Question about Health & Beauty
Hillman golf buggy
Motor or gears make a whineing noise
Check oil in rear diff
Posted on Oct 19, 2013
Makes whining noise
This could be a stuck Bendix gear. The Bendix gear is the gear that engages with the flywheel on the engine when you start the car, and if it hasn't retracted it will whine.
Check with a local garage, but do so soon.
Dec 12, 2013 | 2001 Ford Taurus
Rearend prob.[noise]
Here are the common causes or rear end noises
Constant high pitched whine at all speeds: Pinion Bearings or Ring gear carrier bearings
Whine at steady speeds or whines on deceleration: Rear end gear set is worn and will need to be replaced.
Rumbling type of noises are caused by wheel bearings or a tire with a separated cord.
Jan 19, 2011 | 1999 Suzuki Vitara
Engines whines loudly gets louder the more gas you give it. in nuetral or gear same whining noise
IS IT MANUAL OR AUTO? IF MANUAL YOUR CLUTCH IS MOST LIKELY SHOT OR GEARS ARE BENT BE CAREFUL AS U CAN CHIP FLY WHEEL AND THATS A PAIN CAUSE IT CAN SHATTER UR STARTER AND THEN YOUR IN FOR A EXPENSIVE REPAIR IF YOU DONT DO THE WORK URSELF
WITH TRANSMISSION CHECK THE FLUID IT MAY B LOW OR FLUID BURNT AND LET A DROP FALL ON UR FINGER IF METAL FRAGMENTS ARE IN IT U NEED TRANNY
BEST OF LUCK TO U I HAVE BEEN IN UR SHOES MANY TIMES MANY DIFFERENT CARS AND TRUCKS AND IM NOT EVEN 50 YET :)
POSS THE TRANNYS FLUID COULD B CLOGGED AND NEEDS CHANGING ,CARS ARE A NIGHTMARE I SEE WHY THE AMISH HAVE HORSE AND BUGGY'S
Dec 02, 2010 | 2003 Chevrolet TrailBlazer
Whining noise at low speed
If the noise happens when car is in park and you rev it to about 1500rpm's then its thebearing in the oil pump of the torque converter.It should make noise all the time even in park ideling. You may need a rebuild transmission. Have the vehicle checked out at a transmission repair shop
May 05, 2010 | Hyundai Motor 1998 Accent
1999 sebring makes whining noise from motor area. slips out of gear too? can anyone tell me what that may be?
you need to take it to a transmission shop,the whining
is the front pump in the transmission.
Jan 01, 2010 | 2000 Chrysler Sebring
VW GOLF 1.4 1999 S. Gearbox makes whining sound at idle. once clutch is pressed sound goes. car drives fine with no noise in 1st-4th gears. unable to select 5th gear.. just grinds and wont engage. VW Golf...
No good news on this one I think
Your whining sound problem is the Layshaft bearings in the gearbox are badly worn. It also seems that the baulk rings are damaged on 5th gear.
John
Aug 14, 2009 | 1999 Volkswagen Golf
Gearbox makes whining noise
sounds like syncro bearings in trans
Jul 20, 2009 | 2006 Volkswagen Golf
Loud whine in first gear only second is good a4 quatro thumping noise also in front end not associated withe the tranny noise could it be broken motor mount?
THE WHINE SOUNDS LIKE A BEARING GOING IN THE TRANS THE THUMPING NOISE DOES IT DO UNDER EXCELERATION IF SO THEN YES ITS A MOTOR MOUNT OR THANS MOUNT PUT THE E-BRAKE ON LIFT THE HOOD AND AND SLOWLY LET THE CLUTCH OUT YOU SHOULD BE ABLE TO SEE THE MOTOR MOVE
Jun 25, 2009 | 2000 Audi A4
Whining from engine when in gear
Just a thought- remove the oil filler cap when the whine is present - (this checks if PCV valve is faulty, causing high crankcase vacuum, which in turn causes a whistling/whine noise as air leaks past engine oil seals). Worth a check.
Try listening with a short piece of hose pipe to locate immediate area/source of noise.
Jun 17, 2009 | 1998 Dodge Ram 1500 4WD
Health & Beauty Logo
136 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
