Oil leak under washer
Large oil spot underneath the washer. Oil appears black. Approx. 6"dia. spot
  • 113 Answers
If its an old ge it needs a transmission seal
Posted on Apr 24, 2009
Where can I find underneath view of under hood of CD Vectra Auto?
The Haynes repair manuals usually provide an underside view of the engine compartment.
The oil spot you describe seems in an unlikely place, even if it is leaking from a brake component. Clearly the origin should be checked by someone qualified to do so, who can raise the car and look underneath safely.
If brake fluid is leaking out somewhere the level in the reservoir will be falling and that you should check. Standard brake fluid is glycol based and can easily be washed away by water so it should be simple to decide whether the new patch of a fluid is brake fluid or oil.
May 13, 2017 | Cars & Trucks
Black oil under my Lincoln mkz
transfer case is leaking. bad seal in transfer case. remove TC then replace seal. about 6 hours.
Apr 10, 2013 | 2007 Lincoln MKZ
How to change the oil filter
Put the car on a lift or jacks. Since it has low clearnance you will need lower jacks or use a ramp.
Remove the oil cap and the oil filter. You may need a strap wrench if the oil filter is too tight to come off by hand.
Look for trap door under the metal cover underneath the car. Open the trap door and you will have access to the oil pan drain bolt.
Use 17mm socket to remove the drain bolt and catch oil into a basin.
Remove the oil filter from the oil cap housing. YOu will also have to remove a large and small oil ring as well as a washer. The new filter will come with those. The oil rings must go into the groove to prevent oil from leaking. The filter goes on the cap housing. The washer that comes with the oil filter goes with the drain plug. Take off the old washer drain plug and put on the new washer drain plug and drain bolt once all oil has poured out.
Ratchet in drain bolt and close the trap door. Put on oil filter by hand. Put in 7 quarts of 5w-30 oil. Check with the dipstick as you get to the last half quart.
Replace oil cap, start engine, and check for any indications of leaks.
Aug 25, 2010 | 2006 BMW 3 Series
Oil leak on 2002 chevy S-10
HI, the best thing to ensure the right choice of repair is to look under the vehicle and inspect the oil pan and plug. you will notice on site where the leak is during this inspection. Considering the miles on this vehicle, the oil consumption is quite normal. you will have to replace the valve seal and rings soon. most oil consumption will occur around the 90-100,000 mile mark. Most likely, this oil leak will be coming from the oil pan itself but, it always good to inspect it before you buy new parts.
Please rate and god bless:)
Apr 13, 2009 | Chevrolet S 10 Cars & Trucks
Oil leaking underneath washer. Whirlpool
Your washer does not have a belt. Your gearcase is the trouble, part # 3360629. Hope this helps!
Feb 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Transmission noise
Washers normally don't have much grease in them at all....the transmission is full of oil....which on GE washers often gets dumped onto the floor.Remove power, tilt the washer back and check on/around/near the large center pulley under the tranny....often the belt and pulley throw the oil around inside the cabinet.
Some of the oils they use are a synthetic oil....acts a little diff than some other oils....sometimes if water gets into the tranny the oil can change foamy or black due to the moisture.
Feb 10, 2009 | GE WHRE5260E Top Load Washer
Oil leaking from washer
if it smell like wd 40..your transmission is defective,,need help replacing post question,,
Dec 27, 2008 | Frigidaire FEX831CS Top Load Stacked...
Spotting on IBM R40 TFT Screen
you can get a screen replacement cheaply on ebay/craigslist
Aug 31, 2008 | IBM 11P836402 for ThinkPad R40 Monitor
Oil and black specks on floor underneath washer (middle)
Check the position of the oil mark and check your machine to find out which place was leaking and fix it, maybe you need tie the screw up a little bit.
Jul 21, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
204 people viewed this question
Top Washing Machines Experts
