Question about Coffee Makers & Espresso Machines
My cuisinart cod-6000sa will not cycle water thru itself and won't make coffee. The blue light comes on when button is pushed but nothing happens beyond that. tank heater heats up but no water is pumped thru the unit.
SOURCE: No water is being pumped at all
I got through to the tech support at Breville and they helped me fix this problem. What they had me do was:
1)Fill the water tank all the way up
2)Turn the power on and wait until the heating light turns off.
3)without coffee in the head turn the machine to espresso mode and let it pump for a minute.
4)after a minute turn to standby for a couple seconds then turn it to steam mode for a minute.
5) after this minute is up turn it back to standby for a couple of seconds and then back to espresso mode.
6) the technician said to do this seven times, but mine started working after three or so. The tech said the fixes about 80 to 90 percent of machines with this problem.
Good Luck!
Posted on Dec 26, 2007
SOURCE: water light can't be reset
The gray magnetic float can sometimes get jammed. Check to see if it floats back up when adding water. If not, remove cap, reset magnet so it can move freely and replace cap, be sure the magnet floats to the top of its contained space when water is added. The system should then reset.
Posted on Aug 05, 2009
VtToolMan
  • 704 Answers
SOURCE: how to clean my cuisinart coffee maker - (can't
Here's a link to Cuisinart where you can download a free copy of your user's manual. Just download and print a copy for your use and future reference. It contains all the info about your unit and how to use the cleaning function.
http://www.cuisinart.com/share/pdf/manuals/dcc-2200.pdf
Hope you found this very helpful and best regards!
Posted on Aug 07, 2009
  • 21 Answers
SOURCE: Machine stopped working and both buttons are
May be busted, but before you take it to the shop try these few things. 1. Unplug machine for 30 seconds 2. Then plug back in, (lights should still be blinking) Take silver handle that you lift when you put in coffee pods and gently push back handle as far as you can for 3 seconds. This should reset your machine,back to factory settings. To then reset coffee cup settings to your personal taste by: 3. You can adjust the fill of coffee by holding the large coffee cup down for as long as you want to fill it. Try holding the button down for 20secs., next cup of coffee should automatically fill for 20 seconds. Do the same for small coffee side. Hope this works,it has for me; just not sure because of the cold water pumping out issue. good luck
Posted on Nov 12, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: does not brew coffee consistencty,
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Posted on Dec 22, 2010
Clean instructions
I presume you are requesting instructions for cleaning this coffeemaker...
With the coffeemaker off (either a red blinking light or no light on), pour four cups of pure white vinegar (no water added) into the reservoir. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
After the cleaning cycle has completed, get rid of the vinegar. Rinse out the strainer basket and the coffee pot. Run a full pot of clean water thru a regular brew cycle (with the pot and basket in place, of course). Then, dump the water, rinse the pot and basket again, and run another full pot of clean water thru a regular brew cycle. Dump that water too. And, you're done!
Sep 30, 2013 | Mr. Coffee JWX27 12-Cup Coffee Maker
Cuisinart dcc 3000..set to self clean and nothing is happening? Both the cleaning light and power light are on. How long does the cleaning process take or is there something wrong with the coffee maker.
Press the "CLEAN" button and it will light up red. Then press the "ON/OFF" button which will light up blue. Be patient, nothing happens right away, but the cycle has begun. In a few minutes the water reservoir will begin to empty. This self-clean/decalcification process takes approximately 30 minutes. Then pour the water/white vinegar solution out of the coffee reservoir, rinse the water and coffee reservoirs and run one cycle of fresh cold water through before using to brew coffee.
Sep 17, 2013 | Conair DCC-3000 - Cuisinart Coffee on...
Coffee maker turns on but will not brew
why question to all of this is with a "self clean" button, why doesn't it every tell you to clean it..... ??
Sep 07, 2012 | Cuisinart DCC-1200 Coffee Maker
Why won't the hot water empty into the coffee pot?
Make sure your caraffe has its lid on , and check the bottom of the filter. it usually has a valve preventing coffee from leaking when you remove the caraffe. the lid pushes the valve back open when you place the caraffe back into the machine.
Jul 10, 2012 | Cuisinart DCC-2200 14-Cup Coffee Maker
How to clean
mcdevito75 here, Start with a new paper filter or claen the perminant one, you"ll need enough WHITE VINEGAT to fill the pot itself 3/4 full of this WHITE VINEGAR, NOW pour the pot of 3/4 full of WHITE VINEGAR into the resovoir, replace pot in the coffeee maker and cycle thru the vinegar 3 times, each time letting the mavhine cool a bit for easy handleing, on the 3 rd cycle stop 1/2 thru the brew cycle, let machine cool for 30 Minutes, then complete that cycle. Now repeat with fresh water to reove all the vinegar from the machine. Your coffee maker should now be good as new.
Jun 22, 2010 | Cuisinart Brew Central 12-cup Coffee Maker
Flashing "clean" light on my Cuisinart coffee maker--can't find my manual, sorry. Also, LOTS of steam, less coffee output than expected.
We had this problem. I can't remember all the details but we followed the manual's directions and ultimately the flashing light would come on again. We went through the same procedure a number of time over the day, and each time the self-clean light would go off, but then when we tried to make coffee it would do exactly as you described. Finally we gave up and uplugged it, ready to throw it in the garbage. But then, I was going to call Cuisinart's number (go to their web-site) and I thought I'd try it again so I could describe exactly what happened to the customer service rep. Guess what? It worked! I think what may have happened is, by unplugging it, we re-booted its computer. So try unplugging it and replugging it in.
Apr 27, 2010 | Cuisinart DCC-1200 Coffee Maker
Keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
Jul 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart 12 Cup Digital Thermal Coffemaker
I called Cusinart support and they told me to fill with 2 cups of white vinegar and the rest water, let set for three hours. Did that. Had to keep hitting the on button to get this solution through. Then used a solution of one cup of vinegar and water and this ran through the whole cycle. Ran three more with just water and now it works just fine. Brewed coffee this morning with no problem. Didn't think this would work but seems to have solved the problem. They do suggest you decalcify once a month using the vinegar solution...hope I remember to do this as it would be a lot easier than having to get hitting the on button. Good luck!
Dec 24, 2007 | Cuisinart 12 Cup Digital Thermal Coffee...
Nothing works, only flashing program light and time
listen to this! we called Cuisinart at 1-800-726-0190 and they are going to sihp us a replacement coffee maker and all they are going to charge us it the price of shipping. good news since spending so much for a product. great customer service.
May 28, 2007 | Cuisinart Thermal DGB-600 Grinder
Coffee Makers & Espresso Machines Logo
99 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
