Question about Kalorik WCL-20629 18 Bottle Dual Zone Wine Cooler
I have a Kaloric wine cooler. The fan and light are OK but it doesotrefrigerate at all. Everything stays at room temperature nomayyer how low put the tempat.
Just purchased and is not cooling at all
please see this steps and fix it. God bless you
1. Unit not running
Possible Causes Response a. Power cord unplugged
b. No power at all
c. If display lighting, temp setting high
d. If temp setting ok, sensors or control board bad
e. Compressor unit malfunctioning a. Check for power cord plug
b. Check receptacle voltage & fuses
c. Lower temperature setting
d. Call service for replacing sensors or control board
e. Call service for component check
Nov 27, 2013 | EdgeStar CWR361FD - 36 Bottle Built-In...
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Aug 11, 2012 | Danby DWC283BLS Wine Cooler
Other than temperature, is there any other reason not to store wines in a regular fridge? I don't mind my wines being slightly cooler and I can always leave them on the counter for 10 minutes bef
Aside from temperature, humidity is a major concern. The low humidity levels can cause the cork to dry/shrink allowing room for both air and other food odors to enter the bottle and tamper with the quality of the wine inside. Wine coolers offer an optimal humidity level of 50-80% needed to keep your wine in good condition.
Jul 31, 2012 | Furniture
The alarm in our Franklin Chef model FWC100 wine cooler keeps going off even though everything stays cool so we want to know how to turn off the alarm or cut the wire to the alarm. Thanks.
Love this machine. Works great. Have had it for 6 years. Now it has a problem. The lights and fan work, and the temperature settings work. It behaves like either the freon is low (I don't hear the compressor starting), or whatever causes the compressor to start is crippled... Fuse looks good, nothing visibly burned on the motherboard, haven't opened the bottom.
Jul 29, 2011 | Franklin FWC100 Wine Cooler
My wine cooler will not run at all. The compressor is Ok. The cooler uses relay 41006036 rev E. I do get continuity on both the pot and the thermistor. What is the correct resistance for the thermistor...
Hi
Please check this link to read detailed information related to wine cooler as per your query:-
http://www.winecoolerexpert.com/wine-cooler-faq.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 05, 2011 | Marvel (6SBARBSG) Wine Cooler
THE UNIT DOES NOT COOL ANDY COLDER THAN ROOM TEMPERATURE.
does the compressor run ? if so you could have a low refrigerant charge, a sealed unit resrtiction, leak or defective compressor.
Apr 30, 2010 | Haier HVUE08A Wine Cooler
Unit will not cool. Stays at room temp.
based on my personal experience it may be a bad fan. can you feel the fan running? or does it just feel hot near the vents?
Jul 31, 2009 | Cuisinart Private Reserve CWC-900 Wine...
U-line 15" wine cooler not cooling, but light is on.
If the light is on and no fan or compressor is running then its your thermostat that is bad. Thats the only thing that turns on those parts.
Nov 25, 2008 | U-Line 15WC Wine Cooler
Cuisinart Private Reserve wine cellar
It is normal. The goofy thing about this wine cellar is that once the ambient temperature is above 70 degrees - which is actually a low room temperature - the fan works constantly. You would have to make sure the wine cellar is in an area that stays below 68 degrees (brrrr) for it to shut off sometimes.
-Tha Mp3 Doctor
Sep 13, 2008 | Cuisinart ICE-30BC 2 Quart Ice Cream Maker
U-Line 15WC wine cooler not working
First make sure your condenser is clean and the fan is going. If everything is running and still doesnt cool enough then you need a repair person to check the sealed system.
Feb 02, 2008 | U-Line 15WC Wine Cooler
Open Questions:
See all Kalorik WCL-20629 18 Bottle Dual Zone Wine Cooler Questions
Kalorik WCL-20629 18 Bottle Dual Zone Wine Cooler Logo
53 people viewed this question
Top Kalorik Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Kalorik Furniture Expert? Answer questions, earn points and help others
