Vaio vpc ef44fx service manual - Computers & Internet
Num lock light is on scroll is working but num lock is not working
Key failure - replace the keyboard - did you spill water on it?
May 13, 2014 | Sony VAIO VPC-EF44FX/BI Laptop
Sony VAIO L Series VPC-L222FX/B ti tv
There is a useful guide to do this at
http://www.instructables.com/id/Use-an-LCD-Monitor-as-a-TV-without-a-Computer/
Feb 23, 2014 | Sony VAIO L Series VPC-L222FX/B - Core i3...
Black screen on sony vaio vpcef44fx
You need to go to your CMOS setup, I think that you lost the primary default boot drive. it should be set to your HD and not to a usb drive or a cd rom or any other device.
I am assuming that you do not get the "Starting windows" screen.
Tony
Feb 09, 2013 | Sony VAIO VPC-EF44FX/BI Laptop
DOWNLOAD BLUETOOTH DRIVER
you can get all drivers from HERE but i believe no blue tooth drivers are listed there
Feb 04, 2013 | Sony VAIO VPC-EF44FX/BI Laptop
I can connect to the internet from my home network. But It will not connect to public connections or other peoples private connections, I have the passwords and permission to connect to these networks....
Check to be sure that your hardware is compatible with there network configuration ie: If you have wireless G you can connect to any network that is broadcast on G or B but they may be Using Wireless N in which case you cannot connect to that network also be sure your network setting are set to auto scan for a compatible Channel if you have it set to a particular channel it will only connect on networks that broadcast on that channel.
Thumbs up if helpful!!!
If so Inclined Feedback is appreciated!!
Good Luck!!!
Jun 13, 2011 | Sony VAIO VPC-EF44FX/BI Laptop
Is there a way to adjust the sony vaio vpc-f13ufx touchpad sensitivity?
go to control panel then mouse then pointer options and set the pointer speed slowed then it already is.
May 12, 2011 | Sony VAIO VPC-F13UFX/H 16.4-Inch...
How to remove the keyboard?
Remove all of the screws on the bottom, as well as the RAM, hard drive, and CD/DVD drive. Then, while the laptop is open, lift up the upper plastic covering on the bottom (you might need a key to get in there) from here, you should be able to see the keyboard mounting screws, make sure you remove the keyboard cable from the motherboard as you remove the keyboard.
May 04, 2011 | Sony VAIO VPC-CW17FX/W PC Notebook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
