Question about SanDisk Sansa View 8GB MP3 Player - Black
Sansa View - reconnects over and over
My sansa view keeps disconnecting and reconnecting by itself, over and over with like a 1 second delay in between. It makes my computer make a constant usb connection sound. Does anyone know how to fix this. I tried hard resetting it. and formatting
    President:
  • 563 Answers
Unfortunately, the two things you already tried are the only troubleshooting options available. There is either a loose connection inside the player or possibly you have a bad USB cable. If the cable is fine, the unit needs to be repaired/exchanged through the manufacturer.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
Sandisk Sansa View 16GB Won't Start
if it is detected in your system,use sansa updater to upgrade the firmware.You will find it here
If not, first download the firmware from here 1.Turn on the View
2.Put the device in Hold (move Hold button until orange is showing)
3.Press and hold the Left Button
4.Plug the 30 pin connector into the device (be sure the USB is plugged into the computer)
5.Wait for View drive(s) to mount
6.Extract the downloaded zip file and transfer all the contents to the mounted drive.
7.Disconnect the Sansa View and let it restart. 8.Upon completion of the firmware upgrade, the device will restart. If the restart does not initiate or complete, press & hold the Power switch for 8 seconds to reset the device and then release and press again to restart.
Sep 03, 2009 | SanDisk Sansa e250 MP3 Player
I have problem with Sansa View
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Feb 20, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 will not power up
Okay what you do for this is hold down the power button for 20-25 seconds or so. This will reset your Sansa e260 and then it will power up like normal. I have had this problem before. If that doesn't work then I don't know what will.
Feb 02, 2009 | SanDisk Sansa e260 MP3 Player
The screen on my sansa view just went white and every thing works but the screen is white with a green line throgh it
-Tha Mp3 Doctor
Dec 09, 2008 | SanDisk Sansa e250 MP3 Player
Sansa View 8MB Player
delete and start over again
it's best to sync a few disconnect, let the database update, and then reconnect, load some more
Jul 12, 2008 | SanDisk Sansa e250 MP3 Player
Sansa clip 2gb
May 28, 2008 | SanDisk Sansa Clip MP3 Player
How do I get my Sansa e260 to appear in Windows Media Player (v. 11; Vista)?
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 12, 2008 | SanDisk Sansa e260 MP3 Player
My sansa e250 ask me this
Solution:
1. Put Lock on.
2. Push and Hold Both Rec and Power buttons while the power is off.
Then message should show saying: " Welcome to Recovery Mode"
Mar 17, 2008 | SanDisk Sansa e250 MP3 Player
Dell optiplex 110 sys does not find the sansa view player
I have recently connected to a Sansa device. The device had to be powered on before it would be detected as a drive. Also it had a hold feature which suspended any I/O. Alternately, the Dell may not have all the usb ports connected to the motherboard. I suggest you plug the Sansa device into the same usb you were connecting the external drive. Beyond this, more information required. I hope it helps. Good Luck.
Jan 27, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
SanDisk Sansa View 8GB MP3 Player - Black Logo
146 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
