Question about Music
Up date my credit card expiration date on my I-Pass
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Music Master
  • 102,366 Answers
Log in to your I-Pass account and select "Manage My I-Pass Account."
Posted on Oct 13, 2013
Need schematic for peavey max 115-chi-imp-120v bass amp serial # 0dajk050437
http://www.peavey.com/support/searchmanuals/
Owner's manuals and spec sheets that are not available on our web site may be obtained by mail (via money order) or by phone (via credit card). Spec sheets and schematics are $2.50 per copy, and owner's manuals are $7.50 (paperback) and $20 (notebook).
Send Money Order to:
Peavey Electronics Parts Department
PO Box 2898
Meridian, MS 39302
Credit Card orders by phone:
1-877-732-8391
Sep 24, 2017 | Peavey Music
Some keys wont work
Your keyboard has a factory defect. Return it to the store or manufacturer and let them give you a new one.
If you waited to long and your warranty has expired take it to a repair shop. There is nothing else you can do...
Jun 13, 2014 | Korg Pa50 Professional Arranger Keyboard...
How do I replace one key?
You will need to gain access to the keybed, remove screw from back of keybed the fix it to the base of the keyboard. Slide the keybed back making a gap of about 2cm at the front of the keybed.
Look at the back of the key towards where it pivots and you will see a small arrow, push something like a credit card between the keys at this point and the key will pop up, you can then slide forward releasing the key.
If you need more info please ask.
Jun 07, 2014 | Yamaha YDP-161 Arius Graded Hammer Piano...
Pa50 factoty date rest
Here is a link to your manual, it should tell you how to do a factory reset somewhere in it. Hope this helps.
http://www.korg.com/uploads/Support/Pa50SD-UM-ENG_634618903911880000.pdf
Nov 27, 2013 | Korg Pa50 Professional Arranger Keyboard...
Just ran out of card space in my unit and I still have songs that need completition and I cannot pass it to my computer CARD IS FULL that is the message that I get what do I do?
You should be able to remove the card and plug it into your computer... you might need an adapter.
Other than deleting to get space on the card there is not much else you can do. Replace card with larger... it can go to 32Gb. Remember to format a new card beforoe use.
May 24, 2011 | Tascam DP 008 Digital Portastudio
Hello, i am from Greece and i represent one young and famous Greek singer.We use the psm 900 on stage and the batteries need to be replaced within one hour from the first use.So, we need to do this 2-3...
Shure's spec is that you should get 5 to 7 hours of CONTINUOUS use. There is OBVIOUSLY a problem.
First thing to check is what brand batteries you are using... some cheap ones from "C" have only a fraction of the energy content as name brand ones.
Second thing is expiration date on the batteries.
Next is to check the current drain of the bodypack with aa meter and compare to the specs for the battery. A good AA should deliver 2000 maHr.
The last thing is to realize that you CANNOT use rechargeable batteries in these devices. The rechargeables have a lower voltage and the circuitry will cut off MUCH earlier than with alkaline batteries. I would expect rechargeables to fail within 1 to 1.5 hours in this unit. As the rechargeables age, it would become much worse.
Mar 04, 2011 | Shure PSM 900 Bodypack Receiver
Ydp 223 some keys are starting to stick to on the downstroke when not struck with a perfectly vertical stroke. varying degrees of affliction. instrument 2 years old thanks for any help
Yamaha keyboards can be prone to sticking keys due to the rear part of the key cracking around the return spring - if this is the case the only solution is replacing the affected key modules. However this problem generally only occurs with long term use by very physical players.
Otherwise the problem may be caused by a build up of dust / fluff between adjacent keys - try raking out the spaces with a thin piece of fairly rigid plastic (maybe a credit card might work?)
Feb 24, 2011 | Yamaha YDP223 Digital Piano
Where is the thermal fuse located on the Follow Spot?
Follow the wires internally. Close to the lamp you will find part of the wire that looks covered in another shield or wrap. Usually the thermal fuse is soldered in-line there. Chauvet will supply parts directly. Per their website: Call our Customer Service Department at 800.762.1084 (press #4). Tell us what part you need, we will give you the part?s cost plus shipping. Then we request your credit card information, charge your credit card, place the order, and ship out the part to you. Hope this helps, Dan
May 19, 2010 | Chauvet Followspot 400g with Stand
Looking for a replacement volume control module for psr e303
You can obtain these from Yamaha Music Spares Dept in your country.
Go to the following Yamaha site link and choose your country
http://www.yamaha.com/
Select Musical Instruments - Support and the contact details will be displayed.
I just used them to by some parts for a Clavinova and they were in stock, accepted credit cards and delivered within 24 hours.
Oct 18, 2009 | Yamaha Full-Size Keyboard
Music Logo
95 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
