Question about Sony DVP-NS50P DVD Player
Changing fuse where is the fuse in the DVP-NS50P
    Habit-Forming:
  • Sony Expert
  • 161 Answers
If you are technician then try to chang the fuse fuse is bult in side the dvd player in power supply but as per standared if the fuse is burnt then please check this in nearst sony service centre may be more parts are damage
Posted on Jul 21, 2009
5 Suggested Answers
SOURCE: PAL mode ?
PAL/NTSC is automatic. if you insert a PAL DVD output is PAL ( most probably PAL-B. Some other brands allow manual PAL/NTSC switching, but at this machine this is automaticaly done. Please verify your TV set allows PAL programs
Posted on Jan 02, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Sony CD/DVD Player DVP-NS50P not playing my avi files DVD+RW
You need to convert avi files to dvd format before burning, otherwise the player won't recognize them. Google "avi to dvd" and you'll find a number of free or pay programs that will do the conversion for you.
Posted on Nov 19, 2008
SOURCE: SOny DVD Player DVP-NS50P Locked
press stand by and press return button and enter button and then press stand by button on ur remote control.the player will be unlocked
Posted on Jan 26, 2010
  • 517 Answers
SOURCE: Sony DVP-NS50P not ejecting
Good day!
Please read my solution on how to fix your problem.
This are the steps on how to do a D.I.Y troubleshooting:
  1. Remove the cover of your DVD player.
  2. Look at the DVD or CD tray assembly.
  3. Remove the whole CD tray assembly by loosening all screws at the left and right corner of the CD tray assembly and also you need to remove the front panel of the ejecting tray to get the whole CD tray assembly away from the DVD player for further repair and check-up.
  4. After that,look at the bottom of the DVD or CD tray and try to find out where's the motor that controls the ejecting tray.It is usually have a rubber O-ring or mini rubber belt that control the gear of ejecting tray
  5. Next,when you found the ejecting motor.Try to look at the rubber O-ring or mini rubber belt condition,if it is cut,loosen or disconnected from the motor.
  6. If the rubber belt is in good condition,check the ejecting motor.There are 2 ways of testing the motor,first the resistance checking-you should have a ohmmeter or multimeter (resistance or ohm range) point your (+/-) test prove to the terminal of the motor to measure the resistance.Secondly the actual testing-this procedure you need a battery 3vdc,connect the negative(-) terminal of the battery on the black wire of the motor and the positive(+) is connect to the red wire.If the motor is not spin-up replace it with the same type,rating,voltage and value.
  7. If you already done this procedure and the problem is still there after you replace the defective parts,if any.The problem could be the motor ejecting driver that found on the main board.This is not for D.I.Y because of the parts inside main board is very sensitive and hard to replace.If the trouble is on the main board you have to replace the whole main board or buy a new player.
I hope this solution could help you to fix your problem and enhance your knowledge about this.
Thank you for using FixYa.If you have a comment,feedback and testimony regarding this solution please feel free to post it!.Good luck!
Posted on Apr 29, 2011
Have DVD in Sony DVP-NS50P DVD Player and don't know how to get it to run. Thanks.
http://www.docs.sony.com/release/DVPNS50-41P.pdf
Page 24 shows instructions on how to play a disc
Mar 01, 2011 | Sony DVP-NS50P DVD Player
Hi! how to unlock region code on my sony dvp-ns50p thanx
With the DVD player turned off(stand by), press:
TOP MENU
CLEAR
POWER
Choose option 2 and after option 4. Type:
12450 [press enter]
00000
The tray will open and close repetedly. Unplug the power cable and afterwards turn it on again.
Done! Your DVD is now multi-zone.
hope this helps
John
Jan 10, 2011 | Sony DVP-NS50P DVD Player
Dec 27, 2009 | Sony DVP-NS50P DVD Player
Nov 19, 2008 | Sony DVP-NS50P DVD Player
DVD unlocck code
My DVD player is Sony DVP-NS50P, it can not play some dics (not in USA). You can help to unlock it !
Thank you very much.
Oct 19, 2008 | Sony DVP-NS50P DVD Player
Region Codes
It works for NS50P, NS575 and the most models of the families NS50 e
NS500.
TOP MENU
CLEAR
POWER
12450 [press enter]
00000 - Then press enter and power off.
DVD will now be region Free.
Jan 07, 2008 | Sony DVP-NS50P DVD Player
SYSTEM NOT SWITCHING ON
i have same problem checked fuse was ok. Just went to turn on and system was dead. I would like to get some basic voltage values I could probe the power supply for.
Dec 14, 2007 | Sony DVP-NS50P DVD Player
PAL mode ?
Oct 27, 2007 | Sony DVP-NS50P DVD Player
Sony DVP-NS50P DVD Player Logo
205 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
