Question about Buffalo Tools Sportsman GEN7000LP Portable Propane Generator W/Electric Start
My portable generator runs great but only produces 7 volts and 20 volts on each 110 volt receptacle and 20 volts on the 220 volt receptacle. any ideas on troubleshooting steps to find the problem part?
    Prodigy:
    An expert who has answered 500 questions.
  • Buffalo Tools Expert
  • 573 Answers
Assuming the speed is correct check the voltage on the rotor brushes during running (Caution) It should be DC. If you have low or no DC voltage then the capacitor in the end of the generator housing is bad, or the AVR. If you do have voltage then make sure the slip rings are clean and shiny, from there you may have a rotor or stator issue that needs carefull resisitance check
Posted on Nov 17, 2013
2 Suggested Answers
bozcro
  • 867 Answers
SOURCE: buffalo tools 4,000 watt generator
wow, that is high, i would think voltage regulator is faulty also
Posted on Aug 17, 2009
Miller trailblazer 302 it has 110 volts but no 220 volts
Both sets of the 120? If both of those are there (all 4 outlets), then the machine is producing 220v. So get a flashlight and look into the holes on the 220 receptacle, or check the wires on the backside of the receptacle. All that 220 is, is two 120 volts out of phase.
Feb 19, 2015 | Miller Trailblazer 302 Welder Generator...
Hi, I recently purchased a used makita 6100r generator and when checking it out I discovered on my 30 amp 220 receptacles arent getting full power. I took out the receptacle and checked the wires in back...
You may be asking too much of the unit; the 5800 watts a which it is spec'd, may be a 'peak' power rating which may be 15-20% higher than its continuous rating. 30 Amps at 220 volts implies 6600 watts which is higher than even the peak power rating. I would expect the unit to produce ~4800 watts continuous or around 22 Amps.
Decided to check my statements and found this, which I quote:
Generator Volts AC (60Hz) 120/240 Max. Output Current 5800W-48.3A/24.2A Rated Output Current 4800W-40A/20A Volts DC (AMPS) 12 (8.3)
Aug 28, 2011 | Makita G6100R 5800 Watt Generator
The generator produce onely 73 volts ac on the 120 volts plug and 146 volts ac on the 220 volts plug . what could be causing this problem
Check all wiring and fuses associated with you voltage regulator if they check ok, find a way to adjust your voltage regulator replace it. Make sure the unit is running at 3600 rpm as well and making 60 hz.
Jul 10, 2011 | Coleman Powermate Premium Plus 6250W...
I have a PC 6500 watts generator. The 120 volt receptacle is already occupied. I have an appliance120volt/30 amps that has a 10/3 cord and is furnished with a standard 3 pin twist plug. How can I used...
How many amps is the 120/240 volt circuit? I can tell you how to split it into two 120 volt circuits. A twist loc cord end, a piece of four conductor cord, two electric boxes, two receptacles would be needed.
How many amps?
Nov 12, 2017 | Porter Cable 6,500 Watt Contractor...
I have a coleman powermate 6250 generator with a 4prong 220v female plug on the power panel. My travel trailer has a 3 prong male plug. How can I convert my generator or is there an adapter that I can...
You do not want to convert anything to a 220 v connection !!!! Your RV is 12 volt DC and 120 volt AC.
Use a 30amp female to 15 amp male adapter to plug in to regular household receptacle on generator. Available at hardware store and RV stores.
Apr 27, 2011 | Coleman Powermate Premium Plus 6250W...
I have a Briggs and Stratton 5500 watt Generator 30241, I live overseas and I use 220 volts 50hz. How can I adjust the generator to run on this voltage.
Hello, I would not advise you to adjust the speed without a frequency meter. for 220 volt operation, you will have to use the twist - lock receptacles and not use the neutral in the receptacle. This means one of the generator's hot leads is going to be the neutral in your system. The frame of the generator may be connected to the neutral of the generator, so be careful so that you do not receive an electrical shock. The voltage is adjusted within the receptacle box. There might be a small hole on the right side of the receptacle box that you can insert a small blade screwdriver into to make the voltage adjustment. You do not need to change this much to change the voltage. Now, the frequency is adjusted by a self-locking nut located under the air cleaner right side, when facing the engine. There is a spring on this nut / bolt assembly. I think it is a 5/16 nutdriver or socket that you need for this. Turn counter clockwise 1/8 of a turn. This will slow down the generator to about 50 - 55 hz. This is okay if you are running at around 52 hz. As the generator loads, the rpm will drop down. A frequency meter would be great to use here, as a too low rpm could burn out electrical motors and other equipment that you are using. Feel free to contact me joeleier@gmail.com www.freelancemissions.com
Jan 22, 2011 | Briggs & Stratton Power Products 5,550...
