Question about JVC C-13811 TV
Do you know what's is the code for this model c-13811 tv??? I can't remember... U.u
PIONEER REMOTE CONTROL CU-SD092
HAVE A REMOTE FOR MY PIONEER SD-P5185 PROJECTION TELEVISION. THE TV IS ABOUT 10 YEARS OLD OR SO. REMOTE CONTROL IS MODEL CU-SD092. DOES ANYONE KNOW THE STEPS TO SEARCH CODES TO PROGRAM THIS TO WORK TV. IT WORKED BEFORE BUT TOOK THE BATTERIES OUT AND NOW I HAVE RESET IT AND DON'T REMEMBER HOW TO REPROGRAM
Feb 02, 2014 | Pioneer Televison & Video
Can't remember the code to reprogram my rca tv with universal remote
Try one of these codes:
0047, 0019, 0018, 0090, 0135, 0679
If none work, please let me know the model of remote you have and I can help you further.
Jun 29, 2011 | Computers & Internet
I cant remember the code for a radio shack remote control cat no 5-2147 to operate a sylvinia tv
0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161
Its one of those. I cant tell which without knowing the model of your tv
May 25, 2011 | Radio Shack (15-2147) Remote Control
I can't program my direct tv remote to my coby TFTV3225 TV. Don't have the right codes. Does anyone know the codes?
11531 is the code given by DirecTV for this model. To enter this code . . .
1. Slide the mode switch at the top of the remote to the TV position
2. Hold both the MUTE and SELECT buttons until the LED blinks twice
3. Enter the 5-digit code 11531
4. Test the volume and power buttons for correct operation with the TV
If the code does not work first time, try entering the code a couple more times. If it still doesn't work, also try code 11436. DirecTV do not list any other codes for your TV, so if they don't work, it's possible that the remote will not work with your TV. There is also a code search option which tries every code in the remote. If this doesn't work, the remote definitely will not work with your TV.
Please try the codes above and let me know if you need further assistance or the code search instructions. Also, remember to slide the mode switch back to the DirecTV position after you have finished entering the codes.
Regards,
BElectric
Apr 24, 2011 | Coby TFTV3225 32 in. LCD TV
REMOTE FOR JVC C-13811 TV WON'T WORK....WE THINK ITS THE 4 DIGIT CODE, BUT WE CAN'T GET TO WHERE WE NEED TO RESET IT...WHAT CAN WE DO?
As far as I am aware, the code is only for preventing rated channel viewing. Can the TV be turned on/off with the remote? If not, either the remote or the TV is defective. Check battery, check TV/DVD/SAT switch on the remote's side or front, is there any switch in the battery compartment? If the battery is good and the remote is functional, you may check it by holding it towards the your cell phone camera while pressing any remote button. You should see a bulb lights when any key is pressed. Our naked eye cannot see it but the camera can. To make sure the test works, use another remote. If the JVC remote test fails with good battery, change the remote. If the test shows good, then the TV's remote sensor could be defective.
Jan 23, 2010 | JVC C-13811 TV
Tuning or programming?
no tv signal at this outlet for cable. make sure center conductor of cable is coming through at both ends-may have been pulled away from wall outlet.
Apr 29, 2008 | JVC C-13811WT 13" TV
Rca universal remote code
You can go www.rca.com and locate a code in there universal code section . they have a link for this . If you can not find it let me know what rca remote you have. The remote # is generally on the front or on the battery door cover . I will see if i can find it for you . Also is this just a tv or is it a combo unit? If it is a combo also get the codes for a DVD or VCR if it has one of these built in your tv . Sometimes you have to use the codes for dvd or the vcr . Let me know , thanks
Mar 09, 2008 | Broksonic CTGV-5463TCT TV
CODE RETRIVAL FOR A SANSUI TV MODEL
I lost the remote to my Sansui TV and can't remember the model number. can I get a remote to replace it?, the tv was bought in 2004
Nov 19, 2007 | RCA RCR311B Remote Control
Durabrand model # BH2004D
Try uplugging the TV from the mains overnight. This should erase the Eprom memory, and also the set code. then default code will be 0000
Aug 18, 2007 | Durabrand DWT1905 TV
Televison & Video Logo
23 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
