Question about Dell Dimension C521 PC Desktop
My computer was downloading windows updates overnight and froze. Tried turning it off from the power button, but did not work so I unplugged the computer. Few hours later I plugged the computer back in and it would not start. Power button is pushed in and is stuck pushed in. When I plug the computer in the fan comes on, power light blinks green once, and the whole thing shuts down. Any idea on how to fix? Thanks Robert
    Master:
  • 359 Answers
You will have to get your power button unstuck. I do not know what type of button you have but if you would like to at least get your PC on without it instantly turning off, you can remove the power switch connector from the motherboard. You will eventually need to have the switch unstuck, or replaced though.
Posted on Oct 13, 2013
Testimonial: "It turned out that the power button was stuck. I had everything unplugged from the computer and took the side panel off. The power button connects to a small plastic tube which is a couple inches long and curves upward. The plastic tube goes into a panel, and at the joint where the tube enters the panel the tube was stuck. With the tip of a screw driver I softly pushed the tube back into place and the power button popped out. Thanks for the help."
  • 64 Answers
If it's a Dell computer, the PSU is in safe mode, to fix Dell desktops with power cord out press and hold the power button, then connect the mains power lead, keep the power button held until it shuts-down release the button, now try turning on as normal... Hope that works for you.
Posted on Oct 17, 2013
  • Glenn Marsden
    Glenn Marsden Oct 17, 2013
Joed911
  • 4338 Answers
SOURCE: Computer won't turn on unless I unplug the Ethernet Cable
Is the Ethernet built-in on the system board? I would go to BIOS (hit F2 while booting the PC) and disable the ethernet. then restart the PC. See if it stays on with or without the Ethernet cable plugged in. If it does. The built-in Ethernet circuit is the problem. I would buy a Ethernet adapter ($20).and install it. and leave the built-in ethernet disabled.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 12, 2008
SOURCE: Computer wont turn on
I had the same problem here. And sure enough it was the USB socket that had been bent inside or broken off. Basically the pins were touching the sides of the casing and causing it to short on power up.
I used the method suggested above - get a screwdriver and (MAKING SURE THE POWER IS OFF) bend the pins from the USB socket back into shape so they are no longer touching the side casing. The USB port is unusable but the machine powered up straight away and is now working fine.
Thanks for your help!!
Posted on Oct 31, 2008
  • 60 Answers
SOURCE: Flashing Green Power Light on Tower
Try holding down the power for a full minute or two then start it up again. The power button may be set for sleep and not shut down. You may have to hold the button longer. If that doesn't work it could be RAM, or a serious problem with the motherboard.
Posted on May 06, 2009
SOURCE: 4600C no power, flashing amber light
i have a dimension 4600c. same problem. amber flashing light no sounds. replaced my power source and its now working fine. bought one on ebay for $47
Posted on May 11, 2009
madhatter639
  • 260 Answers
SOURCE: power button if flashing orange and nothing else works
It's likely that your power supply has started to go out. There are several different leads with varying voltages & amps. If your computer is getting enough power to make a light flash yellow or orange then this often means that there is something wrong with one or more of the voltages from the power supply. Sometimes it means that something is wrong with your motherboard. Like: burned out capacitors, resistors, & etc.
Posted on Jul 06, 2010
My samsung galaxy tab 2 has a frozen screen I can't even turn it off help
Here is how you fix this problem: Hold both the power button AND the volume UP button down at the same time for about 5-10 seconds it should restart. You don't lose any info doing this.
Mar 26, 2013 | Samsung Galaxy Tab 101 Tablet...
When I hit the power button it wont turn on. I have replaced the RAM with a known working DDR400 1GB stick, no fix. Tried switching power supplies, no fix, tried new videocard since when it was last on (a...
When you say the CMOS is set to reset, this should not be the case for normal usage. and maybe the problem if left in the on position the system will not start (which sounds like your problem).
Mar 18, 2011 | DFI NF4X INFINITY Motherboard
Sony DSC-W110 Hi, my camera was workign fine, plugged it into the computer to take some pictures off and the camera froze. Powered the camera down powered it back up and it froze again. Powered it down...
First, stop plugging it into the computer. Next, remove the card and battery, press all the buttons, leave it alone for 20 minutes, insert the card and then the battery (which I'm assuming is fully charged), turn it on. To download your pics in the future, use a separate card reader.
Apr 25, 2010 | Sony Cyber-shot DSC-W110 Digital Camera
Bush hd freesat topbox will not switch off or operate. plugged in hdmi cable to box and television, switched on box started software update, after a while screen went blank since then nothing on screen and...
blobby 1589, my Bush freesat box has just done the same. Power going to it. Blue light on. Cannnot turn the box on. Screen froze before it turned off. Tried unplugging it. There was a software upgrade 2 days ago - wonder if that has anything to do with it
Mar 06, 2010 | Audio Players & Recorders
Magellan Triton 400 update failed unit stuck in white screen
Hey, Had the same exact problem, found a website with instructions on how to fix it. Turns out there was a corrupt file in the update, so you have to download the update directly from magellan and copy/paste into folders yourself. Anyway, here's the link--it worked perfectly for me!
http://www.gelb.com/jungleghost/Articles/Upgrade_Fails_to_Complete.htm
May 30, 2009 | Magellan Triton 400 Handheld GPS Receiver
Sansa wont reconize
Substitute REC for volume + in the following instructions:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Nov 23, 2008 | SanDisk Sansa e250 MP3 Player
My 1gb mp3 player has froze mid-rewind
Songs may be fixed-term license or samples. Try resetting player first.
unplug mp3 player from pc
uninstall the Sansa software
reinstall the sansa software
replug the mp3 player
-Tha Mp3 Doctor
-Tha Mp3 Doctor
Nov 07, 2008 | SanDisk Sansa e250 MP3 Player
Computer won't boot
turn off the system remove all the cables from the back of the computer press and hold down the power button for 10 seconds now connect just the poer cable and try to tun on the system and as soon as it turns on tab the F8 key on the keyboard and then boot into last known good configuration
May 28, 2008 | Computers & Internet
Toshiba Satellite: A135-S4427 / Won't shut down
by pressing the power button in, the computer has gone into standby or hibernate mode.
Heres what you Do:- press and hold the power button for between 10 to 20 seconds.
that should bring it out of hibernation.
if that does,nt work. remove the main battery.
when you,ve resolved the problem, run a disk-scan via your windows operating system.
Mike @ Compurepair.
May 12, 2008 | Toshiba Satellite A135-S4427 Notebook
Av 500 froze while updating firmware, power light on with adapter but doesnt not work.
Press the power off button and volume up button simultaneously for a couple of seconds. Rick
Sep 30, 2006 | Archos AV 500 400-Hours Video Recorder
Dell Dimension C521 PC Desktop Logo
85 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
