Question about Casio Office Equipment & Supplies
I have a Casio fx-9750GA plus. I can turn on the calculator with the on button but nothing else works, the keys do not respond and I can not turn it off. Help?
  • Casio Master
  • 7,993 Answers
It has a reset button on the back, midway from the top.
Posted on Oct 14, 2013
Testimonial: "When I push the reset button I still have to press the F1 button to confirm the reset, and the F1 button doesn't respond."
Vinx
  • 5 Answers
SOURCE: factorial abbrevation on casio fx-9750GA PLUS can't find it!!!!
There is no direct or shifted keystroke for nCr nPr and ! on casio long ago.
You can access to those function using OPTN button; here is how to do...
press OPTN, F6(>), F3(PROB), F3(nCr)
Posted on Jul 02, 2009
  • 7993 Answers
SOURCE: Casio fx-9750GA can't find Ran or Int
Turn calculator on. Select [RUN] [EXE].
In run screen press [OPTN] [F6:-->] [F4:NUM] then select the function you want to use. You have ABS, Int, Frac, Rnd, Intg.
Hope it helps.
Posted on Sep 18, 2009
  • 1126 Answers
SOURCE: I need to know how to set the Casio fx-9750ga plus
Page 14 in Chapter 1 listed here.
http://support.casio.com/pdf/004/fx_plus_chapter01.pdf
Posted on Sep 24, 2009
  • 7993 Answers
SOURCE: How do I graph an equation such as y= 5x + 2?
Turn calculator ON. If you do not see several icons press [MENu].
Use arrow to select the [GRAPH] application and press [EXE].
In the entry screen, the line with Y1= is highlighted. If it is not, use arrow to highlight it.
Press the right arrow, the highlighting disappears leaving you with Y1= and the blinking cursor.
At the position of the cursor enter 5 [X, theta,T] key under the [ALPHA]. On the screen appears 5X, complete you equation +2.
Press [EXE] to store function.
If you want to draw other functions, it is time to do so on that screen.
When done press [F6:Draw}.
If the screen does not show a lot of the function, you can use the arrow keys to pan the graph.
You can also press [SHIFT][V-Window] to set the window limits.
Hope it helps.
Posted on Oct 11, 2009
Testimonial: "Thank you so much!!!"
  • 7993 Answers
SOURCE: How can I solve a matrix on my Casio fx-9750GA
If you have mastered matrix manipulations on the TI calculators, it should be a breeze to learn the same on the Casios.
A. Define the matrix (Create it)
  1. Turn calculator ON.
  2. Press Menu,select the MAT icon and press [EXE]
  3. You see a list of possible matrix labels (A, B, C,D,E,F)
  4. All that have not been created have a "none" to their right
  5. Highlight a matrix name and press the right arrow. Where there was "none" , you have a template 0x0.
  6. That is where you specify the dimensions (mxn). exemple. 2x2
  7. Enter the first dimension and press [EXE]
  8. Enter the 2nd dimension and press [EXE]
  9. A matrix template opens where you enter the coefficients left to right and up down.
  10. After each coefficient press [EXE]. Cursor moves to the next coefficient, etc.
At the bottom of the screen you have 3 menus for Row and column manipulations. But those will have to wait for now.
Press [SHIFT][QUIT] to return to the list of matrices to create new ones
Operations on matrices
Once you have one matrix, you can do operations on it: Calculate the determinant (if matrix is square), calculate its inverse, transpose, augment it, fill it, etc..
  1. These operations are accessed as follows.
  2. Quit the matrix editor by pressing [Menu] and selecting the [Run] application.
  3. Press [OPTN][F2:MAT]
  4. You have the menus Mat,M(atrix)->L(ist), Det(erminant), Trn (transpose), Aug(ment) ->, Iden(tity),Dim(ension) Fill
Exemple : calculate the determinant of a matrix A (already defined).
  1. You press the [OPTN][F2:MAT] key sequence (just above)
  2. Press [F3:Det]; the command det is displayed on screen.
  3. Press [F1:Mat] the identifier Mat is displayed.
  4. Press [ALPHA] A; screen display det Mat A.
  5. Press [EXE] to get the value of the determinant.
Square of Matrix A
[OPTN][F2:MAT] (MAT) [Alpha] A ^2 [EXE]
Product of two compatible matrices MatAXMatB
[OPTN][F2:MAT] (MAT) [Alpha] A [* ) (MAT) [ALPHA] B [EXE]
Hope it helps.
Thank you for using FixYa.
Posted on Nov 23, 2009
Is there a verify mode on the CASIO fx-991es plus calculator?
You should try to explore the calculator to find its capabilities. You can also read the manual. Everything is in it.
Press the Mode button, then the down arrow key. On the second page of the mode list you find 2:Verif
Mar 23, 2014 | Casio Brand New-Fx-991es Plus - Scientific...
Matrix casio fx9750giihow can I find eigenvalues and eiginvectors for a matrix in my calculator? :)
This calculator cannot find eigenvalues and eigenvectors of matrices for you. The calculator does have many row and column operation that you can use to solve your problem. You need to know the theory of matrices, determinants, and some eigenvalue and eigenvector finding algorithms.
Dec 13, 2013 | Office Equipment & Supplies
I have a casio fx-9750GA PLUS. how do you do standard deviation with a set of numbers?.
Here are the capabilities of the calculator.
In stat enter the values in List1 and the frequencies in List2
Press the key corresponding to the CALC tab
Press the 1-var tab and you get the results as seen on the screen with title 1-variable.
Other screens show some two-varaible stats or regressions.
Jun 01, 2011 | Casio FX9750GII Graphic Calculator
I'm trying to graph in radians on a casio fx-9750ga plus, but it doesn't show up on my screen. what should i do?
To get results in radians you must configure the angle unit to be degree.
  1. In Run screen press [SHIFT][MENU] to access (SETUP).
  2. Use Down arrow to highlight the line Angle :
  3. Press F2 key to select the TAB Radian.
  4. Once you do that all values (input of trigonometric functions and polar graph functions OR output of inverse trigonometric functions) are in radians.
If your function is periodic (and all trigonometric functions are) set the window dimensions Xmin
= negative (2 or 3)P and Xmax) = (2 or 3) PI. Adjust if necessary to a smaller domain.
Sep 09, 2010 | Casio FX-9750GPlus Calculator
Degree and radian function Casio fx-9750GA Plus
Press MENU, then select RUN and press EXE.
Press SHIFT MENU to access the SetUp.
Move cursor to highlight Angle.
In the botton of screen you see the Deg TAB. Activate it by pressing F1.
Here is a screen capture.
May 06, 2010 | Casio FX-9750GPlus Calculator
Hope it helps.
Oct 10, 2009 | Casio FX-9750GPlus Calculator
Factorial abbrevation on casio fx-9750GA PLUS can't find it!!!!
Jun 13, 2009 | Casio FX-300MS Calculator
Log function on casio fx-9750GA Plus
Look it's simple in the calculator the default base is 10 so when you input log 3 its log 3 base 10 so:
maybe you know in math log x base y = log x / log y . So if you need log 3 base 3 its => log 3 / log 3 (by the way its 1)
Mar 27, 2009 | Casio FX-300MS Calculator
Hope it helps.
Feb 15, 2009 | Casio CFX-9850G Plus Calculator
79 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
