Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Flashing number 2 code - Hunter Fan Company 5/1/1 Programmable Thermostat
    Scholar:
  • 64 Answers
Remove batteries.
Insert a paperclip or similar object into the "reset" hole and hold in for 10+ seconds.
Insert new batteries.
This should reset the thermostat to factory settings and clear all programs, and it should work normally afterwards.
If the error occurs again within a month, then call Hunter tech support at 888-830-1326 between 7am - 7pm US Central timezone.
Posted on Oct 18, 2013
My indesit washing machine WI121 is taking several hours to complete a wash cycle on quick wash which should take 30 minutes
Reading the error code
The fault on the appliance is signalled via:
1. the continuous rotation of the selector knob
2. the action, for the first 4', of the electrovalve and the drain pump
3. the door becomes unlocked
4. the led flashes:
the number of flashes indicates the fault code; the code should be read as follows:
· each fast flash (2/3 flashes of the led very close together) represents one code value
· the fault code is evaluated by counting the number of flashes occurring at 3/4" intervals from one another
· stop counting when the washing machine waits the equivalent of approximately 8/9" between flashes
· the procedure is repeated by the appliance cyclically
Dado
Sep 14, 2015 | Indesit Washing Machines
How to get code for check engine light
you can use a scan tool or code reader to get the code. the other way is to turn the key to the on position then off 3 times in succession. then you count the flashes. the first number/s will be a long flash then the next number will be a quick flash for a 2 or 3 digit number. then there will be a longer pause for the second number complete number. hope this makes sense. you can go to Google search and type in your year, make, model of car and how to flash codes there should be a short film.
Oct 10, 2014 | 2002 Chrysler PT Cruiser
What is service engine light code 12 mean
READING CODES USING MIL (CHECK ENGINE) LAMP
Be advised that the MIL or CHECK ENGINE light can only perform a limited number of functions and it is a good idea to have the system checked with a scan tool to double check the circuit function.
  1. Within a period of 5 seconds, cycle the ignition key ON - OFF - ON - OFF - ON .
  2. Count the number of times the MIL (check engine lamp) on the instrument panel flashes on and off.
The number of flashes represents the trouble code. There is a short pause between the flashes representing the 1st and 2nd digits of the code. Longer pauses are used to separate individual 2-digit trouble codes.
An example of a flashed DTC is as follows:
Lamp flashes 4 times, pauses, then flashes 6 more times. This denotes a DTC number 46. Lamp flashes 5 times, pauses, then flashes 5 more times. This indicates a DTC number 55. DTC 55 will always be the last code to be displayed.
Fig. Fig. 2: Diagnostic trouble code chart (1 of 2)-1995-97 engines
Fig. Fig. 3: Diagnostic trouble code chart (2 of 2)-1995-97 2.0L engines
Jul 26, 2012 | 1995 Dodge Neon
Trouble codes: 1,2,4
dodge codes of this era were 2 number codes not single number codes.recheck your codes flashing on the dash,or with what ever tool your using.there should be a flash close together then a short break then more flashes close together then a longer pause before the next code flashes.cont the flashes that are close together that is one number of the code then after the short pause count the next number of flashes this is the second half of the code.then a new code flashes after the long pause.so if the first code flashes once then after short pause it flashes twice this is a code 12.then a new code flashes after the longer flash,but always a 2 number code.also be aware that dodge uses a code 12 to indicate the start of the code sequence and a code 55 indicates the end of the code sequence.thats why its better to use a scan tool to see what codes are in the computer as sometimes a flash is missed or not counted.
Aug 12, 2011 | 1990 Dodge Ram
I have a 1994 plymouth voyage se and it will not strat. It tell me to check gauge light comes on. what should i do or what does that mean?
