Question about Maytag Neptune MDG9700A Gas Dryer
Maytag Centennial 7 Cu. Ft. Electric Dryer, how to remove front
  • Maytag Master
  • 2,128 Answers
Unplug it,remove the top panel screws in the back,remove the control panel and then you can remove the front.go here
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MDG9700AWW/3048/0151200/M0702017/00001?
blt=06&prst=&shdMod=
you'll see number 14 and 15,you have to remove the 4 1/4 inch screws on the top and the two phillips screws that are behind the door.
Posted on Oct 13, 2013
  • Sal DeAngelo Oct 13, 2013
    what problem are you having?
    it says this is a neptune but the model number you sent isn't for a neptune,is this the correct model number?MDG9700AWW
4 Suggested Answers
  • 65 Answers
SOURCE: Remove front of dryer to clean lint from interior
open door remove eight screws, four on plastic guides and same location on hinges. wiggle door and it will remove . now grab narrow ends of front panel and pull toward you. wwhen panel gets to 45 degrees pull off tabs at bottom.
Posted on Feb 16, 2008
thedayos
  • 57 Answers
SOURCE: My new maytag centennial electric keeps tripping
Hi Matt
I'm not sure that swapping out the breakers to higher rated ones will give you a solution so I'll throw in 2 cents to see if my advice holds true. Let's start by asking this. Is the appliance "rated" at 220 volts at 30 amps per leg. I assume this from your post as to what it has been rated. Next - How long is the "run" of wire from the junction box to the outlet where the appliance plugs in? This usually does not matter in most households but if the run is of significant length it may need a larger gage wire to support the current draw of the appliance. Lastly, and perhaps most importantly, are the lugs and wire connectors tight at the outlet, the plug, and the breaker box. A loose connection will ramp up the current fast. This is assuming the first two items were met. Tell me if any of this helps and we'll work it out from there.
Thanks.
Len
Posted on Feb 28, 2009
SOURCE: Maytag Bravos Dryer (1 mo. old) timer does not change from start
Maytag Bravos 400 Series Dryer purchased August 2009 - November 2009 required repair as I also experience the timer readjusting itself to excessive extended drying time when clothing was bone dry and hot. Sometimes extended to 1 hour 40 minutes! Serviceman stated problem was the Sensors in the dryer. Part number 8577274 Thermister and "Old Ohmed out open" whatever that means as listed on my repair ticket. Have not had that particular problem since. Make sure your dryer vents from dryer to outside are clean and clear of lint. Will help immensely. I have many other issues with this dryer it has been down FOUR times in 9 months. Fighting with Maytag to replace this lemon!
Posted on May 28, 2010
Maytag centennial dryer
May be a thermal fuse or high limit switch.
Sep 26, 2013 | Maytag Centennial 7.0 Cu. Ft. Super...
Maytag centennial dryer wont heat up
I was working on a dryer similar with a no heat problem and made a video you might be interested in:
Dec 21, 2012 | Maytag Centennial 7.0 Cu. Ft. Super...
Maytag Centennial MEDC500VW0 will not run
If you hit the start button, does it run til you let go or not at all?
Nov 23, 2012 | Maytag Centennial 7.0 Cu. Ft. Super...
I have a Maytag Centennial gas dryer and the dryer will not turn off when the door is opened. I'm assuming this is due to a broken switch on the dryer door. How can I repair this?
door switch is correct you will need to unplug the dryer and open the cabinet open and replace switch, this website will assist you, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
May 11, 2011 | Maytag Centennial 7.0 Cu. Ft. 6-Cycle...
My washer is wobbly during agitation even if empty
check to make sure the washer is perfectly level, front to back and side to side.
Sep 26, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Dryer not rotating.
you need to remove the front cover either by removing 2 screws at the lower edge of the front panel,if no screws on this model,then take a putty knife or flat blade and at the top of the front cover between the front and top cover insert it at the edges about 2 inches in and pop the retainer clips inside the panel,then swing it out and remove it,then remove the top cover and then you can access the belt
May 24, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Electric maytag dryer brand new won't heat
could be the thermal fuse, but if it is new then call the warranted service man!
May 02, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Maytag Neptune MDG9700A Gas Dryer Logo
107 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
