Question about Hayward H400FDP Low NOx Propane Gas Pool or Spa Heater
LO error code showing wont start up - Hayward H400FDP Low NOx Propane Gas Pool or Spa Heater
  • Hayward Master
  • 1,631 Answers
For informational purposes...
LO is simply informing you that the Heater is not sensing proper water flow through it! A special sensor, called a pressure switch is this source. But... That does not mean it is bad - No, it is in most cases just doing its job!
Most common reason - Dirty Filter.
A good cleaning of the cartridges, or maybe a breakdown and recharge of a DE Filter, or a good cleansing backwash of your sand filter, will remedy this situation.
Posted on May 25, 2015
  • 128 Answers
Low flow. Try cleaning the filter.
Posted on Nov 02, 2013
Has error 92
Trouble Item:
Hi-Lo solenoid failed
Probable Cause:
. Hi-Lo solenoid output terminals voltage is out of specification.
. Hi-Lo solenoid broken or short-circuited.
. Wiring harness broken or short-circuited.
Solution:
Engine does not start (This is a solution ????)
Check the Hi-Lo solenoid resistance (Page 9-S51 shows 10 to 12 ohms)
Replace the Hi-Lo solenoid
Oct 14, 2015 | Garden
IFB washing machine front load Showing ' Lo' what
Error code LO normally means the filter is blocked. this would be the best place to start. refer to your owners manual for instructions on cleaning this.
Aug 10, 2013 | IFB Washing Machines
P0700/p1603/p1604/po613
fco.lozano, mi carro cirrus 2005 lxi turbo 2.4 triptoni, a veces no entra la tercera c bloquea y nada mas entra segunda lo apago cuando ya esta medio frio lo enciendo y entran bien las velocidades pero c vuelve a calentar pasa lo mismo kien me puede ayudar xfa. gracias
Jul 18, 2012 | 2003 Chrysler PT Cruiser
Im getting a "LO" error
The LO error code means the LID OPEN
Here is what the techicians service manual say to check
LO Door failed to unlock Door lock monitor switch does not indicate to the machine control board that the solenoid in the door lock mechanism retracted and unlock the door. 1.Check for debris inside inside the door lock mechanism, which may be jamming the lock solenoid. 2.check wire connections in harness leading from machine control board to door lock mechanism.
3.Check the door lock monitor switch for welded contacts.
4.Replace responsible component.
Jul 30, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a 2007 r1 it has had an error code HI this code comes up even when the bike is cold and prevents me from starting it . It will turn over , but if it says HI it wont start. only time it will start is...
Hi, Tom for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Yamaha Fault Codes motorcycle manuals
R1 diagnostic modes and codes
Yamaha YZFR1 YZF R1 2007 2011 Factory Service Repair Manual Download...
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
May 31, 2011 | 2007 Yamaha YZF-R1
Getting LO error
Lo is an error code dealing with the safety loop, hi limit switches, water pressure switches. Check for continuity and the wiring between the hi limit switches and the water pressure switch. Also, check to make sure the filter is clean and the pump basket is empty. These also can cause a low flow situation that will cause the pressure switch to not close properly.
May 23, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
"LO" error code on new H400FDN heater
it is low water pressure sensed, unit will not start unless pump is working
Jun 07, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
ERROR CODE
Hi,Pls to shut - down the unit and try to power on ,may be its malfunction the control LCD.
THANX
Edgz
Mar 30, 2008 | Heating & Cooling
Hayward H400FDP Low NOx Propane Gas Pool or Spa Heater Logo
94 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
