Question about Garden
How do I test a stator? - Garden
  • 51 Answers
Put a multi tester across the two wires from the stator. Set the tester to Ohms, the reading can be compared to the manufacturers stated values. The reading will look something like 3.5 or 4.57. If it reads 0.00 0r some other low value like 0.81 it probably means the stator is faulty, (0.00 means dead short, no reading or flashing digits mean no circuit).
Posted on Oct 13, 2013
How do I test the stator on a 2009 heritage softail
To check the STATOR. Turn ignition key switch OFF, then disconnect the voltage regulator connector from alternator stator wiring. THEN connect an ohmmeter set on the RX1 scale with one lead into either of the stator sockets and the other lead to a good ground. And test for continuity - a good stator will show no continuity (0 ohms) across either stator socket - any other reading indicates a grounded stator which must be replaced. THEN remove the ground lead and insert lead it into the other stator socket - the resistance (with ohmmeter still set on the RX1 scale)should be 0.1-0.2 ohms - if the resistance is lower a stator short is indicated. Which means that the stator is damaged and must be replaced. - if the resistance is higher (OL on meter), an open is indicated and again, the stator is damaged and must be replaced. You should check socket 1 to 2 then 1 to 3 then 2 to 3. (If you only had a two wire stator you would check between wires/sockets 1 and 2).
Before testing short out the ohmmeter leads against each other and if they do not produce a reading of0 ohms subtract the reading you do get from any readings you get doing the stator checks in order to get accurate stator circuit readings, otherwise you may have out of range reading due to the internal and/or lead resistance of the ohmmeter.
Oct 10, 2014 | 2009 Harley Davidson FLSTC Heritage...
On a 2005 Suzuki C90t bike not charging. Stator and rectifier check out ok?
there is no test for a reg/ rectifier. stator can be checked for resistance and static tested for output. factory service manual will provide details. if stator passes both tests then replace regulator.
Sep 07, 2014 | Motorcycles
How do I test the stator coil on a yamaha warrior 350 electric start
hi .. go straight to here .. youtube link. http://www.youtube.com/results?search_query=yamaha+350+warrior+stator+test
yamaha 350 warrior stator test YouTube
Jul 20, 2014 | Motorcycles
Whats the correct procedure for measuring the resistance on the Stator, 2001 KLX 300. Which wires get tested and in which order?
Not familiar with this exact model but I have tested other stators. There should be 3 wires of the same color at the connector. This would be a 'Y' wound stator, all 3 are connected to each other. I f you don't have the ohm specs just check for resistance with an ohm meter. All 3 should show continuity to each other no matter what order you test. And, NONE should show continuity to ground. If the stator is removed, ground would be to the iron stator core.
May 22, 2014 | 2001 kawasaki KLX 300
Stator test on harley
You can also do an AC output test:
AC Output Check
Disconnect the voltage regulator connector from the alternator stator wiring and then connect an AC voltmeter across both stator sockets of a two wire stator, or if a three wire stator across two of the three for example 1 & 3 and then later you will repeat the test between 2 & 3 and later between 1 & 2. THEN run the engine at as close as possible in the circumstances to 2000 RPM. The AC output should be approximately 32-40 VAC, approximately 16-20VAC per 1000 RPM. If you have done a stator static test and the stator has proven to be in good mechanical condition and the AC output is below specifications, the charging problem is going to be a faulty rotor. If you have not done a static stator check yet and the AC output is less than as set out above it may be that the stator is defective and the static stator check will need to be done. While the regulator has nothing whatsoever to do with the alternator output, if the alternator output is good the regulator might be defective in either rectification or in limiting the output to the battery to under 15 VDC. If AC output is low and the stator has passed the static stator check then it is likely that the permanent magnets in the alternator rotor are weak. A permanent magnet can lose its magnetic strength if it is dropped or shocked such as letting it snap into place when being installed or possibly by use of an impact wrench to remove the compensator fastener etc.
May 04, 2014 | Harley Davidson FLSTC Heritage Softail...
How to test coil and stator on 1986 husky 510
multi metre and test output on ht , cap , and coil first ! check output on stator on voltage setting !
Aug 17, 2012 | Husqvarna Motorcycles
Testing voltage regulator
ENGINE OFF,UNPLUG the regulator, test continuity from each conductor to ground on the stator, if you have continuity STATOR IS SHORTED... if you test voltage OUTPUT at the stator, it should be around ten volts AC! NOT DC! per thousand RPM... THEN use a 12 volt test lite from regulator leads to ground, if ANY light happens at either lead, BAD regulator
Aug 02, 2012 | 2002 Harley Davidson FXDWG Dyna Wide Glide
I have a 2003 Dyna Wide Glide. My battery will not charge. The voltage regulator is new, and when I load tested the battery, it was only putting out 12.51 volts at all RPM levels. I then tested the stator...
If you had your meter in AC VOLTS, and you only got three volts out of the stator, it's bad. Check for a shorted stator but putting your meter in OHMS R X 1. Put one probe on the engine case and then the other to one of the contacts and then to the other. You should read infinite ohms. 12.5 volts is the normal reading of a fully charged battery. I never do the shorted stator test. Why? If the stator is not putting out at least 30 volts at a high idle, it makes no difference if the stator is shorted or what, it needs replacing. That's the way I look at it.
Good Luck
Steve
Jul 12, 2011 | 2002 Harley Davidson FXD Dyna Super Glide
1987 Shadow 700 charging problem
yes there is a couple of different ways to test these components,first you will need a voltmeter and the first test is an ohms (resistance) test unplug the stator and place the meter leads on the stator leads 1and 2 then 1and 3 then 3 and 2 should read between .2 and 2.5 ohms then do an insulation breakdown one lead to stator lead the other to ground should read OL or OFL if any reading stator is junk. Then test out put meter to ac-volts meter leads to stator leads start the bike should read 15-100 vac. Then as far as the reg/rec goes set meter to diode mode and place one meter lead to the power output and the other to the stator input side of the connector do this to all three wires and then rev. the meter leads and do again 0.3-0.8 forward bias OFL in rev. bias then place meter lead to ground wire on reg/rec and do the same test if you get readings in both forward and reverse bias the reg/rec is bad replace
Jun 04, 2010 | 1987 Honda VT 1100 C Shadow
Trying to verify that the stator is bad. Its a 2002 sportsman 90. I have the manual but it still doesn't tell you what to do if the the specs are out. The only test that is not checking out would be...
the fact that you only get 47 volts indicates the stator has an open, there is nothing else but the stator that causes this low un-regulated voltage reading, all stators are tested the sam no matter what they come out of, car motorcycle, ATV etc.
here is the basic test.
STATOR TESTING.—The stator winding can be tested for opens and grounds after it has been disconnected from the alternator end frame. If the ohmmeter reading is low or the test lamp lights when connected between each pair of stator leads (fig. 2-31), the stator winding is electrically good. A high ohmmeter reading or failure of the test lamp to light when connected from any one of the leads to
the stator frame (fig. 2-32) indicates the windings are not grounded. It is not practical to test the stator for shorts due to the very low resistance of the winding.
Figure 2-32
Feb 08, 2010 | Polaris ATV
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
