Question about HHB BurnIt CDR830 CD Recorder
Hhb burnit cd 830 check disk , cd not detect - HHB BurnIt CDR830 CD Recorder
2 Suggested Answers
SuperTech-11
  • 1591 Answers
SOURCE: Live kick drum causes HHB 830 Burnit Plus to stop
Absolutely. You are going to have to isolate the drummer from the writer somehow.
We used to put the drummer in an isolation booth.
You can also try building a "foamy box" for the CD writer. The kind of foam you want looks flat on one side, and sine wave like on the other. Put the flat sides out.
Build it with just the front open, and run the cables under the recorder and out the front if length allows.
CAUTION: I recommend using this enclosure ONLY when there is a live drum being recorded live.
This is because prolonged enclosure like this may cause heat issues.
TIP: which ever side faces the drummer, the writer should not be touching that foam wall.
IE - if the rear faces the drummer, the box should be big enough that the rear wall doesn't touch the writer.
Good luck, and let me know how that all works out for you!
(hey, it's easier than suspending the writer with elastic or bungee cords!)
[subnote - yes, that works too, but it's a pain in the **** building the metal frame!]
Posted on Feb 25, 2011
Need remote for my hhb butnit plus
Either contact hhb or look on E bay. Universal remotes usually do not have enough of the functions required to finalize discs and such.
Dec 26, 2012 | HHB BurnIt CDR830 CD Recorder
Hi, I have an HHB Burn-It CDR 830. Whenever I'm recording, along about the 5th track in- the player starts to fuzz out. The time stutters/freezes momentarily, and then continues normally for a while...
If it's always around the same physical location on a given CD it would have to be a physical problem with the transport, not the lens.
Esoteric but comprehensive advice....
http://www.repairfaq.org/sam/cdfaq.htm
Sep 20, 2011 | HHB BurnIt CDR830 CD Recorder
Live kick drum causes HHB 830 Burnit Plus to stop recording, vibrations?
Feb 25, 2011 | HHB 830 Plus CD Recorder CD Player
How to finalize a cd after recording
Press Finalize, then after it displays a time like 4:04, press Pause. It will count down while finalizing. Press STOP to cancel.
http://www.retrevo.com/search?q=HHB+BurnIt+CDR830
Dec 28, 2010 | HHB BurnIt CDR830 CD Recorder
Hi there, when recording analogue from mixer to HHB Burner 830 the blank cd does not read properly, and records blank even thou the connections are in the right ins and out (phono to phono) And the input...
I can only assume that it's not changing the analogue signal into a format suitable for transferring to a CD. Check the recording settings. Make certain the signal is being converted to say a WAV format or MP3 etc.
May 01, 2017 | HHB BurnIt CDR830 CD Recorder
What does pma rec mean on the hhb cbr 830 ? it just stops recording
The recorder is writing TOC data to the disc's PMA (Program Memory Area). Never turn off the power while this display is
showing.
http://www.retrevo.com/support/HHB-CDR830-CD-Players-manual/id/3875ci874/t/2/
Aug 13, 2010 | HHB BurnIt CDR830 CD Recorder
User manual
You can get it at www.manualsonline.com,www.manualnguide.com or at their website.
thanks and good luck
Jun 04, 2010 | HHB 830 Plus CD Recorder CD Player
Anytime I try to record with my HHD BurnIT cdr 830, the red record light will only be bleeping and the time counter will not work as well. And there will be nothing recorded on the cd.
Just a guess, but did you ever try to hit the record a second time once you're all set up to start? The first press of the record button places the machine in record/pause mode after it calibrates itself to the disc.
Jan 19, 2010 | HHB BurnIt CDR830 CD Recorder
HHB burn it...I record on coaxial from Tascam DAT. 1st five tracks are great but the 6th track sounds horrible like there is a scratchy sounding distorted delay. It does this every once in the while . What...
I had this happen a lot on my Pioneer PDR-509, which is pretty much the same machine, when using marginal mongrel-brand CDR's. It's annoying but I have seen nothing to explain or detect it in real time so something can be re-recorded.
Nov 17, 2009 | HHB BurnIt CDR830 CD Recorder
Cannot use the finalize function anymore
they wear out have it serviced and cleaned
Nov 05, 2009 | HHB BurnIt CDR830 CD Recorder
HHB BurnIt CDR830 CD Recorder Logo
Top HHB Audio Players & Recorders Experts
John
John
darren dillon
Level 1 Expert
Are you a HHB Audio Player and Recorder Expert? Answer questions, earn points and help others
