Question about Kenmore Grilling
Ignighter stopped working 163251 model - Kenmore Grilling
    President:
  • 957 Answers
You need to identify your style igniter. some newer styles take a battery some don't. common failer problem. Do to poor ground, at the end, close to electrode. Make sure that its clean and tight. If so. you may need batteries(if applicable) or a new igniter.
Posted on Apr 25, 2009
Question about ignighter
igniter failed, out of adjustment , or dirty carbon build up
Jul 14, 2017 | Danby Refrigerators
PLUGS 1&4 STOPPED ,REPLACED IGNIGHTER,NOW 2&3 ARE NOT WORKING ,OPENED IGNIGHTER AND BURNED CHIP
If you have had 2 igniters fail....first check the ignition coils testing all for primary and secondary resistance...then I would check the running voltage on the bike.....you may find you have a bad rectifier regulator which is allowing the voltage to climb too high, and perhaps its taking out the igniters.
Apr 01, 2011 | kawasaki ZL 900 A1 Eliminator Motorcycles
Dryer won't dry
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor. All of these parts are inexpensive and easy to test and replace.There is a video at http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jun 08, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Electric ignighter does not come on in the oven at all
In most cases it is the ignitor itself. Eledtricity goes thru the ignitor and as it gets hot it allows more electricity thru to the gas coils, allowing them to open and let the gas go thru. The ignitors do get weak and will glow but that is all. Not enough electricity can get to the gas valve solenoids and let gas thru. Find a local parts dealer and give them your make and model # to order the part.
Jan 28, 2009 | Magic Chef 9122 Gas Single Oven
Maytag gas oven
if your clock and broiler work then you need to replace the lower oven ignighter remove the oven racks then the bottom plate of the oven its easy then the flame spreader after that you will see a burner bar at the back of that will be the ignighter and just because it glowes dont mean its good just replace it
Jun 13, 2008 | Maytag MGR5751AD Gas Kitchen Range
OVEN WON'T WORK
you need to replace the bottom oven ignighter take the racks out then remove lower oven bottom take it out then remove flame spreader and ignighter will be on burner bar get replacement from appliance repair store take model number with you just because it glowes don't mean its good it should light withen 30 seconds
May 24, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL 44 Kitchen Range
replace the ignighter bar in the lower oven pull the racks out remove the two screws in the oven bottom pemove the panel under that remove the metel flame spredder the ignighter is at the back of the burner bar get your model number and go to appliance parts store for a new one and follow inst even if it glowes doesnt mean its good it should light the oven whithen 30 seconds
May 24, 2008 | GE JGBC20 Gas Kitchen Range
Grilling Logo
112 people viewed this question
Top Kenmore Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
