Question about Microwave Ovens
Mh6150xhq specifications need dimensions
Jvm230wl I want to replace my over the range GE JVM230WL model but I'm not sure the exact dimensions. It appears to be a snug fit in the bracket so the measurements need to be manufacture specific. Also,...
GE Customer Service is here. They may be able to tell you if there is a "drop-in" replacement available for your model.
Otherwise, you'll have to take down the old bracket then mount another model in the space.
Jan 15, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Whaqt are the dmensions of panasonic genius premier model number nn-s7768a
Here's your answer and then some, in case it helps
Brand: Panasonic
Name: The Genius Premier 1000W
Primary feature: reheating of popular food categories is done automatically (time and power level automatically determined, often time adjusted based on steam sensor). Defrosting also done by entering weight (so time is automatically determined).
Color: black matte top/lateral sides; black gloss front; white back; silver bottom
Style: Counter/table top (label says not for mounting)
Model: NN-S7768A
Manufacture Month/Year: September/1996
Dimensions Exterior: 14"T x 23-3/8"W x 16-1/2D (18 including protruding door handle and back cord plastic clip)
Dimensions Interior: 10-5/8"T x 16-1/4"W x 15-1/4"D
Cubic Feet interior: ~18.28 cu ft (based on three interior dimensions multiplied together and divided by 144 to get from cubic inches to cubic feet)
Note:
I found a manual from a similar model; you'll probably want to pring page 15 as a reference, since each food category button has 2-4 modes based on the type/temperature of the food, e.g. veggies are 1. for potatoes up to a certain quantity and weight each, 2. fresh veggetables of a certain weight, and 3. frozen vegetables of a certain weight. Specific instructions on adding water, covering, etc. are also included. Makes microwaving pretty easy!
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CGAQFjAB&url=http%3A%2F%2Fservice.us.panasonic.com%2FOPERMANPDF%2FNNS696.pdf&ei=BMEnU4-RLaWbygHQ2oCQCg&usg=AFQjCNF2JlFATy7HV-Ltv0BjDUf_LHHi3g&bvm=bv.62922401,d.aWc
Jun 24, 2013 | Panasonic Microwave Ovens
What is the size of gh4155xp
Google the model number of the unit with specifications or specs, if out there you will find dimensions, weight, and features.
Dec 19, 2012 | Whirlpool Microwave Ovens
I need the dimensions of the GE Spacemaker XL Model JVM1653WH01
For dimensions look at the GE Appliance web site at: http://www.geappliances.com/ then search for JVM1653WH01
This will take you to the product information page for the JVM1653WH 1.6 Cubic Foot Over the Range Microwave Oven with weights and dimensions, installation instructions etc.
Oct 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have an older Whirlpool over the range microwave. 2001 model#MH6150XHQ-1 I went to start it and poof, it went dead. Was it a fuse? If so where are they located and how do I get one for it?
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here (just enter your model number).
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 02, 2010 | Whirlpool Microwave Ovens
How big is microwave MMV4184AAB
From page 5 of the owner's manual:
OVEN SPECIFICATIONS
Power Supply 120 VAC,
60 Hz
Input Power 1,500 W
Cooking Power 1,000 W
(IEC 60705
Standard)
Frequency 2,450 MHz
Rated Current 13 A
Outer Dimensions 2915⁄16" x 167⁄16"
(WxHxD) x 155⁄8"
Cavity Volume 1.8 Cu. Ft.
Net Weight 60 lbs.
If you've misplaced yours, you can download it here.
May 30, 2010 | Maytag Microwave Ovens
We have an mh6150xhq-1 microwave. It rotates, the timer works, but we don't get any heating. can you help?
In all likelihood the mangnetron is failing, or perhaps even the Power Supply is faulty. You need to have it serviced by a reputable service centre/man.
Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one
Jan 27, 2010 | Microwave Ovens
My MH6150XHQ quite cooking
Assuming your turntable comes on when you try to microwave, with the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
Jan 17, 2009 | Whirlpool MH1150XMQ Microwave Oven
I now own a Whrilpool over the stove microwave. Everything works expect it does not heat the food. The model # is MH6150xhq, serial #FGMO101446. I would like to replace it with a model that has the same...
You can contact Whirlpool customer service here and they should be able to suggest a model which will be a "drop-in" replacement.
Are you not interested in getting yours fixed?
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Your manual will tell you about the warranty.
You can download your owner's manual, installation instructions, etc. here.
Sep 27, 2008 | Whirlpool Microwave Ovens
Microwave Ovens Logo
154 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
