Question about Dryers
Trying to find the belt
I have a kenmore 80 series, & I'm trying to locate the belt to check it....can someone direct me to it? Thanks!
  • MIKE major May 11, 2010
    if it is a kenmore with top lint screen,remove the 2 lint screen screws,pul the top toward you and up at the same time and the lid pop's up.you can now see the belt,if you want you can remove the door switch wires and the 2 front panel screws 1 on each side top to get to the bottom-mike
  • 113 Answers
If it has the lint filter on the top pull it out take the two screws out pop the lid up and you should be able to see the belt
Posted on Apr 24, 2009
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series wash machine humming
you have a clogged pump
the pump is hooked directly to the motor if thats cogged the motor cannot move producing a humming sound
Oct 07, 2009 | Washing Machines
Kenmore 80 Series draining problem
Check the following before replacing the timer.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 01, 2009 | Kenmore Washing Machines
Kenmore Series 80
You can find an exploded view at Sears Parts Direct, as well as get P/N's for the parts needed. I suspect the roller assembly came apart which caused the belt to fail.
You will need your Model number to locate the exploded view. If you can not figure out the routing from that, then order the service manual from Sears. It will show the routing and describe how to assemble and test most all aspects of the appliance.
Jan 15, 2009 | Dryers
Kenmore 80 Series Heavy Duty Dryer won't work
hi thanks for the question the belt has probably broken there should be a bottom panel use screw driver to pry the front on each side pry outwards remove panel now you should see a broken belt replace thanks the appliance dod
Sep 25, 2008 | Kenmore 63942 Dryer
80 series kenmore washer
if you need part number is 110---3360629 gearcase fo all direct drive transmission
Jul 18, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore washer model 80 series won't spin in cycle but will when put on spin
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Feb 12, 2008 | Washing Machines
Dryers Logo
46 people viewed this question
Top Dryers Experts
