Question about Polaroid 2626-TLMB2626-TLMB LCD TV
Polaroid TV 2626 TLMB turn in off and on automatically
How to turn off subtitle without a remote on a polaroid tv
Polaroid turn off subtitles tv Questions & Answers - Fixya
www.fixya.com > Forum > Tags > turn off subtitles tv
Polaroid turn off subtitles tv related problems. ... ...subtitles on certain channels? go into menu or setup on remote there ... Not finding what you are looking for?
Nov 17, 2015 | Polaroid Televison & Video
Lost remote for Polaroid TLU 01941 TV,so bought a uni remote but no code listed for said TV. Any ideas anyone plz
Polaroid TLU-01941 CU,there are no codes for polaroids,find an original remote on ebay or 1800remotes,or try automatic code search
May 21, 2015 | Polaroid Televison & Video
Not audio
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 19, 2014 | Polaroid 2626-TLMB2626-TLMB LCD TV
Nokia 2626 car mode solution
nokia 2626 car automatic anser mode
Feb 05, 2012 | Nokia 2626 Mobile Phone
Picture turns black
Hello; I am John at J. D. Electronics in Poland, Maine. This set uses a very poor design. They are stacking two 450 volt cap to get a 900 volt rating needed in this circuit. This practice was used decades ago, but only with VERY high quality caps that are closely matched. At least one cap is bad, but they MUST both be replaced with high quality MATCHED caps. There is an 80% chance that these are your problem. These are on the power supply board which is the top board inside the large metal box inside the set. If you have no way of soldering and testing Caps send that top board to me with $40 cash or postal MO to cover parts, testing & replacing caps and return shipping but with NO WARRANTY. You must call first 207 998 5687 est. No weekend hours, but OK 9-5 est. Good luck, John
Sep 17, 2011 | Polaroid 3226-TLMB 32 in. LCD TV
Power supply
Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 21, 2011 | Polaroid 2626-TLMB2626-TLMB LCD TV
Can turn my polaroid tv on but cant get the hdtv input to come in....there is a slight buzz even without the antenna cable connected....when i bring up the menu and go to select hdtv the menu automatically...
The tv Tuner signal board is the causes and the problems.That the board,where the antenna signal wire plug into it to receive the incomming broadcasting tv signal channels stations.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Apr 04, 2011 | Polaroid FLM-323B Television
I turn on my polaroid t1035 and it automatically shuts down right away
Oct 08, 2010 | Polaroid i1035 Digital Camera
When I turn on the TV, it comes on and cuts right back off.
Most tv sets now have built in protect mode. Once it is turned on, the system will detect some errors on the circuit and automatically turns off to avoid further damage of the circuit. You need to ask for a repair man to open and repair it.
Nov 08, 2009 | Polaroid TDM-1421C TV
TV turns on...displays Polaroid then shuts off. Sometimes i can't even get it to the Polaroid point just turns on and turns off.
You have a bad power supply, call a local tv repair man 2 fix it for ya. Unless you think you can do it urself, but recommended a professional takes a look, dont want to damage anything else in the tv or hurt urself
Oct 07, 2009 | Polaroid Televison & Video
Polaroid 2626-TLMB2626-TLMB LCD TV Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
