool washer does not start after fill with water
It sounds like the washer tub is off balanced. When it is, it will usually not start. Underneath the washer, there are 3 or 4 bolts or nuts, depending on your washer model, that hold the washer to these balance springs. make sure that the bolts or nuts are tight or secure. If this doesn't help, get on a website called Repairclinic.com. They usually will help with home repairs.
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not go into high speed spin
could be door switch if machine control bd does not sense door locked will never go to spin also could be main control under console look for scorched or burnt componets on bd
Dec 16, 2008 | Maytag Neptune Washer
Washing Machines Logo
142 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
