Question about Toshiba Satellite 1955-S801 Notebook
Wifi driver - Toshiba Satellite 1955-S801 Notebook
Wifi button don't works
Ok follow this steps to check the wifi driver go to my computer right click it now select properties now click on device manager check for the modems section try to see if u see ur wifi modem listed if u see a yellow icon on ur wifi driver it means u need to install the driver again if everything is ok right click the wifi driver and select uninstall driver then restart ur computer driver should automatically install tell me if this fixed ur problem
Sep 02, 2014 | Computers & Internet
A2414n driver
Download software for Mars_A2416N - Fixya
www.fixya.com/support/t23865112-download_software_mars_a2416n
Mar 19, 2014 - download software for Mars_A2416N need the software - MSI Mars_a2414n Wifi Outdoor 44dbm ... a2414n driver need driver download.
Where is the DRIVER - Fixya
www.fixya.com/support/t21548780-driver
Nov 18, 2013 - Where is the DRIVER - MSI Mars_a2414n Wifi Outdoor 44dbm question. ... a2414n driver need driver download. Jan 12, 2014 ' MSI ...
MSI Mars_a2414n Wifi Outdoor... Repair Questions - Fixy
Jan 12, 2014 | MSI Mars_a2414n Wifi Outdoor 44dbm 150m...
Wifi driver for optima netbook
You can get the wifi driver for your optima netbook from the website of your computer's manufacturer. Look for the Support and Download page or something like that. Enter the model of your computer and the operating system. All the drivers will be shown. Install the driver for your wifi.
After installing it, you can make sure that all the drivers including the wifi driver updated by using RadarSync.
David
Apr 10, 2013 | Computers & Internet
Rooted ascend 2 m865 wifi error fix
Is your wifi driver or network driver updated? You should update that. If you want it done automatically, then I suggest that you install Radarsync.
Dec 15, 2012 | Huawei Computers & Internet
Wifi driver
Everex uses linux operating system; use orinoco drivers for USB wifi/b. Orinoco USB wifi can do 900kBps. Available on ebay or amazon? If you have external dialup modem, you can download agere orinoco USB drivers.
Mar 03, 2012 | Everex StepNote LM7WZ Notebook
Wiil not scan for wifi
Make Sure the WiFi Switch Is Set To On, And The Light There Is On Indicating WiFi Connected..
Check Your Device Manager to See If Driver And Hardware Is Present...
Update The Wifi Drivers From The Toughbook Website
Dec 03, 2009 | Panasonic Toughbook W7 Notebook
I need driver of this product (sakar wirless wifi) for windows vista!!!! i ned now.. please helpme!!!!!
Intel® WiFi Products Upgrade WiFi adapter driver on Windows Vista* circuit388.gif
Use the following steps to update or upgrade the WiFi adapter driver on Microsoft* Windows Vista*.
Note If you need to automate the process, use the file named iProdifx.exe from the driver package.
  1. Download the updated driver(s) from your computer manufacturer. Note If your computer manufacturer does not provide the driver, you can download a generic version from Intel.
  2. Click Start.
  3. Click Control Panel.
  4. Click System and Maintenance.
  5. Click System.
  6. Click Device Manager.
  7. Click the + symbol in front of Network adapters to expand the section.
  8. Right-click the WiFi adapter
  9. Click Properties.
  10. Click the Driver tab.
  11. Click Update Driver.
  12. Click Browse my computer for driver software.
  13. Browse to the location where you saved the updated driver file(s) and then click Next.
http://download.driverguide.com/driver/M04617/Sakar/d380221.html
this is the link download it and installed the driver
Apr 28, 2009 | Sakar (M04617) 802.11b Wireless Adapter
Wifi drivers problem
first check in your bios if the internal wifi card is enabled.
if it was not then your problem should be fixed by enabling it.
if it was enabled then try :
go to the compaq/hp website go to support and get the wifi driver for your model c700.
and reinstall the driver.
if this doesnt help pls add more info like what is not working is the wifi driver installed does the wifi card show up in the hardware propertys etc any info can help.
good luck
Feb 07, 2009 | Compaq Presario Notebook
Need wifi driver for presario c754tu with xp pro support
HI ,
Listen dear compaq c700 models does not support windows xp , so i suggest you to please install windows vista home basic minimum.... all the drivers needed by this os is available on www.hp.com..... hope you must be satisfied otherwise no solution is dere....
b.bye
May 10, 2008 | Compaq Presario 700 470024-192 Notebook
Asprie 5570Z wifi drivers
That laptop came with 3 different internal WiFi cards.
You can look on the bottom of the unit, and it "should" have a sticker / label telling you which one is installed.
Once you have figured out which card you have, you can get the drivers for the card here, under " Drivers and utilities - MS Windows XP". the wireless drivers are at the bottom of the list from the dropdown box:
http://support.acer-euro.com/drivers/notebook/as_5570.html
Mar 13, 2008 | Computers & Internet
Toshiba Satellite 1955-S801 Notebook Logo
37 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
