Question about Wharfedale Audio Players & Recorders
Wharfedale sys 44 put 2 speaker wires together now not working
  • 186 Answers
See if you blew a fuse in your amplifier
Posted on Oct 16, 2013
I think I might have blown my front speakers....they come on sometimes n other times they don't....idk where the fuse might be or if I jus need to replace the speakers all together....not sure and need...
speakers dont have fuses door speakers quite often develop this fault and it is common for the wires to break between the car body and the door to test put on the radio open the door and work the wires up and down the wires will be in a rubber sheath
May 30, 2011 | AudioTrak MAYA 44 USB External Sound...
I just brought some wharfedale one-three speakers and have them hooked up as the rear speakers. Can i get the sub to play still and do i hook the speaker wires in the top or bottom?
Do you mean "Modus 13"?
See picture 6...
http://www.freeads.co.uk/uk/av/audio/hi-fi/speakers/8402337/wharfedale-modus-one-three-speakers-black-rare-bi-wire-quality/view
Put the jumpers back in as shown. Hook your speaker leads to either top or bottom. The entire array of drivers will be active.
Make your receiver aware they are LARGE for the purposes of bass reproduction so some bass will get out to them. FYI, many AVR's will only allow Large Rear speaker selection if you also have Large Fronts. Refer to the manual(s).
Mar 07, 2011 | Wharfedale Diamond 8.4 Main / Stereo...
Can't get wharfedale melton 2 tweeter to work. Looked inside cabinet and need advice on internal wiring please. These are very old but one works perfectly and the 12'' bass driver on the problem speaker is...
The tweeter has burned out and cannot be salvaged. I also own a pair of (ex) Melton 2s. In the beginning Wharfedale were good at supplying spares (see www.wharfedale.co.uk for contact info and advice). A few years ago after my cat destroyed the 12 inch unit in one, i invested in new insides, including state of the art 12 inch woofers, 4 inch mid range and 1inch tweeters with a good 3 way crossover. The cabinet is great so consider asking a techie friend to do this for you. Please don't just cut out and connect to amp speaker wires! You will get terrible sound and risk ruining both amp and speakers! Best regards Karl (karl@simpson.nom.fr)
May 12, 2010 | Audio Players & Recorders
I have 1 set of wharfedale speakers valdus 400 .power handling (programme) 150W .normal impedance 4-8ohms.1 of the tweeter is not working .please advise how to repair asap ,thanks
you should first try if the driver is really gone or not, maybe it's just a wiring problem, also there can be something wrong with the cross-over network. Check the tweeter with a multimeter, if you don't see something between 2-16 ohms, you need a new one (or two, you probably won't be able to find the original part, so you'll have to change both left and right channel drivers) but if you see the desired impedance on the meter, check the internal wiring, crossover solder joints, capacitors, etc. I hope this helps.
Jan 03, 2010 | Wharfedale Valdus 400 Speaker
Wharfedale Valdus 400 Speakers
Yes, you can easily check it by removing it and swapping it with your other one. If the one from the second cabinet works, then the speaker itself has died. If not, either the wiring is the problem, or the crossover in the cabinet. If you take the first speaker that wasn't working, and put it in the second cabinet and it works, then likely it's your crossover. Please rate my answer, thanks.
May 28, 2009 | Wharfedale Valdus 400 Speaker
Speaker connection from Denon AVR 2105 to Wharfedale suround
The spkrs sound like they are bi-amp spkrs, meaning you have multiple terminals on the backs of each spkr, the jumpers on the spkrs should be connected as such. Now you just connect the spkrs according to the Denon spkr conection diagram. Do not use the surround back unless you have 6 or 7 pair of spkrs
Jan 27, 2009 | Denon AVR-2105 Receiver
Wharfedale Modus One
The tweeters are probably blown, i had the same problem.
You can test this by placing the cable on the dismanteled crossover at the back of the speaker. colour blue/yellow.
No high volume please.
See http://www.hometheatershack.com/forums/diy-speakers/4549-wharfedale-modus-one-six-crossover-pics.html
for pictures.
If the tweeter is blown it can be dismanteld with the aid of a screwdriver, horizontally.
Place it between the tweeterbowl and the ring which has the mark wharfedale on it. The tweeter comes loose. On second hand sites you can buy little speakers, like modus one or two's with the same tweeters for a good price and put them on your larger speakers.
This how i repaired 2 of my 4 modus eights.
good luck Danny Mol
the netherlands
Jan 15, 2008 | Wharfedale Modus One-Six Speaker
Wharfedale dvdr24hd160
have you try a multy scarts socket , available in many stores , argos , currys, dixson ?
Jan 07, 2008 | Wharfedale DVD-M3 DVD Player
59 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
jason
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
