Question about Grundfos Plumbing
Grunfos ch2-50 my water pump works well but the pump doesn't stop when no water is used?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
Can you describe the pump you have? Is it used for household water or a sprinkler system? Typically a household pump will have a storage tank and a pressure switch. 90% of the problems with a pump not turning off is due to the pressure switch.
Posted on Oct 14, 2013
WHY DOES MY BOILER PUMP CONSTANTLY RUN
there is usually a pressure switch this may be an indication of the relay switch not opening and closing properly....shut off power then remove the protective cover (usually on top of motor) inspect the relay contacts they may have some burn marks take an emerey cloth or fine sand paper and slide between contacts hope that works
Aug 02, 2014 | Grundfos Pumps Grunfos UP15-42F 1/25 HP...
I have low pressure at house, There is no problem
I am just guessing but it appears there is a restriction such as a partally closed valve.
Sep 01, 2013 | Grundfos Pumps Grunfos UP15-42F 1/25 HP...
Is there a timer for a up1529sf?
Plug grunfos into any timer with 3-prong outlet.
Analog: Intermatic TN311C up to 3-on-off per day minimum 1/2 hour
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#TN
Digital: Woods 50009 or 59377: 7-day programming down to minute
http://waterheatertimer.org/Woods-timers-and-manuals.html#50009
Generally a Grunfos without timer will operate each time water temperature inside pipe falls below 90 degrees.
http://waterheatertimer.org/Water-heater-recirculation-system.html
So when timer turns ON, then grunfos receives power and thermostat must sense temps below 90 before pump turns on.
Mar 12, 2013 | Hardware & Accessories
My Frigidare Affinity front load washer doesn't pump water on the Normal cycle.
Check the water inlet electro valve at the rear of the washer and make sure it is working.
Jul 25, 2017 | Frigidaire Washing Machines
My reverse osmosis system causes my Grunfos pump to cycle on and off for two hours aftr drawing a gallon of water from the reverse osmosis. Is there way to fix this so that the pump doesn-t cyle on an
HI THIER MR.STEELE. MY NAME CANDY A..I COULD TOTALY UNDERSTAND WHEN SAY THAT THE CYCLING OF YOUR PUMP TURNING ON &N OFF CAN GET VERY ANNOYING.LET ME ASK U A QUESTION.? HAS THIS CONSTENT CYCLING CAUSE YOUR POWER BILL TO INCREASE? OK NOW ,LETS SEE WHAT WE CAN DO TO FIX THIS PROBLEM OF YOURS..THE ITEM THAT TELLS YOUR PUMP WHEN TO COME ON. HAS TO HAVE SOME KIND OF SETTINGS ADJUSTMENT.ON IT WHAT U HAVE TO DO IS.SPREAD 4 IT TOO COME ON WHEN U WANT IT TOO.
Dec 23, 2011 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Hi, I have a Grunfos mq cold water booster pump. It is cutting in and out when the water is not in use, Turns on for 15 seconds tehn off for a minute. I have checked for obvious above ground leaks which...
First check with a pressure gauge to see that the pressure is, indeed, dropping. Then, if it is possible, turn off the outlet valve to isolate the pump.
If pressure is still dropping, there is probably a check valve on the inlet of the pump that prevents water from the high pressure side from leaking back to the inlet piping side.
To test this, let the pump run and pressurize the house and immediately close the valve for the incoming water. If the pressure holds, then open the inlet valve and see if the pressure drops. If it drops, the inlet check valve has to be replaced (or cleaned).
Gary
Feb 19, 2011 | Grundfos Plumbing
Where can I get the wiring diagram for the Laing Autocirc? I want to wire in a momentary switch so that when I am ready to get in the shower I hit the switch and the pump runs until the water is warm and...
If you have the same Autocirc product I have, then it cannot be taken apart. The timer seems to be connected and sealed together with the pump. If yours is different, answer back with the wires that you can see and we'll see if the timer can be by-passed.
With the ordinary Grunfos-type pump that is not on a timer, you can add a switch and have the pump work on demand as you describe.
And they make a product that does the specific job you describe. It's called a Demand Pump. Link above shows two different types at page bottom.
I have not tested either Demand Pump shown. They operate on-demand ... when you activate the pump, the pump quickly brings water over from the hot water heater.
So the Demand Pump has a higher volume pump than the Autocirc or Grunfos.
I question a two things about the Demand Pump. 1) How will the increased pump pressure affect local pipes, especially supply tubes under a sink. 2) How HOT does the pump get? If pump gets hot, and it is located under bathroom sink next to paper goods, then that is a hazard. Some regional building codes don't allow ceiling light bulbs in closets because the bulbs get hot and start fires when people pack their closets full.
Oct 23, 2010 | Laing Thermotech Autocirc Undersink...
The hot water comes on immediately and sometimes takes ten to fifteen minutes I have the grundfos up10b5/atlc in my attic. The water is really a hard water kind. Can i clean it?
If your grunfos pump is clogged with hard water sediment, then it probably needs replacement.
You can try soaking it in CLR for a while, but I doubt it can be salvaged.
Sediment adheres to surfaces and there is no way to get inside the pump and scrub it out with a tooth brush.
You might benefit from replacing pump with the type that has a timer. That might save a bit of money. Or you can add a timer to the ordinary grundfos. If pump works fewer hours, it shouldn't clog up as quickly (or so the theory says)
And your water system might benefit by flushing your water heater each 6 months to prevent sediment from forming in the water heater.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Oct 21, 2010 | Grundfos UP10-16B5/ATLC Comfort Series...
My pump stays on after having a shower sometimes...
The pump will start and stop with a pressure switch that is mounted in the discharge of the pump. Sometimes pressure switches get sticky and won't shut off when they are supposed to. You can buy them at most hardware stores, the most common is a Square D, and you'll need to both connect it to the pipe and also to the power line and the pump motor.
Sep 13, 2009 | Grundfos MQ3-45 1 HP Pressure Booster...
Plumbing Logo
166 people viewed this question
Top Grundfos Plumbing Experts
john h
rayc588
Level 1 Expert
Are you a Grundfos Plumbing Expert? Answer questions, earn points and help others
