Question about Chauvet Geyser RGB Pyro Fog Machine
Geyser rgb - Chauvet Geyser RGB Pyro Fog Machine
Which is the best Repair center for geyser?
Dial fix is the best service center for geyser.Also called Water Heater, Geyser is a household appliance consisting of a gas or electric heating unit under a tank in which water is heated and stored.
Geyser Repairs Services in Hyderabad Dialfix
Feb 03, 2016 | Water Heaters
Which is the best Service center for Geyser in Hyderabad?
Also called Water Heater, Geyser is a household appliance consisting of a gas or electric heating unit under a tank in which water is heated and stored. Geyser Repairs Services in Hyderabad Dialfix
Feb 03, 2016 | Cell Phones
Fly Geyser in NW Nevada, does it exist?
Wow this is wierd but here goes... (from WIki) Fly Geyser is located on the private Fly Ranch in Hualapai Flat, about 0.3 miles (0.48 km) from State Route 34.[1] The ranch is currently owned by Todd Jaksick There is a high fence and a locked gate topped with spikes to exclude trespassers. The only access is a dirt road, but it is large enough to be seen from the road.
It is not an entirely natural phenomenon; it was accidentally created by well drilling in 1964 exploring for sources of geothermal energy.The well may not have been capped correctly, or left unplugged, but either way dissolved minerals started rising and accumulating, creating the travertine mound on which the geyser sits and continues growing. Water is constantly released, reaching 5 feet (1.5 m) in the air. The geyser contains several terraces discharging water into 30 to 40 pools over an area of 74 acres The geyser is made up of a series of different minerals, but its brilliant colors are due to thermophilic algae.
Sep 14, 2014 | Water Heaters
Junkers gas geysers
What is a, "geysers pilot"?
Jul 14, 2014 | Water Heaters
How to set a Kes load control timer model ISG1201
The Geyser Load Control Timer, ISG1201, is designed to prevent geyser from operating during the Eskom's designated weekly morning and evening peak times. The ISG1201 features 4 easily selectable, pre-programmed, geysers "ON" operating profiles to ensure maximum comfort whilst not burdening the user with the complicated process of having to program the unit.
The profiles are as follows;
  • Program (1) is always "ON"
  • Program (2) "ON" after sunset to accommodate solar geysers
  • Program (3) "OFF" all the time
  • Program (4) savings program - "ON" 6 hours weekdays and 12 hours weekend days
Source: http://www.kgwanyape.com/solutions/isg1201-geyser-load-control-timer/
Oct 31, 2013 | Hardware & Accessories
Had burst pipe, used geyser water to bath kid. Water supply now restored but geyser switch in box keeps on tripping... Help!
Use hair dryer and see if you can dry out parts.
Often, when electronics get wet, they cannot be repaired... like dropping cell phone in bucket of water.
Gene
h
Aug 28, 2013 | Mountain Plumbing Water Heaters
What is an anode in a geyser
The anode rod is part of water heater, not part of geyser:
Here are anode rod resources:
http://waterheatertimer.org/Replace-anode-rod.html
http://www.thetankatwaterheaterrescue.com/forums/forum3/
The geyser is compressor that attaches to top of water heater, and converts ambient room temperature into heat to heat water using the refrigeration cycle in reverse
Add a comment and fixya might notify me so i can more informeation if needed
Jul 08, 2013 | Water Heaters
Chauvet Geyser RGB Pyro Fog Machine Logo
113 people viewed this question
Top Chauvet Event Planning & Celebration Experts
DAVE PARTA
Level 1 Expert
samiya_jahan
Level 1 Expert
Are you a Chauvet Event Planning and Celebration Expert? Answer questions, earn points and help others