Coleman powermate 4000 pops circuit breaker on the 220 side.
Don't know what you mean by "on the 220 side".
The generator has two joined circuit breakers that each are 110 volts. Between the two is 220.
If just one of those is opening WITH NOTHING PLUGGED IN, then there are only a few explanations.
1. There is a short in the wiring or the wiring has been tampered with and connected incorrectely.
2. The switch that switches the mode from 120 to 240 has gone bad, possibly with a welded contact. This would occur if the switch is changed with load on the generator. This could put a driect short on half the generator winding and cause one of the breakers to blow.
3. Worst is a winding short in the generator. Fortunately this is the least likely.
4. The 220 receptacle has been broken and insulation failed shorting one terminal to another.
Nov 14, 2009 | Coleman Powermate Premium Plus 6250W...
Runs great but will not produce electricity
To flash the excitor circuit on a coleman ( the generator is built by generac) you need a 12 volt battery. You quickly apply 12 volts via your 120vac recepticals. NO MORE THAN ONE OR TWO SECONDS! Then check you ac voltage. Most of the time the brushes are burnt up when voltage is low. Check the brushes first. You can access them by taking the end cap off of the generator via two to four screws. The brush holder is easy to spot, two wires leading to the front of the amature. Hope this solves your problem.
Mar 29, 2009 | Coleman Powermate Premium Plus 6250W...
Generator plugs doesn't match cord
Hey steve. do you really need 240 volts for 120 v. circuits. the reason you have to have an adaptor plug is because on your 220 volt plug in , 2 of tthose prongs are hot and 1 is ground. for safety you need to get a plug adapter ( a regular 120 volt plug end ) run a ground from adapter to ground on 220 adapter. same with nuetral. you also need to ground your generator. there is usaully a ground lug on the bottom of the gen. Another way. if you dont really need 220 v. is to use both 120v. recepticals on gen. Run 2 chords to tranf. switch. and hard wire it in to switch. another way i did mine . when i lost power in this hurricane. i ran two # 10 chords from my 2 120v. recept on my gen to my breaker panel. when you do this you have to pull the service meter, if you dont when power comes back on it would backfeed through your gen.then i turn all my 220v. breakers i was able to run lights ,ciling fans, freezer, ice box,washing machine and gas dryer , tv's computors etc. . but to do this, you probably need someone that knows what they are doin.
Sep 18, 2008 | Coleman Powermate Premium Plus 6250W...
The power is out because of Hurricane Gustav. I have a 6500 watt portable generator and would like to use our clothes dryer which has a 220 volt requirement. Is that possible, and is there a special...
Dryers require a 40A circuit breaker to handle the current. According to Ohms Law: Watts = Volts * Amps. Therefore, you require a power capacity of 220V * 40A in order to safely run the dryer, which is 8800 Watts. This means your generator does not have enough capacity to run the dryer. If we consider the full power of your generator at 6500 Watts, this only allows for 29.5A, which is not enough to run your dryer.
If it WAS possible, you would need to ensure that you ran a 30A heavy extension cord with the correct 220V plugs and receptacles on the end. This would require at least 10gauge 3-conductor wire, which is quite expensive.
However, that point is moot, since your generator does not have the capacity to run your dryer. You could try it, but I rather suspect that the dryer will trip the 30A breaker on the genset circuit. If you do try it, make sure you run a 10-gauge, 30A extension cord or you could have a fire.
Sep 06, 2008 | Dryers
Buffalo Tools Sportsman GEN7000LP Portable Propane Generator W/Electric Start Logo
158 people viewed this question
Top Buffalo Tools Electrical Supplies Experts
bob walter
bob walter
Level 1 Expert
Bill Boyd
Are you a Buffalo Tools Electrical Supply Expert? Answer questions, earn points and help others