Turn key to on ( not start) then off, then on, then off, then on and leave on, and have a pen and paper ready to record flashes of "check engine light". It will flash then pause between second number of 2 digit code. Then a short pause and flash again, pause, then flash. For example: if it flashes 2 times, then pause, then flashes 2 more times, that would be code 22. If it flashes 3 times, pause, then flashes 5 more times, that would be code 35. As I said, there will be a short pause between 2 digits, as well as after number. Write them down as they come up and get back to us with those codes for advice. When you get code 55 ( 5 flashes, pause 5 more ) that means end of message. Those codes should point everyone in right direction of trouble spot.
Jul 31, 2011 | 1991 Plymouth Grand Voyager
CAR ASKING FOR IMOBOLISER CODE, HOW DO I INSTALL
Press reset button located to right of led for 2 seconds led will flash
Release button
After 2 secs led will flash once
Enter first digit by pressing reset button relevent number of times
After 2secs led will flash once
Enter next digit by pressing reset button relevent number of times
Repeat operation for remaining digits
if code is entered correctly led will flash
if code is entered wrong led will remain lit but not flash
Note if one of the digits of the code is a zero
after the single flash DO NOT press button but wait for next request and enter the next digit.
Oct 05, 2009 | 2000 Alfa Romeo 145
Check engine codes for 1991 Dodge Spirit LE , light comes on but does not blink then goes out.
Turn key to on, then off, then on, then off, then on & leave it on, (not start, just to on) then count the number of flashes of check engine light. It will flash,then have a small pause, then flash again. It will be a 2 digit number, for example: 2 flashes, pause, 2 more flashes, will be code 22. 3 flashes, pause, then 5 more flashes would be code 35. When you get 5 flashes,pause, then 5 more, That is code 55 which just means end of message. Get back to us with codes & we'll advise of what to look for.
Sep 21, 2009 | 1991 Dodge Spirit
CAR LOOSES BOGS OUT AT HWY SPEEDS AND IDOLOS ROUGH .
Cycle your key on (not start, just on) off, on , off ,on, and leave it on. have paper & pen ready. Watch flashes from check engine light. It will flash quick, pause flash quick. It will be a 2 digit number each time. For example: flash, flash, short pause, flash, flash. is # 22. Flash, flash, flash, pause, flash ,flash,flash. is # 33. There will be a slightly longer pause between codes,(after every 2 digits) then next code starts. 2 numbers again. When you get 5 flashes, pause, 5 flashes = code # 55 means end of message. Check it out and let me/us know what you get.
Dec 31, 2008 | 1991 Plymouth Acclaim
Error code e10
Communication failure =E10
1. Rotate the CYCLE SELECT KNOB to the 3 O’clock
position.
2. Press and hold the Select and Pause Cancel
buttons simultaneously for (6) seconds.
3. Immediately after, press and hold the START and
Pause Cancel
buttons simultaneously for (4)
seconds.
4. Rotate the CYCLE SELECT KNOB to the 2 O’clock
position.
The STATUS indicator lights will flash the number of
times for the first digit of the code and the START indicator
light will flash the number of times for the second digit.
The code is obtained by counting the number of times
the lights flash. Example E24: the STATUS indicator
lights would flash twice indicating the 2 and the START
indicator light will flash four times indicating the 4. The
STATUS indicator lights and the START indicator light
will start flashing at the same time. The control will then
pause for 2 seconds, then repeat the code.
Troubleshoot the problem by using the chart on next
page.
To move to the next code, press the OPTIONS button.
To clear code, press the Select botton.
To exit this mode, simultaneously press and hold the
Select and Pause Cancel buttons for (6) seconds to
reset.
if this does not work need to replace control
Sep 07, 2008 | Frigidaire Washing Machines
1989 dodge caravan 2,5 engine throttle body
Check for vacuum leaks. Cycle key, on, off, on, off, on, and see if check engine light flashes out codes. always 2 digit number with short pause in between. for example: 2 flashes, pause, 2 more flashes, is code 22. Write them down & get back to us. Code 55 (5 flashes, pause, 5 flashes, is end of message (codes).
May 18, 2008 | 1989 Dodge Caravan Cargo
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
165 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
